[postgis-tickets] [PostGIS] #5113: berrie and berrie64 failing on topology tests
PostGIS trac at osgeo.org
Fri Mar 4 13:04:19 PST 2022
 Reporter:  robe      |      Owner:  strk
     Type:  defect    |     Status:  new
 Priority:  blocker   |  Milestone:  PostGIS 3.3.0
Component:  topology  |    Version:  3.2.x
 Keywords:            |
 07:15:51  ./topology/test/regress/st_changeedgegeom .. failed (diff
 expected obtained: /tmp/pgis_reg/test_188_diff)
 07:15:52
 07:15:52 --- ./topology/test/regress/st_changeedgegeom_expected 2022-03-04
 04:03:00.146712501 -0800
 07:15:52 +++ /tmp/pgis_reg/test_188_out 2022-03-04 04:15:52.314253246
 -0800
 07:15:52 @@ -1,4 +1,4 @@
 07:15:52 -T1|Edge 25 changed
 07:15:52 +ERROR:  Geometry type (Point) does not match column type
 (Polygon)
 07:15:52  ERROR:  SQL/MM Spatial exception - start node not geometry start
 point.
 07:15:52  ERROR:  SQL/MM Spatial exception - end node not geometry end
 point.
 07:15:52  ERROR:  SQL/MM Spatial exception - geometry crosses a node
 07:15:52 @@ -8,31 +8,32 @@
 This started happening [c273f394/git]
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5113>
