[postgis-tickets] [PostGIS] #5171: SELECT st_length(st_geomfromtext gives error when running on ARM processor when points input are the same
PostGIS trac at osgeo.org
Wed Jun 15 18:59:04 PDT 2022
  Reporter:  arnghosb  |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  high      |  Milestone:  PostGIS 3.2.2
 Component:  postgis   |    Version:  3.2.x
Resolution:            |   Keywords:
Comment (by robe):
 Okay I was able to replicate the issue on my Amazon RDS instance
 That is running:
 POSTGIS="3.1.5 0" [EXTENSION] PGSQL="130" GEOS="3.9.1dev-CAPI-1.14.1"
 PROJ="6.2.1" GDAL="GDAL 2.3.1, released 2018/06/22" LIBXML="2.9.9"
 LIBJSON="0.12.99" LIBPROTOBUF="1.3.0" WAGYU="0.5.0 (Internal)" TOPOLOGY
 RASTER PostgreSQL 13.6 on aarch64-unknown-linux-gnu, compiled by aarch64
 -unknown-linux-gnu-gcc (GCC) 7.4.0, 64-bit
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5171#comment:3>
