[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-651-g7a5ae3e1c
Fri Mar 18 16:13:02 PDT 2022
the project "PostGIS".
       via  7a5ae3e1c3f0aee192601d4648b86d2f5717a3e5 (commit)
      from  d4bcabe852f436d17311257a0b04df71dc1d6eda (commit)
revisions in full, below.
commit 7a5ae3e1c3f0aee192601d4648b86d2f5717a3e5
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Mar 18 21:32:36 2022 +0100
    Execute pending constraints before dropping topology
    References #5115 in master branch (3.3.0dev)
    Includes test
diff --git a/topology/test/regress/droptopology.sql b/topology/test/regress/droptopology.sql
index 0b63a6d71..7f12a2b34 100644
--- a/topology/test/regress/droptopology.sql
+++ b/topology/test/regress/droptopology.sql
@@ -31,6 +31,14 @@ INSERT INTO t3.f(g) VALUES (toTopoGeom('POINT(0 0)', 't3', 1));
 --SELECT topology.DropTopoGeometryColumn('t3', 'f', 'g');
 SELECT topology.DropTopology('t3');
+-- Test DropTopology with pending deferred triggers
+-- See https://trac.osgeo.org/postgis/ticket/5115
+BEGIN;
+SELECT 't5115.create' FROM topology.CreateTopology('t5115');
+SELECT 't5115.addline' FROM topology.TopoGeo_addLineString('t5115', 'LINESTRING(0 0, 10 0)');
+SELECT 't5115.drop' FROM topology.DropTopology('t5115');
+ROLLBACK;
 -- Exceptions
 SELECT topology.DropTopology('topology');
 SELECT topology.DropTopology('doesnotexist');
diff --git a/topology/test/regress/droptopology_expected b/topology/test/regress/droptopology_expected
index 37905a4d3..3c5f8570a 100644
--- a/topology/test/regress/droptopology_expected
+++ b/topology/test/regress/droptopology_expected
@@ -1,5 +1,8 @@
 Topology 't1' dropped
 Topology 't2' dropped
 Topology 't3' dropped
+t5115.create
+t5115.addline
+t5115.drop
 ERROR:  Topology 'topology' does not exist
 ERROR:  Topology 'doesnotexist' does not exist
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index 0d92c8f39..a522cbcf2 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -1704,6 +1704,8 @@ DECLARE
   topoid integer;
   rec RECORD;
   sql TEXT;
+  toposchema REGNAMESPACE;
+  deferred_constraints TEXT[];
 BEGIN
   -- Get topology id
   SELECT id INTO topoid
@@ -1744,14 +1746,37 @@ BEGIN
 #endif
   -- Drop the schema (if it exists)
-  FOR rec IN SELECT * FROM pg_namespace WHERE text(nspname) = atopology
-  LOOP
+  SELECT oid FROM pg_namespace WHERE text(nspname) = atopology
+  INTO toposchema;
+  IF toposchema IS NOT NULL THEN --{
+    -- Give immediate execution to pending constraints
+    -- in the topology schema.
+    -- See https://trac.osgeo.org/postgis/ticket/5115
+    SELECT array_agg(format('%I.%I', atopology, conname))
+    FROM pg_constraint c
+    WHERE connamespace = toposchema AND condeferred
+    INTO deferred_constraints;
+    IF deferred_constraints IS NOT NULL THEN --{
+      sql := format(
+        'SET constraints %s IMMEDIATE',
+        array_to_string(deferred_constraints, ',')
+#ifdef POSTGIS_TOPOLOGY_DEBUG
+      RAISE DEBUG 'Executing: %', sql;
+#endif
+      EXECUTE sql;
+    END IF; --}
     sql := format('DROP SCHEMA %I CASCADE', atopology);
 #endif
     EXECUTE sql;
-  END LOOP;
+  END IF; --}
   RETURN format('Topology %L dropped', atopology);
 END
Summary of changes:
 topology/test/regress/droptopology.sql      |  8 ++++++++
 topology/test/regress/droptopology_expected |  3 +++
 topology/topology.sql.in                    | 31 ++++++++++++++++++++++++++---
 3 files changed, 39 insertions(+), 3 deletions(-)
hooks/post-receive
