[postgis-tickets] [PostGIS] #5194: SELECT postgis_extensions_upgrade() fails with pgextwlist
PostGIS trac at osgeo.org
Fri Jul 29 22:34:24 PDT 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 3.3.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by strk):
 The use of ANY was illustrated as SOLUTION1 in
 https://trac.osgeo.org/postgis/wiki/PostGISExtensionPaths -- I've now
 marked that solution as failing, with reference to this ticket
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5194#comment:5>
