[postgis-tickets] [PostGIS] #5166: Remove Minor from our extension scripts
PostGIS trac at osgeo.org
Thu Jun 2 15:06:25 PDT 2022
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 3.3.0
Component:  build/upgrade/install  |    Version:  master
 Keywords:                         |
 This will be for PostGIS 3.3.0 moving forward.  We discussed the idea of
 doing that for all minors, but decided that was too drastic.
 So sadly we've still got to carry all those scripts.
 3.3 will have scripts
 # these all 0 byte
  postgis--3.0
  postgis--3.1.0 --3.3.X.sql
  postgis--3.1.1 --3.3.X.sql
  postgis--3.1.2 --3.3.X.sql
 postgis--3.2.1 --3.3.X.sql
 # these not 0 byte
 postgis--3.3.X--3.3.sql (not 0 byte)
 postgis-3.3next--3.3.sql (not 0 byte)
 postgis-3.3next-3.3.sql (not 0 byte)
 (the 3.3next 3.3.sql I am thinking if we decided we want our alter
 extension scripts to have CREATE OR REPLACE only for existing and CREATE
 for net-net new, we'd still keep the CREATE OR REPLACE for the 3.3next
 even for net-net new and for the 3.3X--3.3.sql this would be CREATE for
 net-net new functionality.
 and so most we will use 0 byte files as Paul proposed here -
 https://trac.osgeo.org/postgis/wiki/PostGISExtensionPaths#SOLUTION3
 postgis 3.4 would then look like
 # these all 0 byte
  postgis--3.0
  postgis--3.1.0 --3.4.X.sql
  postgis--3.1.1 --3.4.X.sql
  postgis--3.1.2 --3.4.X.sql
 postgis--3.2.1 --3.4.X.sql
 postgis--3.3 --3.4.X.sql #regardless which 3.3 micro release, no new files
 # these not 0 byte
 postgis--3.4.X--3.4.sql (not 0 byte)
 postgis-3.4next--3.4.sql (not 0 byte)
 postgis-3.4-3.4next.sql (not 0 byte)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5166>
