[postgis-tickets] [PostGIS] #5139: PostGIS causes to_jsonb to no longer be parallel safe, ST_AsGeoJSON and ST_AsGML are also parallel unsafe
PostGIS trac at osgeo.org
Mon Jul 25 12:41:55 PDT 2022
  Reporter:  samuelspurling  |      Owner:  pramsey
      Type:  defect          |     Status:  new
  Priority:  medium          |  Milestone:  PostGIS 3.1.7
 Component:  postgis         |    Version:  3.2.x
Resolution:                  |   Keywords:
Comment (by Regina Obe <lr@…>):
 In [changeset:"6906e4079c1c084006af1aabdfc70c99b4286165/git"
 6906e407/git]:
 {{{#!CommitTicketReference repository="git"
 revision="6906e4079c1c084006af1aabdfc70c99b4286165"
 Use read only SPI to maintain parallel safety
 for ST_AsGeoJSON and ST_AsGML
 References #5139 for PostGIS 3.3.0
 Using same solution from #3952
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5139#comment:9>
