[postgis-tickets] [PostGIS] #5167: berries garden tests failing
PostGIS trac at osgeo.org
Thu Jun 2 15:16:05 PDT 2022
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.1.6
Component:  postgis  |    Version:  3.1.x
 Keywords:           |
 Both berrie and berrie64 in 3.1 tests
 16:31:08 COMMIT
 16:31:08 -------------------------------------------------
 16:31:08 Regression tests in progress (it will take time)
 16:31:08 Result output: ./regress/postgis_garden_result.txt
 16:31:08 psql --no-psqlrc -ad postgis_garden <
 ../doc/postgis_gardentest_31.sql > postgis_garden_result.txt 2>&1
 16:57:31 make[1]: *** [Makefile:100: garden] Error 2
 16:57:31 make[1]: Leaving directory
 '/home/jenkins/workspace/PostGIS_Worker_Run/label/berrie64/69b60e63f819ec26690e9b8cfcbe505904d62eab/regress'
 16:57:31 make: *** [GNUmakefile:115: garden] Error 2
 16:57:31 + err_status=2
 16:57:31 + [ -d
 /home/jenkins/workspace/pg/label/berrie64/rel/pg14w64/data_55432/postmaster.pid
 16:57:31 + exit 2
 16:57:31 Build step 'Execute shell' marked build as failure
 16:57:37 Finished: FAILURE
 Seem to be okay in 3.2 and master branches.  It's possible it's left over
 from me accidentally adding newer garden test cases we can't backport to
 3.1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5167>
