[postgis-tickets] [PostGIS] #5112: berrie should show failure on first failure
PostGIS trac at osgeo.org
Fri Mar 4 13:01:12 PST 2022
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  blocker    |  Milestone:  PostGIS 3.3.0
Component:  buildbots  |    Version:  3.2.x
 Keywords:             |
 Right now berrie is failing on topology tests (which I will ticket later)
 and so is berrie64.  However berrie is showing green and berrie64 is
 showing error.
 This is because berrie goes on to run garden tests which succeed.
 She should be stopping upon first failure.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5112>
