[postgis-tickets] [PostGIS] #5170: Make postgis raster copy rows configurable
PostGIS trac at osgeo.org
Sat Jun 11 05:58:17 PDT 2022
  Reporter:  robe         |      Owner:  robe
      Type:  enhancement  |     Status:  reopened
  Priority:  medium       |  Milestone:  PostGIS 3.3.0
 Component:  raster       |    Version:  master
Resolution:               |   Keywords:
Changes (by komzpa):
 * status:  closed => reopened
 * resolution:  fixed =>
Comment:
 echo 'COMMIT;' >> rtpostgis_upgrade.sql
 raster2pgsql.c: In function 'build_overview':
 raster2pgsql.c:1523:24: error: comparison of integer expressions of
 different signedness: 'uint32_t' {aka 'unsigned int'} and 'int' [-Werror
 =sign-compare]
  1523 |    if (tileset->length >= config->max_tiles_per_copy) {
 raster2pgsql.c: In function 'convert_raster':
 raster2pgsql.c:1850:25: error: comparison of integer expressions of
 =sign-compare]
  1850 |     if (tileset->length >= config->max_tiles_per_copy ) {
 raster2pgsql.c:1973:25: error: comparison of integer expressions of
 =sign-compare]
  1973 |     if (tileset->length >= config->max_tiles_per_copy ) {
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5170#comment:3>
