[postgis-tickets] [PostGIS] #5109: Topology documentation uses unexplained concepts
PostGIS trac at osgeo.org
Thu Mar 3 04:32:36 PST 2022
  Reporter:  asgerpetersen  |      Owner:  robe
      Type:  enhancement    |     Status:  new
  Priority:  medium         |  Milestone:  PostGIS 3.3.0
 Component:  documentation  |    Version:  3.2.x
Resolution:                 |   Keywords:
Comment (by strk):
 We probably want to add a chapter about the "topology schema".
 Closest to an explanation is the slide deck
 http://strk.kbt.io/projects/postgis/Paris2011_TopologyWithPostGIS_2_0.pdf
 which is linked from https://postgis.net/docs/Topology.html
 If you want to help improving the manual you can send a pull request with
 edits to this file:
 https://git.osgeo.org/gitea/postgis/postgis/src/branch/master/doc/extras_topology.xml
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5109#comment:1>
