[postgis-tickets] [PostGIS] #5157: basic_test failure on i386
PostGIS trac at osgeo.org
Sat Jul 23 14:02:03 PDT 2022
  Reporter:  Bas Couwenberg  |      Owner:  strk
      Type:  defect          |     Status:  new
  Priority:  blocker         |  Milestone:  PostGIS 3.3.0
 Component:  liblwgeom       |    Version:  master
Resolution:                  |   Keywords:
Comment (by robe):
 Replying to [comment:10 Bas Couwenberg]:
 > 3.2.2 does not have this issue.
 Dependencies are all the same?  I didn't think any of that code has
 changed.
 Anyrate I was able to replicate the issue using your beta2 package and
 dpkg_buildpackage.
 I put in a debug line to see the difference:
 char *msg1 = "mbc_test failed (got %.12f expected %.12f) \n";
 if ( d > result->radius){
       printf(msg1, d, result->radius);
 output was:
 Suite: minimum_bounding_circle
   Test: basic_test ...mbc_test failed (got 247.436045591407 expected
 247.436045591404)
 FAILED
     1. cu_minimum_bounding_circle.c:38  - CU_ASSERT_TRUE(d <=
 result->radius)
 So I think maybe I should just change the test, cause the difference is so
 insignificant not to be a concern.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5157#comment:11>
