[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0alpha1-60-gc75326215
Wed Jun 15 12:56:24 PDT 2022
the project "PostGIS".
       via  c7532621527e72926dc23efe855e3bc1a00145a5 (commit)
      from  25b4d74a77ecb3e97ee4c892444c7d0d291c13fa (commit)
revisions in full, below.
commit c7532621527e72926dc23efe855e3bc1a00145a5
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Jun 15 12:56:03 2022 -0700
    ST_TriangulatePolygon for contrained polygon triangulation
    GEOS 3.11 only, "constrained polygon triangulation" outputs a set of triangles that exactly covers the input polygon.
diff --git a/NEWS b/NEWS
index 046a24fcd..f4a2690c9 100644
--- a/NEWS
+++ b/NEWS
@@ -53,6 +53,7 @@ Use below to enable it.
   - GH657, GiST: do not call no-op decompress function (Aliaksandr Kalenik)
   - #4912, GiST: fix crash on STORAGE EXTERNAL for geography (Aliaksandr Kalenik)
   - ST_ConcaveHull GEOS 3.11+ native implementation (Paul Ramsey, Martin Davis)
+  - ST_ConcaveHull GEOS 3.11+ polygon-respecting native implementation (Paul Ramsey, Martin Davis)
   - #4574, GH678, #5121 Enable Link-Time Optimizations using --enable-lto (Sergei Shoulbakov)
   - GH676, faster ST_Clip (Aliaksandr Kalenik)
   - #5135, Fast GiST index build is enabled by default for PostgreSQL 15+ (Sergei Shoulbakov)
@@ -66,6 +67,8 @@ Use below to enable it.
   - GH659, MARC21/XML, ST_GeomFromMARC21, ST_AsMARC21 (Jim Jones)
   - #5132, GH683, sfcgal: ST_3DUnion aggregate function (Sergei Shoulbakov)
   - #5143, SFCGAL ST_AlphaShape and ST_OptimalAlphaShape (Loïc Bartoletti)
+  - ST_TriangulatePolygon with GEOS 3.11+ (Paul Ramsey, Martin Davis)
+  - ST_SimplifyPolygonHull with GEOS 3.11+ (Paul Ramsey, Martin Davis)
  * Bug Fix *
    - #5100, Support for PostgreSQL 15 (atoi removal) (Laurenz Albe)
diff --git a/doc/html/image_src/Makefile.in b/doc/html/image_src/Makefile.in
index ae87cc694..75a57f388 100644
--- a/doc/html/image_src/Makefile.in
+++ b/doc/html/image_src/Makefile.in
@@ -143,6 +143,7 @@ IMAGES= \
 	../images/st_pointonsurface02.png \
 	../images/st_pointonsurface03.png \
 	../images/st_pointonsurface04.png \
+	../images/st_triangulatepolygon01.png \
 	../images/st_sharedpaths01.png \
 	../images/st_sharedpaths02.png \
 	../images/st_shortestline01.png \
diff --git a/doc/html/image_src/st_triangulatepolygon01.wkt b/doc/html/image_src/st_triangulatepolygon01.wkt
new file mode 100644
index 000000000..262bfc60d
--- /dev/null
+++ b/doc/html/image_src/st_triangulatepolygon01.wkt
@@ -0,0 +1,2 @@
+ArgA;GEOMETRYCOLLECTION(POLYGON((78 0,117 39,156 19.5,78 0)),POLYGON((156 19.5,195 39,195 0,156 19.5)),POLYGON((117 39,78 0,39 19.5,117 39)),POLYGON((39 19.5,0 0,0 39,39 19.5)),POLYGON((78 0,156 19.5,195 0,78 0)),POLYGON((117 39,39 19.5,0 39,117 39)))
+ArgB;POLYGON((0 0,0 39,117 39,156 19.5,195 39,195 0,78 0,39 19.5,0 0))
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index ea7c61bf9..9dcdc31b2 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -996,7 +996,7 @@ POLYGON((154 14,150 14,154 6,154 14))
 </informaltable>
       </refsection>
       <refsection>
-            <title>3D Examples</title>
+            <title>Example 1</title>
             <programlisting>-- 3D multipoint --
 SELECT ST_AsText(ST_DelaunayTriangles(ST_GeomFromText(
 'MULTIPOINT Z(14 14 10,
@@ -1006,13 +1006,71 @@ SELECT ST_AsText(ST_DelaunayTriangles(ST_GeomFromText(
 GEOMETRYCOLLECTION Z (POLYGON Z ((14 14 10,20 10 150,34 6 25,14 14 10))
  ,POLYGON Z ((14 14 10,34 6 25,150 14 100,14 14 10)))</programlisting>
         </refsection>
+    </refentry>
+    <refentry id="ST_TriangulatePolygon">
+      <refnamediv>
+        <refname>ST_TriangulatePolygon</refname>
+        <refpurpose>Computes the constrained Delaunay triangulation of polygons</refpurpose>
+      </refnamediv>
+      <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>geometry <function>ST_TriangulatePolygon</function></funcdef>
+            <paramdef><type>geometry</type> <parameter>geom</parameter></paramdef>
+          </funcprototype>
+        </funcsynopsis>
+      </refsynopsisdiv>
+      <refsection>
+        <title>Description</title>
+        <para>Computes the constrained Delaunay triangulation of polygons. The "constrained Delaunay triangulation" of a polygon is a set of triangles covering the polygon, with the maximum total interior angle over all possible triangulations.  It provides the "best quality" triangulation of the polygon.</para>
+        <para>Availability: 3.3.0</para>
+      </refsection>
+          <refsection>
+            <title>Example</title>
+            <para>A square is triangulated</para>
+                <programlisting>
+SELECT ST_AsText(
+    ST_TriangulatePolygon('POLYGON((0 0, 0 1, 1 1, 1 0, 0 0))'));
+                                 st_astext
+ GEOMETRYCOLLECTION(POLYGON((0 0,0 1,1 1,0 0)),POLYGON((1 1,1 0,0 0,1 1)))
+                </programlisting>
+          </refsection>
+      <refsection>
+            <programlisting>SELECT ST_AsText(ST_TriangulatePolygon(
+    'POLYGON((0 0, 0 1, 3 1, 4 0.5, 5 1, 5 0, 2 0, 1 0.5, 0 0))'
+</programlisting>
+            <informalfigure>
+            <mediaobject>
+            <imageobject>
+            <imagedata fileref="images/st_triangulatepolygon01.png" />
+            </imageobject>
+            <caption><para>Polygon Triangulation</para></caption>
+            </mediaobject>
+            </informalfigure>
+        </refsection>
         <refsection>
             <title>See Also</title>
-            <para><xref linkend="ST_ConstrainedDelaunayTriangles" />, <xref linkend="ST_ConcaveHull" />, <xref linkend="ST_Dump" />, <xref linkend="ST_Tesselate" />
+            <para><xref linkend="ST_ConstrainedDelaunayTriangles" />, <xref linkend="ST_ConcaveHull" />, <xref linkend="ST_Dump" />, <xref linkend="ST_Tesselate" />, <xref linkend="ST_TriangulatePolygon" />
             </para>
         </refsection>
+          <refsection>
+            <title>See Also</title>
+            <para><xref linkend="ST_DelaunayTriangles" />, <xref linkend="ST_ConstrainedDelaunayTriangles" />, <xref linkend="ST_Tesselate" /></para>
+          </refsection>
     </refentry>
     <refentry id="ST_FilterByM">
       <refnamediv>
         <refname>ST_FilterByM</refname>
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index 94f79ad72..7ffffa8a7 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -2525,6 +2525,7 @@ LWGEOM* lwgeom_node(const LWGEOM* lwgeom_in);
 LWGEOM* lwgeom_delaunay_triangulation(const LWGEOM *geom, double tolerance, int32_t edgeOnly);
  * Take vertices of a geometry and build the Voronoi diagram
@@ -2562,6 +2563,14 @@ LWGEOM* lwgeom_concavehull(const LWGEOM* geom, double ratio, uint32_t allow_hole
 LWGEOM*
 lwgeom_simplify_polygonal(const LWGEOM* geom, double vertex_fraction, uint32_t is_outer);
+ * Take vertices of a polygon and build a constrained triangulation
+ * that respects the boundary of the polygon.
+ * @param geom the input geometry
+LWGEOM* lwgeom_triangulate_polygon(const LWGEOM* geom);
 #endif
diff --git a/liblwgeom/lwgeom_geos.c b/liblwgeom/lwgeom_geos.c
index f52acf724..afdad095a 100644
--- a/liblwgeom/lwgeom_geos.c
+++ b/liblwgeom/lwgeom_geos.c
@@ -2015,6 +2015,7 @@ lwgeom_delaunay_triangulation(const LWGEOM* geom, double tolerance, int32_t outp
 	return result;
 static GEOSCoordSequence*
 lwgeom_get_geos_coordseq_2d(const LWGEOM* g, uint32_t num_points)
@@ -2172,4 +2173,31 @@ lwgeom_simplify_polygonal(const LWGEOM* geom, double vertex_fraction, uint32_t i
 	return result;
+LWGEOM*
+lwgeom_triangulate_polygon(const LWGEOM* geom)
+	LWGEOM* result;
+	int32_t srid = RESULT_SRID(geom);
+	uint8_t is3d = FLAGS_GET_Z(geom->flags);
+	GEOSGeometry *g1, *g3;
+	if (srid == SRID_INVALID) return NULL;
+	initGEOS(lwnotice, lwgeom_geos_error);
+	if (!(g1 = LWGEOM2GEOS(geom, AUTOFIX))) GEOS_FAIL();
+	/* if output != 1 we want polys */
+	g3 = GEOSConstrainedDelaunayTriangulation(g1);
+	if (!g3) GEOS_FREE_AND_FAIL(g1);
+	GEOSSetSRID(g3, srid);
+	if (!(result = GEOS2LWGEOM(g3, is3d)))
+		GEOS_FREE_AND_FAIL(g1, g3);
+	GEOS_FREE(g1, g3);
+	return result;
 #endif
diff --git a/postgis/lwgeom_geos.c b/postgis/lwgeom_geos.c
index a07b1a4e8..8919e20e5 100644
--- a/postgis/lwgeom_geos.c
+++ b/postgis/lwgeom_geos.c
@@ -3234,6 +3234,43 @@ Datum ST_DelaunayTriangles(PG_FUNCTION_ARGS)
 	PG_RETURN_POINTER(result);
+ * Take a polygon and build a constrained
+ * triangulation that respect the edges of the
+ * polygon.
+PG_FUNCTION_INFO_V1(ST_TriangulatePolygon);
+Datum ST_TriangulatePolygon(PG_FUNCTION_ARGS)
+#if POSTGIS_GEOS_VERSION < 31100
+	lwpgerror("The GEOS version this PostGIS binary "
+	          "was compiled against (%d) doesn't support "
+	          "'GEOSConstrainedDelaunayTriangulation' function (3.11.0+ required)",
+	          POSTGIS_GEOS_VERSION);
+	PG_RETURN_NULL();
+#else /* POSTGIS_GEOS_VERSION >= 31100 */
+	GSERIALIZED *result;
+	GSERIALIZED *geom = PG_GETARG_GSERIALIZED_P(0);
+	LWGEOM *lwgeom_in = lwgeom_from_gserialized(geom);
+	LWGEOM *lwgeom_out = lwgeom_triangulate_polygon(lwgeom_in);
+	lwgeom_free(lwgeom_in);
+	if (!lwgeom_out)
+		PG_FREE_IF_COPY(geom, 0);
+		PG_RETURN_NULL();
+	result = geometry_serialize(lwgeom_out);
+	lwgeom_free(lwgeom_out);
+	PG_RETURN_POINTER(result);
+#endif
  * ST_Snap
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 00035820f..5e1d202ff 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -3917,6 +3917,24 @@ CREATE OR REPLACE FUNCTION ST_DelaunayTriangles(g1 geometry, tolerance float8 DE
 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
 	_COST_HIGH;
+-- ST_TriangulatePolygon
+-- ST_TriangulatePolygon(g1 geometry)
+-- Builds a triangulation that respects the boundaries of the polygon.
+-- Returns a collection of triangular polygons.
+-- Availability: 3.3.0
+CREATE OR REPLACE FUNCTION ST_TriangulatePolygon(g1 geometry)
+	RETURNS geometry
+	AS 'MODULE_PATHNAME', 'ST_TriangulatePolygon'
+	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
+	_COST_HIGH;
 -- _ST_Voronoi
diff --git a/regress/core/geos311.sql b/regress/core/geos311.sql
index cce4ae686..6731ade0e 100644
--- a/regress/core/geos311.sql
+++ b/regress/core/geos311.sql
@@ -51,3 +51,20 @@ SELECT 'simplifypolygonhull-3' AS test,
 		'POLYGON((0 0, 0 1, 0.5 0.1, 0.5 0.1, 1 1, 1 0, 0 0))'::geometry,
 		0.85),1);
+-- ST_TriangulatePolygon --
+select 'triangulatepolygon-1' AS text,
+	ST_AsText(ST_Normalize(ST_TriangulatePolygon('POLYGON((0 0, 0 1, 1 1, 1 0, 0 0))')), 1);
+select 'triangulatepolygon-2' AS text,
+	ST_AsText(ST_Normalize(ST_TriangulatePolygon('MULTIPOLYGON(((0 0, 0 1, 1 1, 1 0, 0 0)))')), 1);
+select 'triangulatepolygon-3' AS text,
+	ST_AsText(ST_Normalize(ST_TriangulatePolygon('LINESTRING(0 0, 0 1, 1 1, 1 0, 0 0)')), 1);
+select 'triangulatepolygon-4' AS text,
+	ST_AsText(ST_Normalize(ST_TriangulatePolygon('POINT(1 0)')), 1);
+select 'triangulatepolygon-5' AS text,
+		'GEOMETRYCOLLECTION(POLYGON((0 0,0 1,1 1,0 0)),POLYGON((1 1,1 0,0 0,1 1)), POINT(1 1))'
+		)), 1);
diff --git a/regress/core/geos311_expected b/regress/core/geos311_expected
index 01d9fbbfc..1ef8e742e 100644
--- a/regress/core/geos311_expected
+++ b/regress/core/geos311_expected
@@ -5,3 +5,8 @@ concavehull02-points|t|ST_Polygon|t
 simplifypolygonhull-1|POLYGON((0 0,0 1,1 1,1 0,0 0))
 simplifypolygonhull-2|POLYGON((0 0,0 1,1 1,1 0,0 0))
 simplifypolygonhull-3|POLYGON((0 0,0 1,0.5 0.1,1 1,1 0,0 0))
+triangulatepolygon-1|GEOMETRYCOLLECTION(POLYGON((0 0,1 1,1 0,0 0)),POLYGON((0 0,0 1,1 1,0 0)))
+triangulatepolygon-2|GEOMETRYCOLLECTION(POLYGON((0 0,1 1,1 0,0 0)),POLYGON((0 0,0 1,1 1,0 0)))
+triangulatepolygon-3|GEOMETRYCOLLECTION EMPTY
+triangulatepolygon-4|GEOMETRYCOLLECTION EMPTY
+triangulatepolygon-5|GEOMETRYCOLLECTION(POLYGON((0 0,1 1,1 0,0 0)),POLYGON((0 0,0 1,1 1,0 0)))
Summary of changes:
 NEWS                                           |  3 ++
 doc/html/image_src/Makefile.in                 |  1 +
 doc/html/image_src/st_triangulatepolygon01.wkt |  2 +
 doc/reference_processing.xml                   | 62 +++++++++++++++++++++++++-
 liblwgeom/liblwgeom.h.in                       |  9 ++++
 liblwgeom/lwgeom_geos.c                        | 28 ++++++++++++
 postgis/lwgeom_geos.c                          | 37 +++++++++++++++
 postgis/postgis.sql.in                         | 18 ++++++++
 regress/core/geos311.sql                       | 17 +++++++
 regress/core/geos311_expected                  |  5 +++
 10 files changed, 180 insertions(+), 2 deletions(-)
 create mode 100644 doc/html/image_src/st_triangulatepolygon01.wkt
hooks/post-receive
