[postgis-tickets] [SCM] PostGIS branch stable-3.2 updated. 3.2.1-29-g5d23c8ac6
Mon Jun 20 10:57:36 PDT 2022
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  5d23c8ac6a196941ee299a37df19dc37cdde48bb (commit)
       via  18c0a23a1368491d39ad1d0f7a37ea21dfad737e (commit)
      from  92f94fe1c24b17ccf593fd670bd6d4b5817953ba (commit)
revisions in full, below.
commit 5d23c8ac6a196941ee299a37df19dc37cdde48bb
Merge: 18c0a23a1 92f94fe1c
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Jun 20 10:57:26 2022 -0700
    Error out when asked to build flatgeobuf on table with no geometry (references #5173)
diff --cc NEWS
index 3520cdef3,8072de9a3..b2029aefd
--- a/NEWS
+++ b/NEWS
@@@ -2,7 -2,7 +2,6 @@@ PostGIS 3.2.2de
  2022/MM/DD
  * Bug Fixes *
--  - #5152, Fix infinite loop with ST_Split (Sandro Santilli)
    - #5124, GRANT USAGE on topology schema to PUBLIC (Sandro Santilli)
    - #5120, Fix not-null result from ST_EstimatedExtent against
             truncated tables with spatial index (Sandro Santilli)
@@@ -10,16 -10,16 +9,18 @@@
             (Sandro Santilli)
    - #5105, Fix false invalidity report from ValidateTopology
             (Sandro Santilli)
++  - #5039, postgis_tiger_geocoder: Support for TIGER 2021 (Regina Obe)
    - #5097, Ensure spatial index is used during topology population
             at the getClosestEdge step (Sandro Santilli)
    - #5091, Fix --without-protobuf builds (Tobias Bussmann)
    - #5100, Don't use pg_atoi (removed in PG15) (Laurenz Albe)
++  - #5114, Crash with long column names pgsql2shp (Paul Ramsey)
    - #5123, Support for PG15 (JSON funcs exposed) (Regina Obe)
--  - #5151, ST_SetPoint with empty geometries (Regina Obe)
--  - #5150, Change signature of AddToSearchPath (Regina Obe)
    - #5125, Fix search path function (Sandro Santilli)
--  - #5114, Crash with long column names pgsql2shp (Paul Ramsey)
 -  - #5039, postgis_tiger_geocoder: Support for TIGER 2021 (Regina Obe)
++  - #5150, Change signature of AddToSearchPath (Regina Obe)
++  - #5151, ST_SetPoint with empty geometries (Regina Obe)
++  - #5152, Fix infinite loop with ST_Split (Sandro Santilli)
 +  - #5173, Crash creating flatgeobuf on row without geometry (Julien Rouhaud)
  PostGIS 3.2.1
commit 18c0a23a1368491d39ad1d0f7a37ea21dfad737e
Date:   Mon Jun 20 10:55:53 2022 -0700
diff --git a/NEWS b/NEWS
index 4769fe96f..3520cdef3 100644
--- a/NEWS
+++ b/NEWS
@@ -19,6 +19,7 @@ PostGIS 3.2.2dev
 PostGIS 3.2.1
diff --git a/postgis/flatgeobuf.c b/postgis/flatgeobuf.c
index 1b502e546..545442f31 100644
--- a/postgis/flatgeobuf.c
+++ b/postgis/flatgeobuf.c
@@ -110,6 +110,9 @@ static void inspect_table(struct flatgeobuf_agg_ctx *ctx)
 		columns_size++;
+	if (!geom_found)
+		elog(ERROR, "no geom column found");
 	if (columns_size > 0) {
 		ctx->ctx->columns = columns;
 		ctx->ctx->columns_size = columns_size;
Summary of changes:
 NEWS                 | 11 ++++++-----
 postgis/flatgeobuf.c |  3 +++
 2 files changed, 9 insertions(+), 5 deletions(-)
hooks/post-receive
