[postgis-tickets] [PostGIS] #5167: berries garden tests failing
PostGIS trac at osgeo.org
Wed Jun 8 10:38:42 PDT 2022
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.1.6
 Component:  postgis  |    Version:  3.1.x
Resolution:           |   Keywords:
Comment (by robe):
 Okay looks like it's crashing on:
 SELECT ST_Node(ST_GeomFromText('LINESTRING EMPTY',4326))  As result
 This is running with GEOS 3.10.2.  The other branches where this is not
 crashing are running newer GEOS.  I'm going to move berries PostGIS 3.1
 runs to check this out with the latest released 3.10 to see if is still an
 issue.
 Unfortunately I don't have that version of geos installed, so can't
 confirm it crashes on other than ARM.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5167#comment:2>
