[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0alpha1-62-g08dcf2aa5
Wed Jun 15 15:36:51 PDT 2022
the project "PostGIS".
       via  08dcf2aa5f2e0bd9ee195183644d4c3ee8cad6c4 (commit)
      from  a8917e5f17035c3f6470a73767bf0d8d820d8451 (commit)
revisions in full, below.
commit 08dcf2aa5f2e0bd9ee195183644d4c3ee8cad6c4
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Jun 15 15:36:40 2022 -0700
    Add ST_DistanceSphere(geom, geom, radius) and
    ST_DistanceSpheroid(geom, geom) for a little
    more convenience and functionality.
diff --git a/doc/reference_measure.xml b/doc/reference_measure.xml
index 47d15b05a..2891504bd 100644
--- a/doc/reference_measure.xml
+++ b/doc/reference_measure.xml
@@ -673,7 +673,8 @@ SELECT ST_3DDistance(poly, mline) As dist3d,
 		  <funcprototype>
 			<funcdef>float <function>ST_DistanceSphere</function></funcdef>
 			<paramdef><type>geometry </type> <parameter>geomlonlatA</parameter></paramdef>
-			<paramdef><type>geometry </type> <parameter>geomlonlatB</parameter></paramdef>
+            <paramdef><type>geometry </type> <parameter>geomlonlatB</parameter></paramdef>
+            <paramdef choice="opt"><type>float8 </type> <parameter>radius=6371008</parameter></paramdef>
 		  </funcprototype>
 		</funcsynopsis>
 	  </refsynopsisdiv>
@@ -732,7 +733,7 @@ FROM
 			<funcdef>float <function>ST_DistanceSpheroid</function></funcdef>
-			<paramdef><type>spheroid </type> <parameter>measurement_spheroid</parameter></paramdef>
+			<paramdef choice="opt"><type>spheroid </type><parameter>measurement_spheroid=WGS84</parameter></paramdef>
 		  </funcprototype>
 		</funcsynopsis>
 	  </refsynopsisdiv>
diff --git a/postgis/lwgeom_spheroid.c b/postgis/lwgeom_spheroid.c
index fd96bc495..61631427b 100644
--- a/postgis/lwgeom_spheroid.c
+++ b/postgis/lwgeom_spheroid.c
@@ -531,17 +531,36 @@ Datum geometry_distance_spheroid(PG_FUNCTION_ARGS)
 PG_FUNCTION_INFO_V1(LWGEOM_distance_ellipsoid);
 Datum LWGEOM_distance_ellipsoid(PG_FUNCTION_ARGS)
+	SPHEROID s;
+	/* No spheroid provided */
+	if (PG_NARGS() == 2) {
+		/* Init to WGS84 */
+		spheroid_init(&s, 6378137.0, 6356752.314245179498);
+		PG_RETURN_DATUM(DirectFunctionCall4(geometry_distance_spheroid,
+			PG_GETARG_DATUM(0),
+			PG_GETARG_DATUM(1),
+			PointerGetDatum(&s),
+			BoolGetDatum(true)));
-	                                    PG_GETARG_DATUM(0), PG_GETARG_DATUM(1), PG_GETARG_DATUM(2), BoolGetDatum(true)));
+		PG_GETARG_DATUM(2),
 PG_FUNCTION_INFO_V1(LWGEOM_distance_sphere);
 Datum LWGEOM_distance_sphere(PG_FUNCTION_ARGS)
 	SPHEROID s;
 	/* Init to WGS84 */
+	if (PG_NARGS() == 3) {
+		s.radius = PG_GETARG_FLOAT8(2);
 	s.a = s.b = s.radius;
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 5e1d202ff..49cfcdbdd 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -1345,11 +1345,18 @@ CREATE OR REPLACE FUNCTION ST_IsPolygonCCW(geometry)
 	_COST_LOW;
 -- Availability: 2.0.0
-CREATE OR REPLACE FUNCTION ST_DistanceSpheroid(geom1 geometry, geom2 geometry,spheroid)
+CREATE OR REPLACE FUNCTION ST_DistanceSpheroid(geom1 geometry, geom2 geometry, spheroid)
 	RETURNS FLOAT8
 	AS 'MODULE_PATHNAME','LWGEOM_distance_ellipsoid'
 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
-	_COST_MEDIUM; --upped this
+	_COST_MEDIUM;
+-- Availability: 3.3.0
+CREATE OR REPLACE FUNCTION ST_DistanceSpheroid(geom1 geometry, geom2 geometry)
+	RETURNS FLOAT8
+	AS 'MODULE_PATHNAME','LWGEOM_distance_ellipsoid'
+	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
+	_COST_MEDIUM;
 -- Minimum distance. 2D only.
 CREATE OR REPLACE FUNCTION ST_Distance(geom1 geometry, geom2 geometry)
@@ -6056,6 +6063,13 @@ CREATE OR REPLACE FUNCTION ST_DistanceSphere(geom1 geometry, geom2 geometry)
 	'select @extschema at .ST_distance( @extschema at .geography($1), @extschema at .geography($2),false)'
 	LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE;
+CREATE OR REPLACE FUNCTION ST_DistanceSphere(geom1 geometry, geom2 geometry, radius float8)
+	RETURNS FLOAT8
+	AS 'MODULE_PATHNAME','LWGEOM_distance_sphere'
+ 	_COST_HIGH;
 -- GEOMETRY_COLUMNS view support functions
Summary of changes:
 doc/reference_measure.xml |  5 +++--
 postgis/lwgeom_spheroid.c | 23 +++++++++++++++++++++--
 postgis/postgis.sql.in    | 18 ++++++++++++++++--
 3 files changed, 40 insertions(+), 6 deletions(-)
hooks/post-receive
