[postgis-tickets] [PostGIS] #5115: Deferred constraint prevents dropping topology
PostGIS trac at osgeo.org
Fri Mar 18 14:25:13 PDT 2022
  Reporter:  ccrook    |      Owner:  strk
      Type:  defect    |     Status:  assigned
  Priority:  medium    |  Milestone:  PostGIS 3.3.0
 Component:  topology  |    Version:  3.2.x
Resolution:            |   Keywords:
Changes (by strk):
 * status:  new => assigned
Comment:
 Issue confirmed. The issue is present also in PostGIS-3.0 (and probably
 earlier too).
 Work in progress fix is here:
 https://gitlab.com/postgis/postgis/-/merge_requests/73
 Those pending constraints need to be executed in order for the drop to be
 accepted.
 You can force executing them with this:
   SET constraints ALL IMMEDIATE;
 Or, to be stricter:
   SET constraints mytopology.next_right_edge_exists,
 mytopology.next_left_edge_exists IMMEDIATE;
 To be honest I forgot why we're making those constraints deferred, it may
 have been a bad choice
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5115#comment:1>
