[postgis-tickets] [PostGIS] #5170: Make postgis raster copy rows configurable
PostGIS trac at osgeo.org
Thu Jun 9 13:53:02 PDT 2022
 Reporter:  robe         |      Owner:  robe
     Type:  enhancement  |     Status:  new
 Priority:  medium       |  Milestone:  PostGIS 3.3.0
Component:  raster       |    Version:  master
 Keywords:               |
 A client asked me why does copy mode, always result in
 COPY 11
 11 rows per copy command.
 I checked in the code, and it appears to be a hard-coded setting.
 https://git.osgeo.org/gitea/postgis/postgis/src/branch/master/raster/loader/raster2pgsql.c#L1518
 https://git.osgeo.org/gitea/postgis/postgis/src/branch/master/raster/loader/raster2pgsql.c#L1845
         if (tileset->length > 10) {
                                 if (!insert_records(
                                         config->schema, ovtable,
 config->raster_column,
                                         (config->file_column ?
 config->rt_filename[idx] : NULL), config->file_column_name,
                                         config->copy_statements,
 config->out_srid,
                                         tileset, buffer
 I'm assuming this was put in place to get around some copy size limit.
 Can we get better load by increasing or making this configurable.
 I was going to test this out to see.  Given that the size of each row
 would be dependent on tile size, doesn't seem right it should always be
 11.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5170>
