[postgis-tickets] [PostGIS] #5172: GHA ci main/main is failing
PostGIS trac at osgeo.org
Sat Jun 25 22:32:29 PDT 2022
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.3.0
 Component:  raster   |    Version:  master
Resolution:           |   Keywords:
Comment (by robe):
 I think the culprit is PROJ 9.1.
 I swapped out the latest (which had GDAL 3.6, PROJ 9.1, PostgreSQL 15,
 GEOS 3.11)  and replaced with  GDAL 3.6, PROJ 9.0, PostgreSQL 15, GEOS
 3.11, and there is no error.
 https://github.com/postgis/postgis/runs/7058314172?check_suite_focus=true
  PostgreSQL 15beta1 on x86_64-pc-linux-gnu, compiled by gcc (Debian
 10.2.1-6) 10.2.1 20210110, 64-bit
   Postgis 3.3.0dev - (0bc5aa5) - 2022-06-26 04:15:30
   scripts 3.3.0dev 0bc5aa5
   raster scripts 3.3.0dev 0bc5aa5
   GEOS: 3.11.0beta3-CAPI-1.16.0
   PROJ: 9.0.1
   SFCGAL: 1.4.1
   GDAL: GDAL 3.6.0dev-125fafc, released 2022/06/25
 as opposed to the latest, which crashes on the gdal driver test
   Postgis 3.3.0dev - (76a92a5) - 2022-06-24 19:04:03
   scripts 3.3.0dev 76a92a5
   raster scripts 3.3.0dev 76a92a5
   GEOS: 3.11.0beta2-CAPI-1.16.0
   PROJ: 9.1.0
   SFCGAL: 1.4.1
   GDAL: GDAL 3.6.0dev-c5ffcd7, released 2022/06/19
 Although I suppose it still could be GDAL since it looks like perhaps GHA
 has the docker latest cached, since last run is till not the latest  build
 of GDAL
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5172#comment:5>
