[postgis-tickets] [PostGIS] #5165: CREATE EXTENSION scripts should use CREATE instead of CREATE OR REPLACE
PostGIS trac at osgeo.org
Thu Jun 2 14:44:17 PDT 2022
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 3.3.0
Component:  build/upgrade/install  |    Version:  master
 Keywords:                         |
 Best practices, all our postgis-3.3.sql should be using CREATE instead of
 CREATE OR REPLACE.
 We should start doing this with 3.3.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5165>
