[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0alpha1-49-gc31450b64
Tue Jun 14 15:46:45 PDT 2022
the project "PostGIS".
       via  c31450b6430f651817c2e15c7aba1454a58aa6f3 (commit)
       via  2de0f05bfb8939712e682d33faf7bca4df0e43fe (commit)
       via  c66b78eaea4d4f2eba3b79b64349577ffe8b6b1e (commit)
      from  b27234075727f27935d12de474618c5c55922225 (commit)
revisions in full, below.
commit c31450b6430f651817c2e15c7aba1454a58aa6f3
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Jun 14 18:46:34 2022 -0400
    Turn off upgrading on debbie.  Turn on on berrie64.  Minor cleanup of scripts
diff --git a/ci/berrie64/postgis_regress.sh b/ci/berrie64/postgis_regress.sh
index 5fddfac4d..f29c58752 100644
--- a/ci/berrie64/postgis_regress.sh
+++ b/ci/berrie64/postgis_regress.sh
@@ -21,12 +21,23 @@ make
 export err_status=0
 make check RUNTESTFLAGS="-v"
 make install
 make check RUNTESTFLAGS="-v --extension"
-err_status=$?
+if [ "$?" != "0" ]; then
+	err_status=$?
+fi
-#make garden
-#err_status=$?
+make garden
+	err_status=$?
+fi
+utils/check_all_upgrades.sh \
+    `grep '^POSTGIS_' Version.config | cut -d= -f2 | paste -sd '.'`
+ if [ "$?" != "0" ]; then
+   err_status=$?
+ fi
 if [ -d $PGDATA/postmaster.pid ] ; then
diff --git a/ci/debbie/postgis_regress.sh b/ci/debbie/postgis_regress.sh
index d21e2eafe..15191236e 100644
--- a/ci/debbie/postgis_regress.sh
+++ b/ci/debbie/postgis_regress.sh
@@ -118,8 +118,10 @@ fi
 # Test all available upgrades
 # TODO: protect via some variable ?
-utils/check_all_upgrades.sh \
+if [ "$MAKE_UPGRADE" = "1" ]; then
+ utils/check_all_upgrades.sh \
-if [ "$?" != "0" ]; then
   exit $?
+ fi
 fi
commit 2de0f05bfb8939712e682d33faf7bca4df0e43fe
Date:   Tue Jun 14 18:40:49 2022 -0400
    Allow upgrade of tiger structure. Put in notes.  References #5039 for PostGIS 3.3.0
diff --git a/NEWS b/NEWS
index 4a03f6cc7..046a24fcd 100644
--- a/NEWS
+++ b/NEWS
@@ -7,10 +7,11 @@ Changes since PostGIS 3.3.0alpha1
     control number of rows per copy statement (Regina Obe)
   - #4939, #5161, ST_LineMerge now has option to keep the directions of input linestrings,
     useful when processing road graphs. Requires GEOS 3.11. (Sergei Shoulbakov)
+  - #5039, postgis_tiger_geocoder TIGER 2021 (Regina Obe)
 * New features *
   - #5169, ST_SimplifyPolygonHull (requires GEOS 3.11)
-    (Paul Ramsey, Martin Davis)
+    (Paul Ramsey, Martin Davis)
 PostGIS 3.3.0alpha1
diff --git a/extensions/postgis_tiger_geocoder/Makefile.in b/extensions/postgis_tiger_geocoder/Makefile.in
index 83993845f..8df3730e4 100644
--- a/extensions/postgis_tiger_geocoder/Makefile.in
+++ b/extensions/postgis_tiger_geocoder/Makefile.in
@@ -194,9 +194,7 @@ sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: sql_bits/tiger_geocoder--unpack
 #they can be dropped but we need to remove
 #them from the extension first
 sql/tiger_geocoder_upgrade_minor.sql:  sql/tiger_geocoder_minor.sql.in | sql
-	sed -e '/^\(CREATE\|ALTER\) \(CAST\|TYPE\|TABLE\|SCHEMA\|DOMAIN\|TRIGGER\).*;/d' \
-	 	 -e '/^\(CREATE\|ALTER\) \(CAST\|TYPE\|TABLE\|SCHEMA\|DOMAIN\|TRIGGER\)/,/\;/d' \
-	 	 -e 's/BEGIN;//g' -e 's/COMMIT;//g' \
+	sed -e 's/BEGIN;//g' -e 's/COMMIT;//g' \
 EXTDIR=$(DESTDIR)$(datadir)/$(datamoduledir)
commit c66b78eaea4d4f2eba3b79b64349577ffe8b6b1e
Date:   Tue Jun 14 17:23:00 2022 -0400
    Change signature
diff --git a/extras/tiger_geocoder/utility/set_search_path.sql b/extras/tiger_geocoder/utility/set_search_path.sql
index 19d2f9523..f3eee2f18 100644
--- a/extras/tiger_geocoder/utility/set_search_path.sql
+++ b/extras/tiger_geocoder/utility/set_search_path.sql
@@ -5,7 +5,8 @@
 -- Adds a schema to  the front of search path so that functions, tables etc get installed by default in set schema
 -- but if people have postgis and other things installed in non-public, it will still keep those in path
 -- Example usage: SELECT tiger.SetSearchPathForInstall('tiger');
-CREATE OR REPLACE FUNCTION tiger.SetSearchPathForInstall(a_schema_name varchar)
+DROP FUNCTION IF EXISTS tiger.SetSearchPathForInstall(varchar);
+CREATE OR REPLACE FUNCTION tiger.SetSearchPathForInstall(a_schema_name text)
 RETURNS text
 AS
Summary of changes:
 NEWS                                              |  3 ++-
 ci/berrie64/postgis_regress.sh                    | 17 ++++++++++++++---
 ci/debbie/postgis_regress.sh                      |  6 ++++--
 extensions/postgis_tiger_geocoder/Makefile.in     |  4 +---
 extras/tiger_geocoder/utility/set_search_path.sql |  3 ++-
 5 files changed, 23 insertions(+), 10 deletions(-)
hooks/post-receive
