[postgis-tickets] [SCM] postgis.net branch hugo updated. 0ccecc58d387e6b1f201e76362a7e195a6a49273
Fri Mar 4 14:03:28 PST 2022
the project "postgis.net".
The branch, hugo has been updated
       via  0ccecc58d387e6b1f201e76362a7e195a6a49273 (commit)
      from  612ad92fe5cbf3ffc0e5224214d425324f4e87ad (commit)
revisions in full, below.
commit 0ccecc58d387e6b1f201e76362a7e195a6a49273
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Mar 4 17:03:24 2022 -0500
    Fix geos and proj links
diff --git a/content/pages/development.md b/content/pages/development.md
index 8729bde..dd43b8b 100644
--- a/content/pages/development.md
+++ b/content/pages/development.md
@@ -18,8 +18,8 @@ PostGIS adds extra types (geometry, geography, raster and others) to the [Postgr
 Since PostGIS is in C, it can make use of other libraries in C and C++, and it does so liberally. PostGIS depends on:
-* [GEOS](http://trac.osgeo.org/geos) for many geometry processing algorithms
-* [Proj](https://trac.osgeo.org/proj/) for coordinate re-projection functions
+* [GEOS](https://libgeos.org/) for many geometry processing algorithms
+* [Proj](https://proj.org/) for coordinate re-projection functions
 * [GDAL](http://gdal.org) for raster processing and format support
 * [LibXML2](http://www.xmlsoft.org/) for XML parsing
 * [JSON-C](https://github.com/json-c/json-c) for JSON parsing
diff --git a/content/pages/source.md b/content/pages/source.md
index a5c1735..358d6e5 100644
--- a/content/pages/source.md
+++ b/content/pages/source.md
@@ -44,7 +44,7 @@ For platform specific compilation instructions refer to [Compile and Install for
 To build from source, you will need a complete installation of PostgreSQL, either built and installed from source itself, or including the development headers and utilities. For Linux users, that means installing the `postgresql-devel` or `postgresql-dev` packages as well as the base packages.
-You will also need to install and/or build [GEOS](http://trac.osgeo.org/geos), [Proj](https://proj.org), [GDAL](http://gdal.org), [LibXML2](http://www.xmlsoft.org/) and [JSON-C](https://github.com/json-c/json-c).
+You will also need to install and/or build [GEOS](https://libgeos.org/), [Proj](https://proj.org), [GDAL](http://gdal.org), [LibXML2](http://www.xmlsoft.org/) and [JSON-C](https://github.com/json-c/json-c).
 ```sh
 tar xvzf postgis-{{< loc "postgis.version" >}}.tar.gz
Summary of changes:
 content/pages/development.md | 4 ++--
 content/pages/source.md      | 2 +-
 2 files changed, 3 insertions(+), 3 deletions(-)
hooks/post-receive
postgis.net
