[postgis-tickets] [PostGIS] #5157: basic_test failure on i386
PostGIS trac at osgeo.org
Fri Jul 22 22:30:54 PDT 2022
  Reporter:  Bas Couwenberg  |      Owner:  strk
      Type:  defect          |     Status:  new
  Priority:  blocker         |  Milestone:  PostGIS 3.3.0
 Component:  liblwgeom       |    Version:  master
Resolution:                  |   Keywords:
Comment (by Bas Couwenberg):
 You don't need an i386 system to reproduce this issue, you can also use an
 i386 chroot on amd64.
 See the [https://trac.osgeo.org/postgis/ticket/5014#comment:3 comment in
 #5014] where the process to create and use such a chroot is documented.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5157#comment:9>
