[postgis-tickets] [PostGIS] #5175: <> and != on geometry yield operator is not unique
PostGIS trac at osgeo.org
Mon Jun 27 16:58:52 PDT 2022
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.2.2
 Component:  postgis  |    Version:  3.2.x
Resolution:           |   Keywords:
Description changed by robe:
Old description:
> Reported on IRC someone trying to create a trigger with construct:
>  (NEW.geom != OLD.geom)
> yielded != is not unique for geometry.
> had to resort to
>  (NEW.geom::text != OLD.geom::text)
> I verified it is an issue with
> SELECT ST_Point(1,2) != ST_Point(3,4);
> SELECT ST_Point(1,2) <> ST_Point(3,4);
> However this works fine:
> SELECT ST_Point(1,2)::geography != ST_Point(3,4)::geography;
> SELECT ST_Point(1,2)::geography <> ST_Point(3,4)::geography;
> I haven't verified where the extra operator indirection is coming from
> that is not effecting geography as well.
New description:
 had to resort to
 Note that:
 SELECT ST_Point(1,2) = ST_Point(3,4);
 SELECT NOT (ST_Point(1,2) = ST_Point(3,4)) ;
 work without error
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5175#comment:1>
