[postgis-tickets] [PostGIS] #5165: CREATE EXTENSION scripts should use CREATE instead of CREATE OR REPLACE
PostGIS trac at osgeo.org
Wed Jun 8 11:38:20 PDT 2022
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.3.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by strk):
 > our function would now make a function they own be part of postgis
 Woudn't it be much simpler to just FORCE ownership of functions, in the
 upgrade script ?
 We would check the ownership of a function which is known to have been in
 postgis forever (postgis_version?) and set ownership of all functions,
 after the CREATE OR REPLACE, to that user.
 Would this block the kind of attack you describe ?
 The enforcement of all function of the extension could be also done in a
 single final statement, as we can easily get the list of all functions in
 our extension, and could set ownership of those function match ownership
 of the extension itself
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5165#comment:3>
