[postgis-tickets] [PostGIS] #5177: Can't build commandline tools only and --without-pgconfig seems broken
PostGIS trac at osgeo.org
Thu Jun 30 07:01:25 PDT 2022
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.3.0
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Description changed by robe:
Old description:
> I thought we had solved this problem already, but it seems not.
> I tried building the command-line tools on a CentOS, thinking I could do
> it with.
> export PKG_CONFIG_PATH="/projects/rel/lib/pkgconfig"
> export
> PATH="/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/projects/rel/lib:/projects/rel/bin:/projects/rel/include"
> ./configure --prefix=/projects/rel --without-protobuf \
>   --with-geosconfig=/projects/rel/bin/geos-config \
>   --without-pgconfig --without-protobuf \
>   --with-libiconv=/projects/rel
> What happens with the above, even though I have GDAL installed in
> /projects/rel
> I still get error:
> configure: WARNING: gdal.h: present but cannot be compiled
> configure: WARNING: gdal.h:     check for missing prerequisite headers?
> configure: WARNING: gdal.h: see the Autoconf documentation
> configure: WARNING: gdal.h:     section "Present But Cannot Be Compiled"
> configure: WARNING: gdal.h: proceeding with the compiler's result
> checking for gdal.h... no
> configure: error: could not find GDAL headers
> If I do
> If I do,
> export
>   --with-libiconv=/projects/rel \
>   --without-raster
> Then configure succeeds, and even make completes with:
> /usr/bin/ar: creating .libs/liblwgeom.a
> libtool: link: gcc-ranlib .libs/liblwgeom.a
> libtool: link: rm -fr .libs/liblwgeom.lax
> libtool: link: ( cd ".libs" && rm -f "liblwgeom.la" && ln -s
> "../liblwgeom.la" "liblwgeom.la" )
> but make install just outputs
>  make install
> for s in liblwgeom; do \
>         echo "---- Making install in ${s}"; \
>         make -C ${s} install || exit 1; \
> done;
> I would have assumed the shp2pgsql, pgsql2shp would get installed in the
> --prefix folder, but no nothing.  Even building with below the --prefix
> is ignored and all by commandline tools end up in /projects/rel/pg14/bin
> export
> export PGPATH=/projects/rel/pg14
> ./configure --prefix=/projects/rel --without-protobuf --with-
> pgconfig=${PGPATH}/bin/pg_config \
> make && make install
> What I am expecting, is that since shp2pgsql and raster2pgsql do not have
> ANY dependency on PostgreSQL or libpq for that matter, I should be able
> to get those built with below and they should be installed in
> --prefix=/projects/rel/bin
>   --without-raster
> I thought this used to work, but perhaps was broken after our numerous
> changes to liblwgeom config
> I'm going to try older versions to see
New description:
 it with.
 export
 ./configure --prefix=/projects/rel \
 /projects/rel
 I still get error:
 If I do
 If I do,
 export
   --without-raster
  make install
 done;
 --prefix folder, but no nothing.  Even building with below the --prefix is
 export
 ANY dependency on PostgreSQL or libpq for that matter, I should be able to
   --without-raster
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5177#comment:2>
