[postgis-tickets] [PostGIS] #5191: Use integer instead of int4
PostGIS trac at osgeo.org
Mon Jul 25 11:48:11 PDT 2022
 Reporter:  robe     |      Owner:  robe
     Type:  defect   |     Status:  assigned
 Priority:  medium   |  Milestone:  PostGIS 2.5.8
Component:  postgis  |    Version:  2.5.x
 Keywords:           |
 integer is the canonical preferred way of specifying int4 in postgresql
 functions.  In fact if you define a function as input int4 or output int4,
 PostgreSQL changes it to integer when you script the function.
 To make it easier for our Perl script to determine a function is
 installed, we should standardize on integer instead of int4
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5191>
