[postgis-tickets] [PostGIS] #5139: PostGIS causes to_jsonb to no longer be parallel safe, ST_AsGeoJSON also parallel unsafe
trac at osgeo.org
Fri Jul 22 11:52:27 PDT 2022
parallel unsafe
Reporter: samuelspurling | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.2.2
Component: postgis | Version: 3.2.x
Resolution: | Keywords:
Comment (by robe):
I wanted to confirm that all output functions that try to output
spatial_ref_sys metadata fail.
I confirmed that ST_AsGML also fails.
What is interesting is ST_AsKML doesn't. I assume it's because it's using
ST_Transform to convert to WGS84 long lat, but why ST_Transform doesn't
fail when it has to also query spatial_ref_sys at some point I haven't
quite figured out. It looks like for the most part the projcache is used
most of the time instead of directly calling into spatial_ref_sys, so that
might be why.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5139#comment:6>
