[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-650-gd4bcabe85
Thu Mar 17 21:12:26 PDT 2022
the project "PostGIS".
       via  d4bcabe852f436d17311257a0b04df71dc1d6eda (commit)
      from  8c152e7c6971543cca8e110f0d16e8d33522393c (commit)
revisions in full, below.
commit d4bcabe852f436d17311257a0b04df71dc1d6eda
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date:   Thu Mar 17 03:31:34 2022 +0000
    Translated using Weblate (Japanese)
    Currently translated at 94.4% (221 of 234 strings)
    Translation: postgis/extras_tigergeocoder.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/extras_tigergeocoderxml/ja/
diff --git a/doc/po/ja/extras_tigergeocoder.xml.po b/doc/po/ja/extras_tigergeocoder.xml.po
index d9a2863e0..4aa404d8e 100644
--- a/doc/po/ja/extras_tigergeocoder.xml.po
+++ b/doc/po/ja/extras_tigergeocoder.xml.po
@@ -10,8 +10,8 @@ msgstr ""
 "Project-Id-Version: PostGIS\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2021-09-11 01:55+0000\n"
-"PO-Revision-Date: 2022-03-11 05:52+0000\n"
-"Last-Translator: Regina Obe <regina at arrival3d.com>\n"
+"PO-Revision-Date: 2022-03-18 04:12+0000\n"
+"Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
 "extras_tigergeocoderxml/ja/>\n"
 "Language: ja\n"
@@ -1367,6 +1367,10 @@ msgid ""
 "as well as bg, and tabblock using the <xref linkend="
 "\"Loader_Generate_Census_Script\"/> script."
 msgstr ""
+"この関数はセンサスの<varname>tract</varname>を使用しますが、これはデフォルト"
+"ではロードされません。すでに州テーブルをロード済みなら、<xref linkend="
+"\"Loader_Generate_Census_Script\""
+"/>スクリプトを使って、tractを、bgおよびtabblockと共にロードできます。"
 #. Tag: para
 #: extras_tigergeocoder.xml:366
@@ -1388,10 +1392,10 @@ msgstr ""
 #. Tag: para
 #: extras_tigergeocoder.xml:368
-#, fuzzy, no-c-format
+#, no-c-format
 msgid ""
 "then they will be included by the <xref linkend=\"Loader_Generate_Script\"/>."
-msgstr ", <xref linkend=\"Missing_Indexes_Generate_Script\"/>"
+msgstr "これらは、<xref linkend=\"Loader_Generate_Script\"/>によって取り込まれます。"
 #. Tag: programlisting
 #: extras_tigergeocoder.xml:378
Summary of changes:
 doc/po/ja/extras_tigergeocoder.xml.po | 12 ++++++++----
 1 file changed, 8 insertions(+), 4 deletions(-)
hooks/post-receive
