[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0alpha1-34-gec0ff3363
Mon Jun 13 09:09:37 PDT 2022
the project "PostGIS".
       via  ec0ff336342f5732fda5e2fc818c225969236dcf (commit)
      from  f45fd932eedb27273ca905b95f8c8bf121d0d91d (commit)
revisions in full, below.
commit ec0ff336342f5732fda5e2fc818c225969236dcf
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Jun 13 12:09:31 2022 -0400
    Document new -Z switch. Clarify use of -k.  References #5170
diff --git a/doc/using_raster_dataman.xml b/doc/using_raster_dataman.xml
index cfe9eaafd..8f6e18ce9 100644
--- a/doc/using_raster_dataman.xml
+++ b/doc/using_raster_dataman.xml
@@ -254,7 +254,8 @@
                   <term>-k</term>
                   <listitem>
                     <para>
-                        Skip NODATA value checks for each raster band.
+                        Keeps empty tiles and skips NODATA value checks for each raster band.
+                        Note you save time in checking, but could end up with far more junk rows in your database and those junk rows are not marked as empty tiles.
                     </para>
                   </listitem>
                 </varlistentry>
@@ -290,6 +291,14 @@
                   </listitem>
                 </varlistentry>
+                <varlistentry>
+                  <term>-Z <varname>max_rows_per_copy</varname></term>
+                  <listitem>
+                    <para>
+                      Specify max number of rows per copy statement. Only relevant when combined with -Y.</para>
+                  </listitem>
+                </varlistentry>
               </variablelist>
             </para>
           </listitem>
Summary of changes:
 doc/using_raster_dataman.xml | 11 ++++++++++-
 1 file changed, 10 insertions(+), 1 deletion(-)
hooks/post-receive
