[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0alpha1-31-geab253b38
Sat Jun 11 05:47:29 PDT 2022
the project "PostGIS".
       via  eab253b3822dd600d70b51e7988431440f24026b (commit)
       via  1fd20c9c1190c442b3399b9dde56029b5a7c9f5c (commit)
       via  acfd2483c540472093812e3356d7fcbb04fc1106 (commit)
       via  f712a84d1237514a1210a027871c646b9d554771 (commit)
       via  9b0809bdbf3561b4263993dfb6a9e33931cdfc2b (commit)
      from  a64af1feb79f40d9e5714a5b09ad3ec07a04b742 (commit)
revisions in full, below.
commit eab253b3822dd600d70b51e7988431440f24026b
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sat Jun 11 15:46:58 2022 +0300
    Add NEWS for directed linemerge.
diff --git a/NEWS b/NEWS
index 88607d974..4a03f6cc7 100644
--- a/NEWS
+++ b/NEWS
@@ -5,10 +5,12 @@ Changes since PostGIS 3.3.0alpha1
   - #5158, pgtopo_import / pgtopo_export manpages (Sandro Santilli)
   - #5170, add a -Z option to raster2pgsql to
     control number of rows per copy statement (Regina Obe)
+  - #4939, #5161, ST_LineMerge now has option to keep the directions of input linestrings,
+    useful when processing road graphs. Requires GEOS 3.11. (Sergei Shoulbakov)
 * New features *
   - #5169, ST_SimplifyPolygonHull (requires GEOS 3.11)
-    Paul Ramsey, Martin Davis
+    (Paul Ramsey, Martin Davis)
 PostGIS 3.3.0alpha1
commit 1fd20c9c1190c442b3399b9dde56029b5a7c9f5c
Merge: a64af1feb acfd2483c
Author: Sergei <managerzf168 at gmail.com>
Date:   Sat Jun 11 15:37:04 2022 +0300
    Merge acfd2483c540472093812e3356d7fcbb04fc1106 into a64af1feb79f40d9e5714a5b09ad3ec07a04b742
commit acfd2483c540472093812e3356d7fcbb04fc1106
Author: sergei sh <sshoulbakov at kontur.io>
Date:   Fri Jun 3 12:16:02 2022 +0300
    ST_LineMerg directed: creating overload for GEOS < 3.11
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 0a2e1faa1..8b175688b 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -1872,8 +1872,6 @@ CREATE OR REPLACE FUNCTION ST_LineMerge(geometry)
 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
 	_COST_HIGH;
-#if POSTGIS_GEOS_VERSION >= 31100
 -- Availability: 3.3.0
 CREATE OR REPLACE FUNCTION ST_LineMerge(geometry, boolean)
 	RETURNS geometry
@@ -1881,8 +1879,6 @@ CREATE OR REPLACE FUNCTION ST_LineMerge(geometry, boolean)
 	_COST_HIGH;
-#endif
 -- Affine transforms
commit f712a84d1237514a1210a027871c646b9d554771
Date:   Mon May 30 14:51:38 2022 +0300
    ST_LineMerge directed: docs; new image generator style
diff --git a/doc/html/image_src/Makefile.in b/doc/html/image_src/Makefile.in
index 175685c2e..d08d126ff 100644
--- a/doc/html/image_src/Makefile.in
+++ b/doc/html/image_src/Makefile.in
@@ -104,6 +104,7 @@ IMAGES= \
 	../images/st_line_interpolate_points01.png \
 	../images/st_linemerge01.png \
 	../images/st_linemerge02.png \
+	../images/st_linemerge03.png \
 	../images/st_line_substring01.png \
 	../images/st_locatebetween01.png \
 	../images/st_longestline01.png \
diff --git a/doc/html/image_src/st_linemerge03.wkt b/doc/html/image_src/st_linemerge03.wkt
new file mode 100644
index 000000000..08904f16b
--- /dev/null
+++ b/doc/html/image_src/st_linemerge03.wkt
@@ -0,0 +1,2 @@
+ArgA-arrow;MULTILINESTRING((60 130, 10 170), (120 150, 60 130), (120 150, 180 130))
+Result-arrow;MULTILINESTRING((120 50, 60 30, 10 70), (120 50, 180 30))
diff --git a/doc/html/image_src/styles.conf b/doc/html/image_src/styles.conf
index ac85f1ad7..511dbc6b9 100644
--- a/doc/html/image_src/styles.conf
+++ b/doc/html/image_src/styles.conf
@@ -168,6 +168,18 @@ polygonFillColor = "#ff000020"
 polygonStrokeColor = "#770000"
 polygonStrokeWidth = 2
+[Style]
+styleName = Result-arrow
+pointSize = 5
+pointColor = "#770000"
+lineWidth = 4
+lineColor = "#770000"
+lineStartSize = 5
+lineArrowSize = 10
+polygonFillColor = "#ff000020"
+polygonStrokeColor = "#770000"
+polygonStrokeWidth = 2
 [Style]
 # Result style for overlapping results
 styleName = Result-light
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index bd5135038..11b77d91a 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -1186,6 +1186,11 @@ FROM test;
 				<funcdef>geometry <function>ST_LineMerge</function></funcdef>
 				<paramdef><type>geometry </type> <parameter>amultilinestring</parameter></paramdef>
 			  </funcprototype>
+			  <funcprototype>
+				<funcdef>geometry <function>ST_LineMerge</function></funcdef>
+				<paramdef><type>geometry </type> <parameter>amultilinestring</parameter></paramdef>
+				<paramdef><type>boolean </type> <parameter>directed</parameter></paramdef>
+			  </funcprototype>
 			</funcsynopsis>
 		</refsynopsisdiv>
@@ -1198,9 +1203,14 @@ FROM test;
             Lines are not joined across intersections of 3-way or greater degree.
             </para>
+			<para>If <emphasis role="bold">directed</emphasis> is TRUE, then ST_LineMerge
+			will not change point order within LineStrings, so lines with opposite directions
+			will not be merged</para>
 			<note><para>Only use with MultiLineString/LineStrings. Other geometry types
 			return an empty GeometryCollection</para></note>
 			<para>Performed by the GEOS module.</para>
+			<para>Enhanced: 3.3.0 accept a directed parameter - requires GEOS >= 3.11.0</para>
 			<para>Availability: 1.1.0</para>
 			<warning><para>This function strips the M dimension.</para></warning>
 		</refsection>
@@ -1258,6 +1268,27 @@ SELECT ST_AsText(ST_LineMerge(
 MULTILINESTRING((-45.2 -33.2,-46 -32),(-29 -27,-30 -29.7,-36 -31,-45 -33))
 </programlisting>
+<para>
+	<informalfigure>
+		<mediaobject>
+			<imageobject>
+				<imagedata fileref="images/st_linemerge03.png" />
+			</imageobject>
+			<caption>
+				<para>Lines with opposite directions are not merged if directed = TRUE.</para>
+			</caption>
+		</mediaobject>
+	</informalfigure>
+</para>
+<programlisting>
+SELECT ST_AsText(ST_LineMerge(
+'MULTILINESTRING((60 30, 10 70), (120 50, 60 30), (120 50, 180 30))',
+TRUE));
+ MULTILINESTRING((120 50,60 30,10 70),(120 50,180 30))
+</programlisting>
 <para>Example showing Z-dimension handling.</para>
 <programlisting>
commit 9b0809bdbf3561b4263993dfb6a9e33931cdfc2b
Date:   Thu May 26 15:00:52 2022 +0300
    ST_LineMerge overload with "directed" argument.
    Closes #5161
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index d1a1e4974..54e0fa35b 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -2400,6 +2400,7 @@ LWGEOM *lwgeom_centroid(const LWGEOM* geom);
 LWGEOM *lwgeom_union(const LWGEOM *geom1, const LWGEOM *geom2);
 LWGEOM *lwgeom_union_prec(const LWGEOM *geom1, const LWGEOM *geom2, double gridSize);
 LWGEOM *lwgeom_linemerge(const LWGEOM *geom1);
+LWGEOM *lwgeom_linemerge_directed(const LWGEOM *geom1, int directed);
 LWGEOM *lwgeom_unaryunion(const LWGEOM *geom1);
 LWGEOM *lwgeom_unaryunion_prec(const LWGEOM *geom1, double gridSize);
 LWGEOM *lwgeom_clip_by_rect(const LWGEOM *geom1, double x0, double y0, double x1, double y1);
diff --git a/liblwgeom/lwgeom_geos.c b/liblwgeom/lwgeom_geos.c
index e3f321e04..d5f636dbf 100644
--- a/liblwgeom/lwgeom_geos.c
+++ b/liblwgeom/lwgeom_geos.c
@@ -749,6 +749,12 @@ lwgeom_intersection_prec(const LWGEOM* geom1, const LWGEOM* geom2, double prec)
 LWGEOM*
 lwgeom_linemerge(const LWGEOM* geom)
+	return lwgeom_linemerge_directed(geom, LW_FALSE);
+LWGEOM*
+lwgeom_linemerge_directed(const LWGEOM* geom, int directed)
 	LWGEOM* result;
 	int32_t srid = RESULT_SRID(geom);
@@ -765,7 +771,20 @@ lwgeom_linemerge(const LWGEOM* geom)
 	if (!(g1 = LWGEOM2GEOS(geom, AUTOFIX))) GEOS_FAIL();
-	g3 = GEOSLineMerge(g1);
+	if (directed)
+#if POSTGIS_GEOS_VERSION < 31100
+		lwerror("Directed line merging requires GEOS-3.11 or higher");
+		GEOS_FREE_AND_FAIL(g1);
+		return NULL;
+#else
+		g3 = GEOSLineMergeDirected(g1);
+#endif
+	else
+		g3 = GEOSLineMerge(g1);
 	if (!g3) GEOS_FREE_AND_FAIL(g1);
 	GEOSSetSRID(g3, srid);
diff --git a/postgis/lwgeom_geos.c b/postgis/lwgeom_geos.c
index 2b7a39105..82eb636af 100644
--- a/postgis/lwgeom_geos.c
+++ b/postgis/lwgeom_geos.c
@@ -3116,15 +3116,18 @@ PG_FUNCTION_INFO_V1(linemerge);
 Datum linemerge(PG_FUNCTION_ARGS)
 	GSERIALIZED *geom1;
+	bool directed = false;
 	GSERIALIZED *result;
 	LWGEOM *lwgeom1, *lwresult ;
 	geom1 = PG_GETARG_GSERIALIZED_P(0);
+	if ( PG_NARGS() > 1 )
+		directed = PG_GETARG_BOOL(1);
 	lwgeom1 = lwgeom_from_gserialized(geom1) ;
-	lwresult = lwgeom_linemerge(lwgeom1);
+	lwresult = lwgeom_linemerge_directed(lwgeom1, directed ? LW_TRUE : LW_FALSE);
 	result = geometry_serialize(lwresult) ;
 	lwgeom_free(lwgeom1) ;
index 05fb550b3..0a2e1faa1 100644
@@ -1872,6 +1872,17 @@ CREATE OR REPLACE FUNCTION ST_LineMerge(geometry)
 	_COST_HIGH;
+#if POSTGIS_GEOS_VERSION >= 31100
+-- Availability: 3.3.0
+CREATE OR REPLACE FUNCTION ST_LineMerge(geometry, boolean)
+	RETURNS geometry
+	AS 'MODULE_PATHNAME', 'linemerge'
+	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
+	_COST_HIGH;
+#endif
Summary of changes:
 NEWS                                  |  4 +++-
 doc/html/image_src/Makefile.in        |  1 +
 doc/html/image_src/st_linemerge03.wkt |  2 ++
 doc/html/image_src/styles.conf        | 12 ++++++++++++
 doc/reference_processing.xml          | 31 +++++++++++++++++++++++++++++++
 liblwgeom/liblwgeom.h.in              |  1 +
 liblwgeom/lwgeom_geos.c               | 21 ++++++++++++++++++++-
 postgis/lwgeom_geos.c                 |  5 ++++-
 postgis/postgis.sql.in                |  7 +++++++
 9 files changed, 81 insertions(+), 3 deletions(-)
 create mode 100644 doc/html/image_src/st_linemerge03.wkt
hooks/post-receive
