[postgis-tickets] [PostGIS] #5172: GHA ci main/main is failing
PostGIS trac at osgeo.org
Fri Jun 24 18:13:58 PDT 2022
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.3.0
 Component:  raster   |    Version:  master
Resolution:           |   Keywords:
Comment (by robe):
 I forgot I do build gdal master on debbie.  I tested with master on debbie
 and no issue.  The GHA docker image is still building, I'll trigger a run
 after it is done building.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5172#comment:3>
