[postgis-tickets] [SCM] postgis.net branch website updated. cdc746a2b29c2d6bf0f6cf07fdc4a88986d2e9a5
Sat Jul 23 09:55:38 PDT 2022
the project "postgis.net".
The branch, website has been updated
       via  cdc746a2b29c2d6bf0f6cf07fdc4a88986d2e9a5 (commit)
      from  fa1d48da64e59044615ee40dc579385838ea03ac (commit)
revisions in full, below.
commit cdc746a2b29c2d6bf0f6cf07fdc4a88986d2e9a5
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Jul 23 12:55:31 2022 -0400
    PostGIS 3.2.2 release
diff --git a/config/_default/params.toml b/config/_default/params.toml
index 167f571..2f6aab2 100644
--- a/config/_default/params.toml
+++ b/config/_default/params.toml
@@ -141,8 +141,8 @@ dev_download = "/stuff"
     is_dev = true
   [postgis.releases.32]
     minor = "3.2"
-    dev = "3.2.2dev"
-    tag = "3.2.1"
+    dev = "3.2.3dev"
+    tag = "3.2.2"
   [postgis.releases.31]
     minor = "3.1"
     dev = "3.1.7dev"
diff --git a/content/post/2022/07-23_postgis-3.2.2.md b/content/post/2022/07-23_postgis-3.2.2.md
new file mode 100644
index 0000000..46cb94f
--- /dev/null
+++ b/content/post/2022/07-23_postgis-3.2.2.md
@@ -0,0 +1,76 @@
+title: PostGIS 3.2.2
+layout: post
+category: news
+tags: [release, 3.2]
+author: Regina Obe
+thumbnail:
+date: "2022-07-23"
+The PostGIS Team is pleased to release PostGIS 3.2.2!
+This release works for PostgreSQL 9.6-15.
+**3.2.2**
+* [source download]({{< loc "postgis.release_source">}}/postgis-3.2.2.tar.gz) [md5]({{< loc "postgis.dev_download">}}/postgis-3.2.2.tar.gz.md5)
+* [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.2.2/NEWS)
+* [PDF docs en]({{< loc "postgis.release_docs">}}/postgis-3.2.2.pdf)
+This release is a bug fix release, addressing issues found in the previous 3.2 releases.
+<!--more-->
+**Bug Fixes**
+  - [#5182](https://trac.osgeo.org/postgis/ticket/5182), Fix loading topology.sql in new database (Sandro Santilli)
+  - [#4835](https://trac.osgeo.org/postgis/ticket/4835), Occasional distance errors in polar area (Paul Ramsey)
+  - [#5124](https://trac.osgeo.org/postgis/ticket/5124), GRANT USAGE on topology schema to PUBLIC (Sandro Santilli)
+  - [#5120](https://trac.osgeo.org/postgis/ticket/5120), Fix not-null result from ST_EstimatedExtent against
+           truncated tables with spatial index (Sandro Santilli)
+  - [#5115](https://trac.osgeo.org/postgis/ticket/5115), Allow dropping topologies with pending constraints
+           (Sandro Santilli)
+  - [#5105](https://trac.osgeo.org/postgis/ticket/5105), Fix false invalidity report from ValidateTopology
+           (Sandro Santilli)
+  - [#5039](https://trac.osgeo.org/postgis/ticket/5039), postgis_tiger_geocoder: Support for TIGER 2021 (Regina Obe)
+  - [#5097](https://trac.osgeo.org/postgis/ticket/5097), Ensure spatial index is used during topology population
+           at the getClosestEdge step (Sandro Santilli)
+  - [#5091](https://trac.osgeo.org/postgis/ticket/5091), Fix --without-protobuf builds (Tobias Bussmann)
+  - [#5100](https://trac.osgeo.org/postgis/ticket/5100), Don't use pg_atoi (removed in PG15) (Laurenz Albe)
+  - [#5114](https://trac.osgeo.org/postgis/ticket/5114), Crash with long column names pgsql2shp (Paul Ramsey)
+  - [#5123](https://trac.osgeo.org/postgis/ticket/5123), Support for PG15 (JSON funcs exposed) (Regina Obe)
+  - [#5125](https://trac.osgeo.org/postgis/ticket/5125), Fix search path function (Sandro Santilli)
+  - [#5150](https://trac.osgeo.org/postgis/ticket/5150), Change signature of AddToSearchPath (Regina Obe)
+  - [#5151](https://trac.osgeo.org/postgis/ticket/5151), ST_SetPoint with empty geometries (Regina Obe)
+  - [#5152](https://trac.osgeo.org/postgis/ticket/5152), Fix infinite loop with ST_Split (Sandro Santilli)
+  - [#5173](https://trac.osgeo.org/postgis/ticket/5173), Crash creating flatgeobuf on row without geometry (Julien Rouhaud)
+  - [#4541](https://trac.osgeo.org/postgis/ticket/4541), ST_ConcaveHull returns a "geometrycollection" type
+        instead of the expected "polygon" (Regina Obe)
+  - [#5154](https://trac.osgeo.org/postgis/ticket/5154), raster ST_Value is undercosted (Regina Obe)
+**Upgrading**
+After installing the binaries or after running pg_upgrade:
+For PostGIS 3.2, 3.1, 3.0
+do below which will upgrade all your postgis extensions.
+```postgres
+SELECT postgis_extensions_upgrade();
+For PostGIS 2.5 and below do:
+```postgres
+ALTER EXTENSION postgis UPDATE;
+If you come across any issues, feel free to report via our [ticket tracker](https://trac.osgeo.org/postgis)
+or [mailing list](https://lists.osgeo.org/listinfo/postgis-users) with details
+View all [tickets for 3.2.2 milestone][1].
+[1]: https://trac.osgeo.org/postgis/query?status=assigned&status=closed&milestone=PostGIS+3.2.2&milestone=PostGIS+3.1.6&milestone=PostGIS+3.0.6
Summary of changes:
 config/_default/params.toml              |  4 +-
 content/post/2022/07-23_postgis-3.2.2.md | 76 ++++++++++++++++++++++++++++++++
 2 files changed, 78 insertions(+), 2 deletions(-)
 create mode 100644 content/post/2022/07-23_postgis-3.2.2.md
hooks/post-receive
postgis.net
