[postgis-tickets] [PostGIS] #5139: PostGIS causes to_jsonb to no longer be parallel safe, ST_AsGeoJSON and ST_AsGML are also parallel unsafe
PostGIS trac at osgeo.org
Tue Jul 26 12:08:19 PDT 2022
  Reporter:  samuelspurling  |      Owner:  pramsey
      Type:  defect          |     Status:  closed
  Priority:  medium          |  Milestone:  PostGIS 3.1.7
 Component:  postgis         |    Version:  3.2.x
Resolution:  fixed           |   Keywords:
Comment (by Regina Obe <lr@…>):
 In [changeset:"8ae2e1c1d82a10c581493e3154db81df019e17f1/git"
 8ae2e1c1/git]:
 {{{#!CommitTicketReference repository="git"
 revision="8ae2e1c1d82a10c581493e3154db81df019e17f1"
 Fix ST_Point to use older signature in tests. References #5139 for PostGIS
 3.1.7
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5139#comment:13>
