[postgis-tickets] [PostGIS] #5166: Remove Micro (Patch level) from our extension scripts and use 0-byte scripts
PostGIS trac at osgeo.org
Mon Jun 6 07:48:46 PDT 2022
scripts
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.3.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Description changed by robe:
Old description:
> This will be for PostGIS 3.3.0 moving forward.  We discussed the idea of
> doing that for all minors, but decided that was too drastic.
> So sadly we've still got to carry all those scripts.
> 3.3 will have scripts
> # these all 0 byte
>  postgis--3.0.0--3.3.MAX.sql
>  postgis--3.0.1--3.3.MAX.sql
>  postgis--3.1.0--3.3.MAX.sql
>  postgis--3.1.1--3.3.MAX.sql
>  postgis--3.1.2--3.3.MAX.sql
> postgis--3.2.1--3.3.MAX.sql
> postgis--3.3.0alpha1--3.3.MAX.sql
> postgis--3.3.0dev--3.3.MAX.sql
> # these not 0 byte
> postgis--3.3.MAX--3.3.sql
> postgis-3.3next--3.3.sql
> postgis-3.3--3.3next.sql
> (the 3.3next 3.3.sql I am thinking if we decided we want our alter
> extension scripts to have CREATE OR REPLACE only for existing and CREATE
> for net-net new, we'd still keep the CREATE OR REPLACE for the 3.3next
> even for net-net new and for the 3.3X--3.3.sql this would be CREATE for
> net-net new functionality.
> and so most we will use 0 byte files as Paul proposed here -
> https://trac.osgeo.org/postgis/wiki/PostGISExtensionPaths#SOLUTION3
> postgis 3.4 would then look like
> # these all 0 byte
>  postgis--3.1.0--3.4.MAX.sql
>  postgis--3.1.1--3.4.MAX.sql
>  postgis--3.1.2--3.4.MAX.sql
> postgis--3.2.1--3.4.MAX.sql
> postgis--3.3--3.4.MAX.sql #regardless which 3.3 micro release, no new
> files
> # these not 0 byte
> postgis--3.4.MAX--3.4.sql
> postgis-3.4next--3.4.sql
> postgis-3.4-3.4next.sql
New description:
 Main benefits:
  1) We will eventually have fewer files (savings of not having micro
 scripts moving forward) Note even if PostgreSQL project were to fix this,
 we'd still need something like this for older versions of PostgreSQL since
 they likely will not backport that.
 2) Using Paul's 0 byte, the file sizes will be smaller even if the
 packager doesn't symlink.
 3) If someone is upgrading from a version released after the one they are
 upgrading to, they can still upgrade.  It also means we don't need to have
 to remember to include recently released micros in our new release.
 # these all 0 byte
 # these not 0 byte
 # these all 0 byte
 files
 # these not 0 byte
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5166#comment:5>
