[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0beta2-20-g2249fb637
Mon Jul 25 18:49:03 PDT 2022
the project "PostGIS".
       via  2249fb637b3afcdac3c6a2b0d01306b59f4379e7 (commit)
      from  a80b805b095d5f75b5d24bde43092e661ad60f6d (commit)
revisions in full, below.
commit 2249fb637b3afcdac3c6a2b0d01306b59f4379e7
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Jul 25 21:48:57 2022 -0400
    Regression test for  #5139
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 89a817cb9..08b0fd6a4 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1438,3 +1438,29 @@ SELECT
 -- https://trac.osgeo.org/postgis/ticket/5151
 SELECT '#5151', ST_SetPoint(ST_GeomFromText('LINESTRING EMPTY',4326), 1, ST_GeomFromText('POINT(40 50)',4326)) As result;
+-- https://trac.osgeo.org/postgis/ticket/5139
+SET client_min_messages TO ERROR;
+DROP TABLE IF EXISTS a;
+CREATE TABLE a AS
+SELECT x AS id, ST_Point(40000 + 10000, -100000 , 27700) AS geom
+FROM generate_series(1,1000000) AS x ;
+set max_parallel_workers_per_gather=3;
+set force_parallel_mode=on;
+DROP TABLE IF EXISTS object_list_temp;
+WITH object_list AS (
+	SELECT '#5139'::text AS t, id, to_jsonb(geom) AS json_data
+	FROM a
+	WHERE id::text LIKE '100000%'
+SELECT * INTO TEMPORARY TABLE object_list_temp
+FROM object_list;
+DROP TABLE IF EXISTS object_list;
+SELECT t, id FROM object_list_temp;
+reset max_parallel_workers_per_gather;
+reset force_parallel_mode;
+SET client_min_messages TO NOTICE;
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index 1dea7e91d..da7ebe1a9 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -461,3 +461,5 @@ ERROR:  LWGEOM_addpoint: Invalid offset
 #4799|{"type": "Feature", "geometry": {"type":"Point","crs":{"type":"name","properties":{"name":"EPSG:25832"}},"coordinates":[359667,5651729]}, "properties": {"id": 1, "geom1": {"type":"Point","crs":{"type":"name","properties":{"name":"EPSG:3035"}},"coordinates":[4110471,3103061]}}}
 #5008|f|f
 ERROR:  Line has no points
+#5139|100000
+#5139|1000000
Summary of changes:
 regress/core/tickets.sql      | 26 ++++++++++++++++++++++++++
 regress/core/tickets_expected |  2 ++
 2 files changed, 28 insertions(+)
hooks/post-receive
