[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-626-gc273f3943
Fri Mar 4 03:12:48 PST 2022
the project "PostGIS".
       via  c273f3943df45ef06907be12282c20caea6784c2 (commit)
      from  2fe49a4b5c7441bee2c2e987e93d0521de51957e (commit)
revisions in full, below.
commit c273f3943df45ef06907be12282c20caea6784c2
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Mar 3 20:38:06 2022 +0100
    Speed up face MBR computation during topology editing
    Closes #5111
    Update test for #4706 as we won't throw an exception now,
    from ST_ChangeEdgeGeom, on invalid topology
diff --git a/liblwgeom/liblwgeom_topo.h b/liblwgeom/liblwgeom_topo.h
index c49ba0bda..276d9d7cf 100644
--- a/liblwgeom/liblwgeom_topo.h
+++ b/liblwgeom/liblwgeom_topo.h
@@ -853,6 +853,17 @@ typedef struct LWT_BE_CALLBACKS_T {
 					   uint64_t *numelems,
 					   int fields);
+   * Compute minimum bounding rectangle of a face
+   * @param topo the topology to act upon
+   * @param face the face identifier
+   * @return a GBOX describing the minimum bounding rectangle of the face.
+  GBOX *(*computeFaceMBR)(const LWT_BE_TOPOLOGY *topo, LWT_ELEMID face);
 } LWT_BE_CALLBACKS;
diff --git a/liblwgeom/lwgeom_topo.c b/liblwgeom/lwgeom_topo.c
index 97e0515eb..479a65386 100644
--- a/liblwgeom/lwgeom_topo.c
+++ b/liblwgeom/lwgeom_topo.c
@@ -412,6 +412,12 @@ lwt_be_getClosestEdge(const LWT_TOPOLOGY *topo, const LWPOINT *pt, uint64_t *num
   CBT3(topo, getClosestEdge, pt, numelems, fields);
+static GBOX *
+lwt_be_computeFaceMBR(const LWT_TOPOLOGY *topo, LWT_ELEMID face)
+  CBT1(topo, computeFaceMBR, face);
  * Utility functions
@@ -2043,7 +2049,7 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
 	  lwerror("Backend error: %s", lwt_be_lastErrorMessage(topo->be_iface));
 	  return -2;
-  LWDEBUGF(1, "lwt_be_getEdgeByFace returned %d edges", numfaceedges);
+  LWDEBUGF(1, "_lwt_AddFaceSplit: lwt_be_getEdgeByFace returned %d edges", numfaceedges);
   if ( numfaceedges )
@@ -2831,6 +2837,7 @@ lwt_GetFaceGeometry(LWT_TOPOLOGY* topo, LWT_ELEMID faceid)
 	  return NULL;
+  LWDEBUGF(1, "lwt_GetFaceGeometry: lwt_be_getEdgeByFace returned %d edges", numfaceedges);
   if ( numfaceedges == 0 )
@@ -3078,6 +3085,7 @@ lwt_GetFaceEdges(LWT_TOPOLOGY* topo, LWT_ELEMID face_id, LWT_ELEMID **out )
 	  return -1;
   if ( ! numfaceedges ) return 0; /* no edges in output */
+  LWDEBUGF(1, "lwt_GetFaceEdges: lwt_be_getEdgeByFace returned %d edges", numfaceedges);
   /* order edges by occurrence in face */
@@ -3480,89 +3488,53 @@ lwt_ChangeEdgeGeom(LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, LWLINE *geom)
   const GBOX* newbox = lwgeom_get_bbox(lwline_as_lwgeom(geom));
   if ( ! gbox_same(oldbox, newbox) )
+    GBOX* updatedBox;
     uint64_t facestoupdate = 0;
     LWT_ISO_FACE faces[2];
-    LWGEOM *nface1 = NULL;
-    LWGEOM *nface2 = NULL;
     if ( oldedge->face_left > 0 )
-      nface1 = lwt_GetFaceGeometry(topo, oldedge->face_left);
-      if ( ! nface1 )
-        lwerror("lwt_ChangeEdgeGeom could not construct face %"
-                   LWTFMT_ELEMID ", on the left of edge %" LWTFMT_ELEMID,
-                  oldedge->face_left, edge_id);
-        return -1;
-  #if 0
-      size_t sz;
-      char *wkt = lwgeom_to_wkt(nface1, WKT_EXTENDED, 2, &sz);
-      LWDEBUGF(1, "new geometry of face left (%d): %s", (int)oldedge->face_left, wkt);
-      lwfree(wkt);
-  #endif
-      lwgeom_add_bbox(nface1);
-      if ( ! nface1->bbox )
+      updatedBox = lwt_be_computeFaceMBR(topo, oldedge->face_left);
+      if ( ! updatedBox )
         lwerror("Corrupted topology: face %d, left of edge %d, has no bbox",
         return -1;
       faces[facestoupdate].face_id = oldedge->face_left;
-      /* ownership left to nface */
-      faces[facestoupdate++].mbr = nface1->bbox;
+      /* ownership transferred to faces[] */
+      faces[facestoupdate++].mbr = updatedBox;
     if ( oldedge->face_right > 0
          /* no need to update twice the same face.. */
          && oldedge->face_right != oldedge->face_left )
-      nface2 = lwt_GetFaceGeometry(topo, oldedge->face_right);
-      if ( ! nface2 )
-                   LWTFMT_ELEMID ", on the right of edge %" LWTFMT_ELEMID,
-                  oldedge->face_right, edge_id);
-        return -1;
-  #if 0
-      size_t sz;
-      char *wkt = lwgeom_to_wkt(nface2, WKT_EXTENDED, 2, &sz);
-      LWDEBUGF(1, "new geometry of face right (%d): %s", (int)oldedge->face_right, wkt);
-      lwfree(wkt);
-  #endif
-      lwgeom_add_bbox(nface2);
-      if ( ! nface2->bbox )
+      updatedBox = lwt_be_computeFaceMBR(topo, oldedge->face_right);
         lwerror("Corrupted topology: face %d, right of edge %d, has no bbox",
         return -1;
       faces[facestoupdate].face_id = oldedge->face_right;
-      faces[facestoupdate++].mbr = nface2->bbox; /* ownership left to nface */
     LWDEBUGF(1, "%d faces to update", facestoupdate);
     if ( facestoupdate )
-		uint64_t updatedFaces = lwt_be_updateFacesById(topo, &(faces[0]), facestoupdate);
+      uint64_t updatedFaces = lwt_be_updateFacesById(topo, &(faces[0]), facestoupdate);
 	    if (updatedFaces != facestoupdate)
-		    if (nface1)
-			    lwgeom_free(nface1);
-		    if (nface2)
-			    lwgeom_free(nface2);
+        while ( facestoupdate-- ) lwfree(faces[facestoupdate].mbr);
 		    _lwt_release_edges(oldedge, 1);
 		    if (updatedFaces == UINT64_MAX)
 		    else
-			    lwerror("Unexpected error: %d faces found when expecting 1", i);
+			    lwerror("Unexpected error: %d faces updated when expecting 1", updatedFaces);
 		    return -1;
-    if ( nface1 ) lwgeom_free(nface1);
-    if ( nface2 ) lwgeom_free(nface2);
   else
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index dd799e56a..f67af1be7 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -3046,6 +3046,100 @@ cb_getClosestEdge( const LWT_BE_TOPOLOGY* topo, const LWPOINT* pt, uint64_t *num
   return edges;
+static GBOX *
+cb_computeFaceMBR(const LWT_BE_TOPOLOGY *topo, LWT_ELEMID face)
+  //LWT_ELEMID *edges;
+  int spi_result;
+  HeapTuple row;
+  //TupleDesc rowdesc;
+  bool isnull;
+  Datum dat;
+  GSERIALIZED *geom;
+  LWGEOM *lwg;
+  StringInfoData sqldata;
+  StringInfo sql = &sqldata;
+  const GBOX *box;
+  MemoryContext oldcontext = CurrentMemoryContext;
+  initStringInfo(sql);
+  appendStringInfo(
+    sql,
+    "SELECT ST_BoundingDiagonal(ST_Collect("
+    "ST_BoundingDiagonal(geom, true)"
+    "), true) FROM \"%s\".edge "
+    "WHERE left_face != right_face AND "
+    "( left_face = %" LWTFMT_ELEMID
+    " OR right_face = %" LWTFMT_ELEMID
+    topo->name,
+    face,
+    face
+  POSTGIS_DEBUGF(1, "cb_computeFaceMBR query: %s", sql->data);
+  spi_result = SPI_execute(sql->data, !topo->be_data->data_changed, 0);
+  MemoryContextSwitchTo( oldcontext ); /* switch back */
+  if ( spi_result != SPI_OK_SELECT )
+    cberror(topo->be_data, "unexpected return (%d) from query execution: %s", spi_result, sql->data);
+    pfree(sqldata.data);
+    return NULL;
+  if ( ! SPI_processed )
+    cberror(
+      topo->be_data,
+      "Face with id %" LWTFMT_ELEMID" in topology \"%s\" has no edges",
+      face,
+      topo->name
+    return NULL;
+  row = SPI_tuptable->vals[0];
+  dat = SPI_getbinval(row, SPI_tuptable->tupdesc, 1, &isnull);
+  if ( isnull )
+    cberror(
+      topo->be_data,
+      "Face with id %" LWTFMT_ELEMID" in topology \"%s\" has null edges ?",
+      face,
+      topo->name
+    return NULL;
+  geom = (GSERIALIZED *)PG_DETOAST_DATUM(dat);
+  lwg = lwgeom_from_gserialized(geom);
+  lwgeom_refresh_bbox(lwg); /* Ensure we use a fit mbr, see #4149 */
+  box = lwgeom_get_bbox(lwg);
+  if ( box )
+    POSTGIS_DEBUGF(1, "Face %" LWTFMT_ELEMID " bbox xmin is %.15g", face, box->xmin);
+  else
+    cberror(
+      topo->be_data,
+      "Face with id %" LWTFMT_ELEMID" in topology \"%s\" has empty MBR ?",
+      face,
+      topo->name
+    return NULL;
+  lwgeom_free(lwg);
+  if ( DatumGetPointer(dat) != (Pointer)geom ) pfree(geom);
+  SPI_freetuptable(SPI_tuptable);
+  return gbox_clone(box);
 static int
 cb_deleteFacesById(const LWT_BE_TOPOLOGY *topo, const LWT_ELEMID *ids, uint64_t numelems)
@@ -3423,7 +3517,8 @@ static LWT_BE_CALLBACKS be_callbacks =
   cb_getFaceWithinBox2D,
   cb_checkTopoGeomRemIsoNode,
   cb_checkTopoGeomRemIsoEdge,
-  cb_getClosestEdge
+  cb_getClosestEdge,
+  cb_computeFaceMBR
 static void
diff --git a/topology/test/regress/st_changeedgegeom.sql b/topology/test/regress/st_changeedgegeom.sql
index 9cedd7677..7822035e0 100644
--- a/topology/test/regress/st_changeedgegeom.sql
+++ b/topology/test/regress/st_changeedgegeom.sql
@@ -136,20 +136,13 @@ SELECT 'T13.3', TopoGeo_AddPoint('city_data', 'POINT(-1.1697 47.7825)'::geometry
 SELECT 'T13.4', ST_ChangeEdgeGeom('city_data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
 0' );
 -- See https://trac.osgeo.org/postgis/ticket/4706
-DO $$
-BEGIN
-  -- 1. corrupt topology
-  UPDATE city_data.edge_data SET right_face = 3 WHERE edge_id = 19;
-  -- 2. Try to change the edge of a face with no bbox
-  BEGIN
-    PERFORM ST_ChangeEdgeGeom('city_data', 7, 'LINESTRING(21 22,28 20,35 22)' );
-  EXCEPTION
-  WHEN OTHERS THEN
-    -- Strip details, we only want the first part
-    RAISE EXCEPTION '%', regexp_replace(SQLERRM, '([^:]): .*', '\1 (see #4706)');
-  END;
-END;
-$$ LANGUAGE 'plpgsql';
+BEGIN;
+-- 1. Corrupt topology to make face geometry unbuildable
+UPDATE city_data.edge_data SET right_face = 3 WHERE edge_id = 19;
+-- 2. Try to change an edge of the corrupted face
+-- (we're only interested in this operation not crashing the backend)
+SELECT NULL FROM ST_ChangeEdgeGeom('city_data', 7, 'LINESTRING(21 22,28 20,35 22)' );
+ROLLBACK;
 ---- TODO: test changing some clockwise closed edges..
diff --git a/topology/test/regress/st_changeedgegeom_expected b/topology/test/regress/st_changeedgegeom_expected
index 64acf3f58..9e29700c7 100644
--- a/topology/test/regress/st_changeedgegeom_expected
+++ b/topology/test/regress/st_changeedgegeom_expected
@@ -35,5 +35,4 @@ T13.1|29
 T13.2|Edge 29 changed
 T13.3|26
 ERROR:  Edge motion collision at POINT(-1.1697 47.7825)
-ERROR:  Corrupted topology (see #4706)
 Topology 'city_data' dropped
Summary of changes:
 liblwgeom/liblwgeom_topo.h                       | 11 +++
 liblwgeom/lwgeom_topo.c                          | 72 ++++++------------
 topology/postgis_topology.c                      | 97 +++++++++++++++++++++++-
 topology/test/regress/st_changeedgegeom.sql      | 21 ++---
 topology/test/regress/st_changeedgegeom_expected |  1 -
 5 files changed, 136 insertions(+), 66 deletions(-)
hooks/post-receive
