[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0alpha1-78-g09d0f62d2
Thu Jun 16 14:02:31 PDT 2022
the project "PostGIS".
       via  09d0f62d29bf23a0eab9741bf60e1e5b84da73ff (commit)
       via  75e4d91e53000480729b301d706f722342fd505f (commit)
      from  2316ccccf74aa3dd4f7a7e8a21f818f3001a074f (commit)
revisions in full, below.
commit 09d0f62d29bf23a0eab9741bf60e1e5b84da73ff
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Jun 16 17:02:25 2022 -0400
    Put back raster regress/Makefile.in but take out the redundant bits
diff --git a/configure.ac b/configure.ac
index 86feb8c47..695077429 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1537,6 +1537,7 @@ if test "x$with_raster" != "xno"; then
 		raster/loader/Makefile \
 		raster/test/Makefile \
 		raster/test/cunit/Makefile \
+		raster/test/regress/Makefile \
 		raster/scripts/Makefile \
 		raster/scripts/python/Makefile"
diff --git a/raster/test/regress/Makefile.in b/raster/test/regress/Makefile.in
new file mode 100644
index 000000000..5232d425e
--- /dev/null
+++ b/raster/test/regress/Makefile.in
@@ -0,0 +1,68 @@
+# Copyright (c) 2009-2022 Sandro Santilli <strk at kbt.io>
+# Copyright (c) 2009 Pierre Racine <pierre.racine at sbf.ulaval.ca>
+# Copyright (c) 2011 Jorge Arevalo <jorge.arevalo at deimos-space.com>
+# Copyright (c) 2011-2013 Regents of the University of California
+#   <bkpark at ucdavis.edu>
+# This is free software; you can redistribute and/or modify it under
+# the terms of the GNU General Public Licence. See the COPYING file.
+# This program is free software; you can redistribute it and/or
+# modify it under the terms of the GNU General Public License
+# as published by the Free Software Foundation; either version 2
+# of the License, or (at your option) any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software Foundation,
+# Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
+top_srcdir = @top_srcdir@
+srcdir = @srcdir@
+top_builddir = @top_builddir@
+POSTGIS_SRC=../../..
+PERL=@PERL@
+# MingW hack: rather than use PGSQL_BINDIR directly, we change
+# to the directory and then use "pwd" to return the path. This
+# ensures that the returned path is in MSYS format, otherwise
+# colons in drive letters will break PATH.
+PGSQL_BINDIR=$(shell cd "@PGSQL_BINDIR@" && pwd)
+# Where we put our regression installation
+REGRESS_INSTALLDIR = $(realpath $(top_builddir) )/regress/00-regress-install
+# Put path from pg_config into front of search path
+PATH := $(PGSQL_BINDIR):$(PATH)
+export PATH
+all:
+	@echo "Use 'make check' to run all tests"
+distclean: clean
+	rm -f Makefile
+clean:
+	$(RM) -f rtpostgis.sql
+rtpostgis.sql: ../../rt_pg/rtpostgis.sql
+	$(PERL) -lpe "s'\\\$$libdir'$(REGRESS_INSTALLDIR)/lib'g" $< > $@
+# TODO: drop this variable, use top_srcdir directly
+topsrcdir = $(top_srcdir)
+include $(srcdir)/tests.mk
+include $(top_srcdir)/regress/runtest.mk
+check: check-regress
commit 75e4d91e53000480729b301d706f722342fd505f
Date:   Thu Jun 16 15:54:15 2022 -0400
    Put back mingw64 testing
diff --git a/.github/workflows/msys.yml b/.github/workflows/msys.yml
index 000000000..23555e7df
--- /dev/null
+++ b/.github/workflows/msys.yml
@@ -0,0 +1,53 @@
+name: MSYS2
+on: [push, pull_request]
+jobs:
+  mingw:
+    name: mingw
+    runs-on: windows-latest
+    strategy:
+      matrix:
+        #fail-fast: false
+        include:
+          # mingw32 fail: addface
+          - { icon: '🟦', sys: mingw64 }
+          - { icon: '🟨', sys: ucrt64  } # Experimental!
+          - { icon: '🟧', sys: clang64 } # Experimental!
+    defaults:
+      run:
+        shell: msys2 {0}
+    steps:
+      # see https://github.com/msys2/setup-msys2
+    - name: checkout
+      uses: actions/checkout at v2
+    - name: '${{ matrix.icon }} Setup MSYS2'
+      uses: msys2/setup-msys2 at v2
+      with:
+        msystem: ${{ matrix.sys }}
+        update: true
+        install: >-
+          git
+          make
+          bison
+        pacboy: >-
+          toolchain:p
+          autotools:p
+          geos:p
+          proj:p
+          gdal:p
+          sfcgal:p
+          json-c:p
+          gettext:p
+          libxml2:p
+          postgresql:p
+    - name: '🚧 Build TOOL'
+      run: |
+        MSYSTEM= /${{ matrix.sys }}/bin/initdb -D D:/a/_tmp/psql
+        MSYSTEM= /${{ matrix.sys }}/bin/pg_ctl -D D:/a/_tmp/psql -l logfile start
+        MSYSTEM= /${{ matrix.sys }}/bin/pg_ctl register -N "postgresql" -U "NT AUTHORITY\NetworkService" -D D:/a/_tmp/psql -w -S demand
+        MSYSTEM= /${{ matrix.sys }}/bin/createuser -U `whoami` -s postgres
+        MSYSTEM= ./autogen.sh
+        MSYSTEM= ./configure --with-pgconfig=/${{ matrix.sys }}/bin/pg_config --without-protobuf
+        MSYSTEM= make
+        MSYSTEM= make check
Summary of changes:
 .github/workflows/msys.yml      | 53 ++++++++++++++++++++++++++++++++
 configure.ac                    |  1 +
 raster/test/regress/Makefile.in | 68 +++++++++++++++++++++++++++++++++++++++++
 3 files changed, 122 insertions(+)
 create mode 100644 .github/workflows/msys.yml
 create mode 100644 raster/test/regress/Makefile.in
hooks/post-receive
