[postgis-tickets] [SCM] PostGIS branch stable-3.1 updated. 3.1.6-3-g3ef092d12
Mon Jul 25 14:07:34 PDT 2022
the project "PostGIS".
The branch, stable-3.1 has been updated
       via  3ef092d1297d7886a0971f060593c6a2d1aff11f (commit)
      from  0e9ccc76609a38fa4fda2d7dfa73ac796d76ba02 (commit)
revisions in full, below.
commit 3ef092d1297d7886a0971f060593c6a2d1aff11f
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Jul 25 14:01:44 2022 -0700
    Move to using snprintf for fixed length buffers.
diff --git a/extras/WFS_locks/WFS_locks.c b/extras/WFS_locks/WFS_locks.c
index 31c79bf63..6655ac191 100644
--- a/extras/WFS_locks/WFS_locks.c
+++ b/extras/WFS_locks/WFS_locks.c
@@ -33,8 +33,7 @@ Datum check_authorization(PG_FUNCTION_ARGS)
 	char *lockcode;
 	char *authtable = "authorization_table";
 	const char *op;
-#define ERRMSGLEN 256
-	char errmsg[ERRMSGLEN];
+	char errmsg[256];
 	/* Make sure trigdata is pointing at what I expect */
@@ -86,7 +85,7 @@ Datum check_authorization(PG_FUNCTION_ARGS)
 	elog(NOTICE,"check_authorization called");
 #endif
-	sprintf(query,"SELECT authid FROM \"%s\" WHERE expires >= now() AND toid = '%d' AND rid = '%s'", authtable, trigdata->tg_relation->rd_id, pk_id);
+	snprintf(query, sizeof(query), "SELECT authid FROM \"%s\" WHERE expires >= now() AND toid = '%d' AND rid = '%s'", authtable, trigdata->tg_relation->rd_id, pk_id);
 #if PGIS_DEBUG > 1
 	elog(NOTICE,"about to execute :%s", query);
@@ -120,7 +119,7 @@ Datum check_authorization(PG_FUNCTION_ARGS)
 	 * check to see if temp_lock_have_table table exists
 	 * (it might not exist if they own no locks)
-	sprintf(query,"SELECT * FROM pg_class WHERE relname = 'temp_lock_have_table'");
+	snprintf(query, sizeof(query), "SELECT * FROM pg_class WHERE relname = 'temp_lock_have_table'");
 	SPIcode = SPI_exec(query,0);
 	if (SPIcode != SPI_OK_SELECT )
 		elog(ERROR,"couldnt execute to test for lockkey temp table :%s",query);
@@ -129,7 +128,7 @@ Datum check_authorization(PG_FUNCTION_ARGS)
 		goto fail;
-	sprintf(query, "SELECT * FROM temp_lock_have_table WHERE xideq( transid, getTransactionID() ) AND lockcode ='%s'", lockcode);
+	snprintf(query, sizeof(query), "SELECT * FROM temp_lock_have_table WHERE xideq( transid, getTransactionID() ) AND lockcode ='%s'", lockcode);
 #if PGIS_DEBUG
@@ -150,7 +149,7 @@ Datum check_authorization(PG_FUNCTION_ARGS)
 fail:
-	snprintf(errmsg, ERRMSGLEN, "%s where \"%s\" = '%s' requires authorization '%s'",
+	snprintf(errmsg, sizeof(errmsg), "%s where \"%s\" = '%s' requires authorization '%s'",
 	         op, colname, pk_id, lockcode);
 	errmsg[ERRMSGLEN-1] = '\0';
diff --git a/postgis/long_xact.c b/postgis/long_xact.c
index 91b2344ba..68e64796d 100644
--- a/postgis/long_xact.c
+++ b/postgis/long_xact.c
@@ -61,8 +61,7 @@ Datum check_authorization(PG_FUNCTION_ARGS)
 	char *lockcode;
 	const char *op;
-	char err_msg[ERRMSGLEN];
+	char err_msg[256];
@@ -112,7 +111,7 @@ Datum check_authorization(PG_FUNCTION_ARGS)
 	POSTGIS_DEBUG(3, "check_authorization called");
 	POSTGIS_DEBUGF(3 ,"about to execute :%s", query);
@@ -141,7 +140,7 @@ Datum check_authorization(PG_FUNCTION_ARGS)
 		goto fail;
 	POSTGIS_DEBUGF(3, "about to execute :%s", query);
@@ -168,9 +167,9 @@ Datum check_authorization(PG_FUNCTION_ARGS)
 fail:
-	snprintf(err_msg, ERRMSGLEN, "%s where \"%s\" = '%s' requires authorization '%s'",
+	snprintf(err_msg, sizeof(err_msg), "%s where \"%s\" = '%s' requires authorization '%s'",
-	err_msg[ERRMSGLEN-1] = '\0';
+	err_msg[sizeof(err_msg)-1] = '\0';
 #ifdef ABORT_ON_AUTH_FAILURE
 	elog(ERROR, "%s", err_msg);
Summary of changes:
 extras/WFS_locks/WFS_locks.c | 11 +++++------
 postgis/long_xact.c          | 13 ++++++-------
 2 files changed, 11 insertions(+), 13 deletions(-)
hooks/post-receive
