[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0alpha1-19-g99cfcff56
Thu Jun 9 11:37:40 PDT 2022
the project "PostGIS".
       via  99cfcff5671882e202a14b56449868e7b88a42b2 (commit)
      from  4ad1e66b123d76e7dd3127660b8da13ce1942978 (commit)
revisions in full, below.
commit 99cfcff5671882e202a14b56449868e7b88a42b2
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Jun 9 11:37:36 2022 -0700
    Turn off cirrus-ci bots until someone wants to make them happy
diff --git a/.cirrus.yml b/.cirrus.yml
index 67df00bd2..31cb804b1 100644
--- a/.cirrus.yml
+++ b/.cirrus.yml
@@ -1,35 +1,35 @@
-freebsd_instance:
-  image: freebsd-12-2-release-amd64
-  cpu: 8
-  memory: 16G
+# freebsd_instance:
+#   image: freebsd-12-2-release-amd64
+#   cpu: 8
+#   memory: 16G
-task:
-  only_if: $BRANCH != 'master'
-  install_script:
-    - sed -i.bak -e 's,pkg+http://pkg.FreeBSD.org/\${ABI}/quarterly,pkg+http://pkg.FreeBSD.org/\${ABI}/latest,' /etc/pkg/FreeBSD.conf
-    - ASSUME_ALWAYS_YES=yes pkg bootstrap -f
-    - pkg install -y bison postgresql12-server gmake libxml2 autoconf automake libtool pkgconf iconv pcre proj gdal sfcgal geos libxslt cunit protobuf-c json-c postgresql12-contrib
+# task:
+#   only_if: $BRANCH != 'master'
+#   install_script:
+#     - sed -i.bak -e 's,pkg+http://pkg.FreeBSD.org/\${ABI}/quarterly,pkg+http://pkg.FreeBSD.org/\${ABI}/latest,' /etc/pkg/FreeBSD.conf
+#     - ASSUME_ALWAYS_YES=yes pkg bootstrap -f
+#     - pkg install -y bison postgresql12-server gmake libxml2 autoconf automake libtool pkgconf iconv pcre proj gdal sfcgal geos libxslt cunit protobuf-c json-c postgresql12-contrib
-  patch_script:
-    # will be removed
-    - find . -name "*.pl" | xargs sed -i -r 's|/usr/bin/perl|/usr/bin/env perl|'
-  configure_script:
-    - ./autogen.sh
-    - ./configure PKG_CONFIG=/usr/local/bin/pkgconf CFLAGS="-isystem /usr/local/include -Wall -fno-omit-frame-pointer -Werror" LDFLAGS="-L/usr/local/lib" --with-libiconv-prefix=/usr/local --without-gui --without-interrupt-tests --with-topology --without-raster  --with-sfcgal=/usr/local/bin/sfcgal-config --with-address-standardizer --with-protobuf
-    - service postgresql oneinitdb
-    - service postgresql onestart
-    - su -l postgres -c "createuser -s `whoami`"
-  build_script:
-    - gmake -j8
-  check_script:
-    - gmake -j8 check
-    - gmake -j8 install
-    - gmake -j8 check RUNTESTFLAGS="-v --extension"
-    - gmake -j8 check RUNTESTFLAGS="-v --dumprestore"
-  matrix:
-    - name: freebsd12-amd64
-      freebsd_instance:
-    - name: freebsd13-amd64
-      freebsd_instance:
-          image: freebsd-13-0-release-amd64
+#   patch_script:
+#     # will be removed
+#     - find . -name "*.pl" | xargs sed -i -r 's|/usr/bin/perl|/usr/bin/env perl|'
+#   configure_script:
+#     - ./autogen.sh
+#     - ./configure PKG_CONFIG=/usr/local/bin/pkgconf CFLAGS="-isystem /usr/local/include -Wall -fno-omit-frame-pointer -Werror" LDFLAGS="-L/usr/local/lib" --with-libiconv-prefix=/usr/local --without-gui --without-interrupt-tests --with-topology --without-raster  --with-sfcgal=/usr/local/bin/sfcgal-config --with-address-standardizer --with-protobuf
+#     - service postgresql oneinitdb
+#     - service postgresql onestart
+#     - su -l postgres -c "createuser -s `whoami`"
+#   build_script:
+#     - gmake -j8
+#   check_script:
+#     - gmake -j8 check
+#     - gmake -j8 install
+#     - gmake -j8 check RUNTESTFLAGS="-v --extension"
+#     - gmake -j8 check RUNTESTFLAGS="-v --dumprestore"
+#   matrix:
+#     - name: freebsd12-amd64
+#     - name: freebsd13-amd64
+#           image: freebsd-13-0-release-amd64
Summary of changes:
 .cirrus.yml | 66 ++++++++++++++++++++++++++++++-------------------------------
 1 file changed, 33 insertions(+), 33 deletions(-)
hooks/post-receive
