[postgis-tickets] [PostGIS] #5172: GHA ci main/main is failing
PostGIS trac at osgeo.org
Sun Jun 26 11:15:25 PDT 2022
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 3.3.0
 Component:  raster   |    Version:  master
Resolution:  fixed    |   Keywords:
Comment (by robe):
 Okay it looks like the latest is working now.  So wasn't PROJ either.
 Must have been a fix in GDAL between 6/19 and 6/23 and the last postgis
 build with latest was on 6/23 so must have just missed the latest publish
 by a hair  because this one:
 https://github.com/postgis/postgis/runs/7062500186?check_suite_focus=true
 PostgreSQL 15beta1 on x86_64-pc-linux-gnu, compiled by gcc (Debian
 10.2.1-6) 10.2.1 20210110, 64-bit
   Postgis 3.3.0dev - (5bcf72d) - 2022-06-26 18:08:58
   scripts 3.3.0dev 5bcf72d
   raster scripts 3.3.0dev 5bcf72d
   GEOS: 3.11.0beta3-CAPI-1.16.0
   PROJ: 9.1.0
   SFCGAL: 1.4.1
   GDAL: GDAL 3.6.0dev-2d29343, released 2022/06/24
 Ran successfully
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5172#comment:7>
