[postgis-tickets] [PostGIS] #5157: basic_test failure on i386
PostGIS trac at osgeo.org
Sat Jul 23 22:20:53 PDT 2022
  Reporter:  Bas Couwenberg  |      Owner:  strk
      Type:  defect          |     Status:  closed
  Priority:  blocker         |  Milestone:  PostGIS 3.3.0
 Component:  liblwgeom       |    Version:  master
Resolution:  fixed           |   Keywords:
Comment (by Bas Couwenberg):
 Replying to [comment:11 robe]:
 > Replying to [comment:10 Bas Couwenberg]:
 > > 3.2.2 does not have this issue.
 > Dependencies are all the same?  I didn't think any of that code has
 changed.
 gcc-12 is now default, everything else is mostly the same:
 --- /tmp/postgis-3.3.0.deps     2022-07-24 07:14:46.896921001 +0200
 +++ /tmp/postgis-3.2.2.deps     2022-07-24 07:14:59.852608988 +0200
 -Setting up bsdextrautils (2.38-4) ...
 +Setting up bsdextrautils (2.38-5) ...
 -Setting up lib32gcc-s1 (12.1.0-5) ...
 +Setting up lib32gcc-s1 (12.1.0-7) ...
 -Setting up lib32stdc++6 (12.1.0-5) ...
 +Setting up lib32stdc++6 (12.1.0-7) ...
 -Setting up libblosc1:amd64 (1.21.1+ds2-2) ...
 +Setting up libblosc1:amd64 (1.21.1+ds2-3) ...
 -Setting up libblosc-dev (1.21.1+ds2-2) ...
 +Setting up libblosc-dev:amd64 (1.21.1+ds2-3) ...
 -Setting up libgfortran5:amd64 (12.1.0-5) ...
 +Setting up libgfortran5:amd64 (12.1.0-7) ...
 -Setting up liblcms2-2:amd64 (2.12~rc1-2) ...
 +Setting up liblcms2-2:amd64 (2.13.1-1) ...
 -Setting up liblz1:amd64 (1.13-3) ...
 +Setting up liblz1:amd64 (1.13-4) ...
 -Setting up libobjc-11-dev:amd64 (11.3.0-4) ...
 +Setting up libobjc-11-dev:amd64 (11.3.0-5) ...
 -Setting up libobjc4:amd64 (12.1.0-5) ...
 +Setting up libobjc4:amd64 (12.1.0-7) ...
 -Setting up libpython3-stdlib:amd64 (3.10.4-1+b1) ...
 +Setting up libpython3-stdlib:amd64 (3.10.5-3) ...
 -Setting up libsqlite3-dev:amd64 (3.39.0-2) ...
 +Setting up libsqlite3-dev:amd64 (3.39.2-1) ...
 +Setting up libstdc++-11-dev:amd64 (11.3.0-5) ...
 -Setting up libwww-mechanize-perl (2.10-1) ...
 +Setting up libwww-mechanize-perl (2.12-1) ...
 -Setting up libxslt1.1:amd64 (1.1.34-4) ...
 +Setting up libxslt1.1:amd64 (1.1.35-1) ...
 -Setting up libyaml-0-2:amd64 (0.2.2-1) ...
 +Setting up libyaml-0-2:amd64 (0.2.5-1) ...
 -Setting up plzip (1.10-3) ...
 +Setting up plzip (1.10-4) ...
 -Setting up python3 (3.10.4-1+b1) ...
 +Setting up python3 (3.10.5-3) ...
 -Setting up python3-minimal (3.10.4-1+b1) ...
 +Setting up python3-minimal (3.10.5-3) ...
 -Setting up xsltproc (1.1.34-4) ...
 +Setting up xsltproc (1.1.35-1) ...
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5157#comment:13>
