[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-656-g1ba6bccae
Sun Mar 27 13:26:59 PDT 2022
the project "PostGIS".
       via  1ba6bccae13bfd37383e35f8c0678b08393f6726 (commit)
      from  c8eedf3aeb1dd571ef7bcf15ad0c19486d9dd031 (commit)
revisions in full, below.
commit 1ba6bccae13bfd37383e35f8c0678b08393f6726
Author: Chen <onsummer at foxmail.com>
Date:   Sun Mar 27 20:26:55 2022 +0000
    Added translation using Weblate (Chinese (Simplified))
diff --git a/doc/po/zh_Hans/reference_constructor.xml.po b/doc/po/zh_Hans/reference_constructor.xml.po
new file mode 100644
index 000000000..88b326c13
--- /dev/null
+++ b/doc/po/zh_Hans/reference_constructor.xml.po
@@ -0,0 +1,2120 @@
+# SOME DESCRIPTIVE TITLE.
+# FIRST AUTHOR <EMAIL at ADDRESS>, YEAR.
+msgid ""
+msgstr ""
+"Project-Id-Version: PACKAGE VERSION\n"
+"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
+"POT-Creation-Date: 2022-02-13 18:15+0000\n"
+"PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
+"Last-Translator: Automatically generated\n"
+"Language-Team: none\n"
+"Language: zh_Hans\n"
+"MIME-Version: 1.0\n"
+"Content-Type: text/plain; charset=UTF-8\n"
+"Content-Transfer-Encoding: 8bit\n"
+#. Tag: title
+#: reference_constructor.xml:3
+#, no-c-format
+msgid "Geometry Constructors"
+msgstr ""
+#. Tag: refname
+#: reference_constructor.xml:7
+#, no-c-format
+msgid "ST_Collect"
+msgstr ""
+#. Tag: refpurpose
+#: reference_constructor.xml:8
+#, no-c-format
+msgid ""
+"Creates a GeometryCollection or Multi* geometry from a set of geometries."
+msgstr ""
+#. Tag: funcsynopsis
+#: reference_constructor.xml:12
+#, no-c-format
+msgid ""
+"<funcprototype> <funcdef>geometry <function>ST_Collect</function></funcdef> "
+"<paramdef><type>geometry</type> <parameter>g1</parameter></paramdef> "
+"<paramdef><type>geometry</type> <parameter>g2</parameter></paramdef> </"
+"funcprototype> <funcprototype> <funcdef>geometry <function>ST_Collect</"
+"function></funcdef> <paramdef><type>geometry[]</type> <parameter>g1_array</"
+"parameter></paramdef> </funcprototype> <funcprototype> <funcdef>geometry "
+"<function>ST_Collect</function></funcdef> <paramdef><type>geometry set</"
+"type> <parameter>g1field</parameter></paramdef> </funcprototype>"
+msgstr ""
+#. Tag: title
+#: reference_constructor.xml:30 reference_constructor.xml:109
+#: reference_constructor.xml:154 reference_constructor.xml:203
+#: reference_constructor.xml:313 reference_constructor.xml:359
+#: reference_constructor.xml:413 reference_constructor.xml:506
+#: reference_constructor.xml:573 reference_constructor.xml:610
+#: reference_constructor.xml:649 reference_constructor.xml:684
+#: reference_constructor.xml:743 reference_constructor.xml:782
+#: reference_constructor.xml:854 reference_constructor.xml:891
+#: reference_constructor.xml:956 reference_constructor.xml:994
+#, no-c-format
+msgid "Description"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Collects geometries into a geometry collection. The result is either a "
+"Multi* or a GeometryCollection, depending on whether the input geometries "
+"have the same or different types (homogeneous or heterogeneous). The input "
+"geometries are left unchanged within the collection."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:38 reference_constructor.xml:208
+#, no-c-format
+msgid ""
+"<emphasis role=\"bold\">Variant 1:</emphasis> accepts two input geometries"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:39 reference_constructor.xml:209
+#, no-c-format
+msgid ""
+"<emphasis role=\"bold\">Variant 2:</emphasis> accepts an array of geometries"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:40
+#, no-c-format
+msgid ""
+"<emphasis role=\"bold\">Variant 3:</emphasis> aggregate function accepting a "
+"rowset of geometries."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:42
+#, no-c-format
+msgid ""
+"If any of the input geometries are collections (Multi* or "
+"GeometryCollection) ST_Collect returns a GeometryCollection (since that is "
+"the only type which can contain nested collections). To prevent this, use "
+"<xref linkend=\"ST_Dump\"/> in a subquery to expand the input collections to "
+"their atomic elements (see example below)."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:50
+#, no-c-format
+msgid ""
+"ST_Collect and <xref linkend=\"ST_Union\"/> appear similar, but in fact "
+"operate quite differently. ST_Collect aggregates geometries into a "
+"collection without changing them in any way. ST_Union geometrically merges "
+"geometries where they overlap, and splits linestrings at intersections. It "
+"may return single geometries when it dissolves boundaries."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Availability: 1.4.0 - ST_Collect(geomarray) was introduced. ST_Collect was "
+"enhanced to handle more geometries faster."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:58 reference_constructor.xml:115
+#: reference_constructor.xml:220 reference_constructor.xml:327
+#: reference_constructor.xml:427 reference_constructor.xml:701
+#, no-c-format
+msgid "&Z_support;"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:59
+#, no-c-format
+msgid "&curve_support;"
+msgstr ""
+#. Tag: title
+#: reference_constructor.xml:63
+#, no-c-format
+msgid "Examples - Two-input variant"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Collect 2D points."
+msgstr ""
+#. Tag: programlisting
+#: reference_constructor.xml:65
+#, no-c-format
+msgid ""
+"SELECT ST_AsText( ST_Collect( ST_GeomFromText('POINT(1 2)'),\n"
+"        ST_GeomFromText('POINT(-2 3)') ));\n"
+"\n"
+"st_astext\n"
+"----------\n"
+"MULTIPOINT(1 2,-2 3)"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:67
+#, no-c-format
+msgid "Collect 3D points."
+msgstr ""
+#: reference_constructor.xml:68
+#, no-c-format
+msgid ""
+"SELECT ST_AsEWKT( ST_Collect( ST_GeomFromEWKT('POINT(1 2 3)'),\n"
+"                ST_GeomFromEWKT('POINT(1 2 4)') ) );\n"
+"\n"
+"                st_asewkt\n"
+"-------------------------\n"
+" MULTIPOINT(1 2 3,1 2 4)"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:70
+#, no-c-format
+msgid "Collect curves."
+msgstr ""
+#: reference_constructor.xml:71
+#, no-c-format
+msgid ""
+"SELECT ST_AsText( ST_Collect( 'CIRCULARSTRING(220268 150415,220227 "
+"150505,220227 150406)',\n"
+"                'CIRCULARSTRING(220227 150406,2220227 150407,220227 "
+"150406)'));\n"
+"\n"
+"                st_astext\n"
+"------------------------------------------------------------------------------------\n"
+"MULTICURVE(CIRCULARSTRING(220268 150415,220227 150505,220227 150406),\n"
+" CIRCULARSTRING(220227 150406,2220227 150407,220227 150406))"
+msgstr ""
+#. Tag: title
+#, no-c-format
+msgid "Examples - Array variant"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:75
+#, no-c-format
+msgid "Using an array constructor for a subquery."
+msgstr ""
+#: reference_constructor.xml:76
+#, no-c-format
+msgid "SELECT ST_Collect( ARRAY( SELECT geom FROM sometable ) );"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:77
+#, no-c-format
+msgid "Using an array constructor for values."
+msgstr ""
+#: reference_constructor.xml:78
+#, no-c-format
+msgid ""
+"SELECT ST_AsText(  ST_Collect(\n"
+"                ARRAY[ ST_GeomFromText('LINESTRING(1 2, 3 4)'),\n"
+"                        ST_GeomFromText('LINESTRING(3 4, 4 5)') ] )) As "
+"wktcollect;\n"
+"\n"
+"--wkt collect --\n"
+"MULTILINESTRING((1 2,3 4),(3 4,4 5))"
+msgstr ""
+#. Tag: title
+#: reference_constructor.xml:81
+#, no-c-format
+msgid "Examples - Aggregate variant"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:82
+#, no-c-format
+msgid "Creating multiple collections by grouping geometries in a table."
+msgstr ""
+#: reference_constructor.xml:83
+#, no-c-format
+msgid ""
+"SELECT stusps, ST_Collect(f.geom) as geom\n"
+"         FROM (SELECT stusps, (ST_Dump(geom)).geom As geom\n"
+"                                FROM\n"
+"                                somestatetable ) As f\n"
+"        GROUP BY stusps"
+msgstr ""
+#. Tag: title
+#: reference_constructor.xml:87 reference_constructor.xml:127
+#: reference_constructor.xml:170 reference_constructor.xml:266
+#: reference_constructor.xml:335 reference_constructor.xml:384
+#: reference_constructor.xml:472 reference_constructor.xml:547
+#: reference_constructor.xml:586 reference_constructor.xml:623
+#: reference_constructor.xml:662 reference_constructor.xml:716
+#: reference_constructor.xml:758 reference_constructor.xml:829
+#: reference_constructor.xml:869 reference_constructor.xml:929
+#: reference_constructor.xml:971 reference_constructor.xml:1021
+#, no-c-format
+msgid "See Also"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:88
+#, no-c-format
+msgid ", <xref linkend=\"ST_Union\"/>"
+msgstr ""
+#. Tag: refname
+#: reference_constructor.xml:94
+#, no-c-format
+msgid "ST_LineFromMultiPoint"
+msgstr ""
+#. Tag: refpurpose
+#: reference_constructor.xml:96
+#, no-c-format
+msgid ""
+"<refpurpose>Creates a LineString from a MultiPoint geometry.</refpurpose>"
+msgstr ""
+#. Tag: funcprototype
+#: reference_constructor.xml:101
+#, no-c-format
+msgid ""
+"<funcdef>geometry <function>ST_LineFromMultiPoint</function></funcdef> "
+"<paramdef><type>geometry </type> <parameter>aMultiPoint</parameter></"
+"paramdef>"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:111
+#, no-c-format
+msgid "<para>Creates a LineString from a MultiPoint geometry.</para>"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:113
+#, no-c-format
+msgid ""
+"Use <xref linkend=\"ST_MakeLine\"/> to create lines from Point or LineString "
+"inputs."
+msgstr ""
+#. Tag: title
+#: reference_constructor.xml:120 reference_constructor.xml:331
+#: reference_constructor.xml:370 reference_constructor.xml:579
+#: reference_constructor.xml:616 reference_constructor.xml:655
+#: reference_constructor.xml:706
+#, no-c-format
+msgid "Examples"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:121
+#, no-c-format
+msgid "Create a 3D line string from a 3D MultiPoint"
+msgstr ""
+#: reference_constructor.xml:122
+#, no-c-format
+msgid ""
+"SELECT ST_AsEWKT(  ST_LineFromMultiPoint('MULTIPOINT(1 2 3, 4 5 6, 7 8 "
+"9)')  ));\n"
+"\n"
+"--result--\n"
+"LINESTRING(1 2 3,4 5 6,7 8 9)"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:129
+#, no-c-format
+msgid ", <xref linkend=\"ST_MakeLine\"/>"
+msgstr ""
+#. Tag: refname
+#: reference_constructor.xml:135
+#, no-c-format
+msgid "ST_MakeEnvelope"
+msgstr ""
+#. Tag: refpurpose
+#: reference_constructor.xml:137
+#, no-c-format
+msgid "Creates a rectangular Polygon from minimum and maximum coordinates."
+msgstr ""
+#: reference_constructor.xml:142
+#, no-c-format
+msgid ""
+"<funcdef>geometry <function>ST_MakeEnvelope</function></funcdef> "
+"<paramdef><type>float</type> <parameter>xmin</parameter></paramdef> "
+"<paramdef><type>float</type> <parameter>ymin</parameter></paramdef> "
+"<paramdef><type>float</type> <parameter>xmax</parameter></paramdef> "
+"<paramdef><type>float</type> <parameter>ymax</parameter></paramdef> "
+"<paramdef choice=\"opt\"><type>integer</type> <parameter>srid=unknown</"
+"parameter></paramdef>"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:156
+#, no-c-format
+msgid ""
+"Creates a rectangular Polygon from the minimum and maximum values for X and "
+"Y. Input values must be in the spatial reference system specified by the "
+"SRID. If no SRID is specified the unknown spatial reference system (SRID 0) "
+"is used."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:160
+#, no-c-format
+msgid "Availability: 1.5"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:161
+#, no-c-format
+msgid ""
+"Enhanced: 2.0: Ability to specify an envelope without specifying an SRID was "
+"introduced."
+msgstr ""
+#. Tag: title
+#: reference_constructor.xml:166
+#, no-c-format
+msgid "Example: Building a bounding box polygon"
+msgstr ""
+#: reference_constructor.xml:167
+#, no-c-format
+msgid ""
+"SELECT ST_AsText( ST_MakeEnvelope(10, 10, 11, 11, 4326) );\n"
+"\n"
+"st_asewkt\n"
+"-----------\n"
+"POLYGON((10 10, 10 11, 11 11, 11 10, 10 10))"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:171
+#, no-c-format
+msgid ""
+", <xref linkend=\"ST_MakeLine\"/>, <xref linkend=\"ST_MakePolygon\"/>, <xref "
+"linkend=\"ST_TileEnvelope\"/>"
+msgstr ""
+#. Tag: refname
+#: reference_constructor.xml:177
+#, no-c-format
+msgid "ST_MakeLine"
+msgstr ""
+#. Tag: refpurpose
+#: reference_constructor.xml:179
+#, no-c-format
+msgid "Creates a LineString from Point, MultiPoint, or LineString geometries."
+msgstr ""
+#: reference_constructor.xml:183
+#, no-c-format
+msgid ""
+"<funcprototype> <funcdef>geometry <function>ST_MakeLine</function></funcdef> "
+"<paramdef><type>geometry</type> <parameter>geom1</parameter></paramdef> "
+"<paramdef><type>geometry</type> <parameter>geom2</parameter></paramdef> </"
+"funcprototype> <funcprototype> <funcdef>geometry <function>ST_MakeLine</"
+"function></funcdef> <paramdef><type>geometry[]</type> "
+"<parameter>geoms_array</parameter></paramdef> </funcprototype> "
+"<paramdef><type>geometry set</type> <parameter>geoms</parameter></paramdef> "
+"</funcprototype>"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:205
+#, no-c-format
+msgid ""
+"Creates a LineString containing the points of Point, MultiPoint, or "
+"LineString geometries. Other geometry types cause an error."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:210
+#, no-c-format
+msgid ""
+"rowset of geometries. To ensure the order of the input geometries use "
+"<varname>ORDER BY</varname> in the function call, or a subquery with an "
+"<varname>ORDER BY</varname> clause."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:214
+#, no-c-format
+msgid ""
+"Repeated nodes at the beginning of input LineStrings are collapsed to a "
+"single point. Repeated points in Point and MultiPoint inputs are not "
+"collapsed. <xref linkend=\"ST_RemoveRepeatedPoints\"/> can be used to "
+"collapse repeated points from the output LineString."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:222
+#, no-c-format
+msgid ""
+"Availability: 2.3.0 - Support for MultiPoint input elements was introduced"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:223
+#, no-c-format
+msgid ""
+"Availability: 2.0.0 - Support for LineString input elements was introduced"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:224
+#, no-c-format
+msgid ""
+"Availability: 1.4.0 - ST_MakeLine(geomarray) was introduced. ST_MakeLine "
+"aggregate functions was enhanced to handle more points faster."
+msgstr ""
+#. Tag: title
+#: reference_constructor.xml:229
+#, no-c-format
+msgid "Examples: Two-input variant"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:231
+#, no-c-format
+msgid "Create a line composed of two points."
+msgstr ""
+#: reference_constructor.xml:232
+#, no-c-format
+msgid ""
+"SELECT ST_AsText( ST_MakeLine(ST_Point(1,2), ST_Point(3,4)) );\n"
+"\n"
+"          st_astext\n"
+"---------------------\n"
+" LINESTRING(1 2,3 4)"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:234
+#, no-c-format
+msgid "Create a 3D line from two 3D points."
+msgstr ""
+#: reference_constructor.xml:235
+#, no-c-format
+msgid ""
+"SELECT ST_AsEWKT( ST_MakeLine(ST_MakePoint(1,2,3), ST_MakePoint(3,4,5) ));\n"
+"\n"
+"                st_asewkt\n"
+" LINESTRING(1 2 3,3 4 5)"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:237
+#, no-c-format
+msgid "Create a line from two disjoint LineStrings."
+msgstr ""
+#: reference_constructor.xml:238
+#, no-c-format
+msgid ""
+"select ST_AsText( ST_MakeLine( 'LINESTRING(0 0, 1 1)', 'LINESTRING(2 2, 3 "
+"3)' ) );\n"
+"\n"
+"          st_astext\n"
+"-----------------------------\n"
+" LINESTRING(0 0,1 1,2 2,3 3)"
+msgstr ""
+#. Tag: title
+#: reference_constructor.xml:242
+#, no-c-format
+msgid "Examples: Array variant"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:244
+#, no-c-format
+msgid "Create a line from an array formed by a subquery with ordering."
+msgstr ""
+#: reference_constructor.xml:245
+#, no-c-format
+msgid ""
+"SELECT ST_MakeLine( ARRAY( SELECT ST_Centroid(geom) FROM visit_locations "
+"ORDER BY visit_time) );"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:247
+#, no-c-format
+msgid "Create a 3D line from an array of 3D points"
+msgstr ""
+#: reference_constructor.xml:248
+#, no-c-format
+msgid ""
+"SELECT ST_AsEWKT( ST_MakeLine(\n"
+"          ARRAY[ ST_MakePoint(1,2,3), ST_MakePoint(3,4,5), "
+"ST_MakePoint(6,6,6) ]  ));\n"
+"\n"
+"                st_asewkt\n"
+"LINESTRING(1 2 3,3 4 5,6 6 6)"
+msgstr ""
+#. Tag: title
+#: reference_constructor.xml:252
+#, no-c-format
+msgid "Examples: Aggregate variant"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:253
+#, no-c-format
+msgid ""
+"This example queries time-based sequences of GPS points from a set of tracks "
+"and creates one record for each track. The result geometries are LineStrings "
+"composed of the GPS track points in the order of travel."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:257
+#, no-c-format
+msgid ""
+"Using aggregate <varname>ORDER BY</varname> provides a correctly-ordered "
+"LineString."
+msgstr ""
+#: reference_constructor.xml:258
+#, no-c-format
+msgid ""
+"SELECT gps.track_id, ST_MakeLine(gps.geom ORDER BY gps_time) As geom\n"
+"        FROM gps_points As gps\n"
+"        GROUP BY track_id;"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:260
+#, no-c-format
+msgid ""
+"Prior to PostgreSQL 9, ordering in a subquery can be used. However, "
+"sometimes the query plan may not respect the order of the subquery."
+msgstr ""
+#: reference_constructor.xml:262
+#, no-c-format
+msgid ""
+"SELECT gps.track_id, ST_MakeLine(gps.geom) As geom\n"
+"        FROM ( SELECT track_id, gps_time, geom\n"
+"                        FROM gps_points ORDER BY track_id, gps_time ) As "
+"gps\n"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:267
+#, no-c-format
+msgid ""
+", <xref linkend=\"ST_AsEWKT\"/>, <xref linkend=\"ST_AsText\"/>, <xref "
+"linkend=\"ST_GeomFromText\"/>, <xref linkend=\"ST_MakePoint\"/>, <xref "
+"linkend=\"ST_Point\"/>"
+msgstr ""
+#. Tag: refname
+#: reference_constructor.xml:280
+#, no-c-format
+msgid "ST_MakePoint"
+msgstr ""
+#. Tag: refpurpose
+#: reference_constructor.xml:282
+#, no-c-format
+msgid "Creates a 2D, 3DZ or 4D Point."
+msgstr ""
+#: reference_constructor.xml:287
+#, no-c-format
+msgid ""
+"<funcdef>geometry <function>ST_MakePoint</function></funcdef> "
+"<paramdef><type>float</type> <parameter>x</parameter></paramdef> "
+"<paramdef><type>float</type> <parameter>y</parameter></paramdef>"
+msgstr ""
+#: reference_constructor.xml:294
+#, no-c-format
+msgid ""
+"<paramdef><type>float</type> <parameter>y</parameter></paramdef> "
+"<paramdef><type>float</type> <parameter>z</parameter></paramdef>"
+msgstr ""
+#: reference_constructor.xml:302
+#, no-c-format
+msgid ""
+"<paramdef><type>float</type> <parameter>z</parameter></paramdef> "
+"<paramdef><type>float</type> <parameter>m</parameter></paramdef>"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:315
+#, no-c-format
+msgid "Creates a 2D, 3D Z or 4D ZM Point geometry."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:317
+#, no-c-format
+msgid ""
+"Use <xref linkend=\"ST_MakePointM\"/> to make points with XYM coordinates."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:319
+#, no-c-format
+msgid ""
+"While not OGC-compliant, <varname>ST_MakePoint</varname> is faster and more "
+"precise than <xref linkend=\"ST_GeomFromText\"/> and <xref linkend="
+"\"ST_PointFromText\"/>. It is also easier to use for numeric coordinate "
+"values."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:325 reference_constructor.xml:365
+#: reference_constructor.xml:510
+#, no-c-format
+msgid ""
+"For geodetic coordinates, <varname>X</varname> is longitude and <varname>Y</"
+"varname> is latitude"
+msgstr ""
+#: reference_constructor.xml:332
+#, no-c-format
+msgid ""
+"--Return point with unknown SRID\n"
+"SELECT ST_MakePoint(-71.1043443253471, 42.3150676015829);\n"
+"\n"
+"--Return point marked as WGS 84 long lat\n"
+"SELECT ST_SetSRID(ST_MakePoint(-71.1043443253471, 42.3150676015829),4326);\n"
+"\n"
+"--Return a 3D point (e.g. has altitude)\n"
+"SELECT ST_MakePoint(1, 2,1.5);\n"
+"\n"
+"--Get z of point\n"
+"SELECT ST_Z(ST_MakePoint(1, 2,1.5));\n"
+"result\n"
+"-------\n"
+"1.5"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:336
+#, no-c-format
+msgid ""
+", <xref linkend=\"ST_PointFromText\"/>, <xref linkend=\"ST_SetSRID\"/>, "
+"<xref linkend=\"ST_MakePointM\"/>"
+msgstr ""
+#. Tag: refname
+#: reference_constructor.xml:342
+#, no-c-format
+msgid "ST_MakePointM"
+msgstr ""
+#. Tag: refpurpose
+#: reference_constructor.xml:344
+#, no-c-format
+msgid "Creates a Point from X, Y and M values."
+msgstr ""
+#: reference_constructor.xml:349
+#, no-c-format
+msgid ""
+"<funcdef>geometry <function>ST_MakePointM</function></funcdef> "
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:361
+#, no-c-format
+msgid "Creates a point with X, Y and M (measure) coordinates."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:363
+#, no-c-format
+msgid ""
+"Use <xref linkend=\"ST_MakePoint\"/> to make points with XY, XYZ, or XYZM "
+"coordinates."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:371
+#, no-c-format
+msgid ""
+"is used for text output because <xref linkend=\"ST_AsText\"/> does not "
+"support M values."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:374
+#, no-c-format
+msgid "Create point with unknown SRID."
+msgstr ""
+#: reference_constructor.xml:375
+#, no-c-format
+msgid ""
+"SELECT ST_AsEWKT(  ST_MakePointM(-71.1043443253471, 42.3150676015829, "
+"10)  );\n"
+"\n"
+"                                   st_asewkt\n"
+"-----------------------------------------------\n"
+" POINTM(-71.1043443253471 42.3150676015829 10)"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:377
+#, no-c-format
+msgid "Create point with a measure in the WGS 84 geodetic coordinate system."
+msgstr ""
+#: reference_constructor.xml:378
+#, no-c-format
+msgid ""
+"SELECT ST_AsEWKT( ST_SetSRID(  ST_MakePointM(-71.104, 42.315, 10),  4326));\n"
+"\n"
+"                                                st_asewkt\n"
+"---------------------------------------------------------\n"
+"SRID=4326;POINTM(-71.104 42.315 10)"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:380
+#, no-c-format
+msgid "Get measure of created point."
+msgstr ""
+#: reference_constructor.xml:381
+#, no-c-format
+msgid ""
+"SELECT ST_M(  ST_MakePointM(-71.104, 42.315, 10)  );\n"
+"\n"
+"result\n"
+"-------\n"
+"10"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:385
+#, no-c-format
+msgid ", <xref linkend=\"ST_MakePoint\"/>, <xref linkend=\"ST_SetSRID\"/>"
+msgstr ""
+#. Tag: refname
+#: reference_constructor.xml:391
+#, no-c-format
+msgid "ST_MakePolygon"
+msgstr ""
+#. Tag: refpurpose
+#: reference_constructor.xml:393
+#, no-c-format
+msgid "Creates a Polygon from a shell and optional list of holes."
+msgstr ""
+#: reference_constructor.xml:398
+#, no-c-format
+msgid ""
+"<funcdef>geometry <function>ST_MakePolygon</function></funcdef> "
+"<paramdef><type>geometry</type> <parameter>linestring</parameter></paramdef>"
+msgstr ""
+#: reference_constructor.xml:404
+#, no-c-format
+msgid ""
+"<paramdef><type>geometry</type> <parameter>outerlinestring</parameter></"
+"paramdef> <paramdef><type>geometry[]</type> <parameter>interiorlinestrings</"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:415
+#, no-c-format
+msgid ""
+"Creates a Polygon formed by the given shell and optional array of holes. "
+"Input geometries must be closed LineStrings (rings)."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:418
+#, no-c-format
+msgid ""
+"<emphasis role=\"bold\">Variant 1:</emphasis> Accepts one shell LineString."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:419
+#, no-c-format
+msgid ""
+"<emphasis role=\"bold\">Variant 2:</emphasis> Accepts a shell LineString and "
+"an array of inner (hole) LineStrings. A geometry array can be constructed "
+"using the PostgreSQL array_agg(), ARRAY[] or ARRAY() constructs."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:423 reference_constructor.xml:695
+#, no-c-format
+msgid ""
+"This function does not accept MultiLineStrings. Use <xref linkend="
+"\"ST_LineMerge\"/> to generate a LineString, or <xref linkend=\"ST_Dump\"/> "
+"to extract LineStrings."
+msgstr ""
+#. Tag: title
+#: reference_constructor.xml:431
+#, no-c-format
+msgid "Examples: Single input variant"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:432
+#, no-c-format
+msgid "Create a Polygon from a 2D LineString."
+msgstr ""
+#: reference_constructor.xml:433
+#, no-c-format
+msgid ""
+"SELECT ST_MakePolygon( ST_GeomFromText('LINESTRING(75 29,77 29,77 29, 75 "
+"29)'));"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:435
+#, no-c-format
+msgid ""
+"Create a Polygon from an open LineString, using <xref linkend=\"ST_StartPoint"
+"\"/> and <xref linkend=\"ST_AddPoint\"/> to close it."
+msgstr ""
+#: reference_constructor.xml:437
+#, no-c-format
+msgid ""
+"SELECT ST_MakePolygon( ST_AddPoint(foo.open_line, ST_StartPoint(foo."
+"open_line)) )\n"
+"FROM (\n"
+"  SELECT ST_GeomFromText('LINESTRING(75 29,77 29,77 29, 75 29)') As "
+"open_line) As foo;"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:439
+#, no-c-format
+msgid "Create a Polygon from a 3D LineString"
+msgstr ""
+#: reference_constructor.xml:440
+#, no-c-format
+msgid ""
+"SELECT ST_AsEWKT( ST_MakePolygon( 'LINESTRING(75.15 29.53 1,77 29 1,77.6 "
+"29.5 1, 75.15 29.53 1)'));\n"
+"\n"
+"st_asewkt\n"
+"-----------\n"
+"POLYGON((75.15 29.53 1,77 29 1,77.6 29.5 1,75.15 29.53 1))"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:441
+#, no-c-format
+msgid "Create a Polygon from a LineString with measures"
+msgstr ""
+#: reference_constructor.xml:442
+#, no-c-format
+msgid ""
+"SELECT ST_AsEWKT( ST_MakePolygon( 'LINESTRINGM(75.15 29.53 1,77 29 1,77.6 "
+"29.5 2, 75.15 29.53 2)' ));\n"
+"\n"
+"st_asewkt\n"
+"----------\n"
+"POLYGONM((75.15 29.53 1,77 29 1,77.6 29.5 2,75.15 29.53 2))"
+msgstr ""
+#. Tag: title
+#: reference_constructor.xml:445
+#, no-c-format
+msgid "Examples: Outer shell with inner holes variant"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:447
+#, no-c-format
+msgid "Create a donut Polygon with an extra hole"
+msgstr ""
+#: reference_constructor.xml:448
+#, no-c-format
+msgid ""
+"SELECT ST_MakePolygon( ST_ExteriorRing( ST_Buffer(ring.line,10)),\n"
+"        ARRAY[  ST_Translate(ring.line, 1, 1),\n"
+"                ST_ExteriorRing(ST_Buffer(ST_Point(20,20),1)) ]\n"
+"        )\n"
+"FROM (SELECT ST_ExteriorRing(\n"
+"        ST_Buffer(ST_Point(10,10),10,10)) AS line ) AS ring;"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:449
+#, no-c-format
+msgid ""
+"Create a set of province boundaries with holes representing lakes. The input "
+"is a table of province Polygons/MultiPolygons and a table of water "
+"linestrings. Lines forming lakes are determined by using <xref linkend="
+"\"ST_IsClosed\"/>. The province linework is extracted by using <xref linkend="
+"\"ST_Boundary\"/>. As required by <code>ST_MakePolygon</code>, the boundary "
+"is forced to be a single LineString by using <xref linkend=\"ST_LineMerge\"/"
+">. (However, note that if a province has more than one region or has islands "
+"this will produce an invalid polygon.) Using a LEFT JOIN ensures all "
+"provinces are included even if they have no lakes."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:462
+#, no-c-format
+msgid ""
+"The CASE construct is used because passing a null array into ST_MakePolygon "
+"results in a NULL return value."
+msgstr ""
+#: reference_constructor.xml:465
+#, no-c-format
+msgid ""
+"SELECT p.gid, p.province_name,\n"
+"        CASE WHEN array_agg(w.geom) IS NULL\n"
+"        THEN p.geom\n"
+"        ELSE  ST_MakePolygon( ST_LineMerge(ST_Boundary(p.geom)),\n"
+"                        array_agg(w.geom)) END\n"
+"FROM\n"
+"        provinces p LEFT JOIN waterlines w\n"
+"                ON (ST_Within(w.geom, p.geom) AND ST_IsClosed(w.geom))\n"
+"GROUP BY p.gid, p.province_name, p.geom;"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:467
+#, no-c-format
+msgid ""
+"Another technique is to utilize a correlated subquery and the ARRAY() "
+"constructor that converts a row set to an array."
+msgstr ""
+#: reference_constructor.xml:469
+#, no-c-format
+msgid ""
+"    CASE WHEN EXISTS( SELECT w.geom\n"
+"        FROM waterlines w\n"
+"        WHERE ST_Within(w.geom, p.geom)\n"
+"        AND ST_IsClosed(w.geom))\n"
+"    THEN ST_MakePolygon(\n"
+"        ST_LineMerge(ST_Boundary(p.geom)),\n"
+"        ARRAY( SELECT w.geom\n"
+"            AND ST_IsClosed(w.geom)))\n"
+"    ELSE p.geom\n"
+"    END AS geom\n"
+"FROM provinces p;"
+msgstr ""
+#. Tag: refname
+#: reference_constructor.xml:482
+#, no-c-format
+msgid "ST_Point"
+msgstr ""
+#. Tag: refpurpose
+#: reference_constructor.xml:484
+#, no-c-format
+msgid ""
+"Creates a Point with the given coordinate values. Alias for ST_MakePoint."
+msgstr ""
+#: reference_constructor.xml:489
+#, no-c-format
+msgid ""
+"<funcdef>geometry <function>ST_Point</function></funcdef> "
+msgstr ""
+#: reference_constructor.xml:496
+#, no-c-format
+msgid ""
+"<paramdef><type>integer</type> <parameter>srid=unknown</parameter></paramdef>"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:508
+#, no-c-format
+msgid ""
+"Returns an Point with the given X and Y coordinate values. This is the SQL-"
+"MM alias for <xref linkend=\"ST_MakePoint\"/> that takes just X and Y."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:512 reference_constructor.xml:575
+#: reference_constructor.xml:612 reference_constructor.xml:651
+#, no-c-format
+msgid ""
+"Enhanced: 3.2.0 srid as an extra optional argument was added. Older installs "
+"require combining with ST_SetSRID to mark the srid on the geometry."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:513
+#, no-c-format
+msgid "&sqlmm_compliant; SQL-MM 3: 6.1.2"
+msgstr ""
+#. Tag: title
+#: reference_constructor.xml:519
+#, no-c-format
+msgid "Examples: Geometry"
+msgstr ""
+#: reference_constructor.xml:521
+#, no-c-format
+msgid "SELECT ST_Point( -71.104, 42.315);"
+msgstr ""
+#: reference_constructor.xml:522
+#, no-c-format
+msgid "SELECT ST_SetSRID(ST_Point( -71.104, 42.315),4326);"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:524
+#, no-c-format
+msgid "New in 3.2.0: With SRID specified"
+msgstr ""
+#: reference_constructor.xml:525
+#, no-c-format
+msgid "SELECT ST_Point( -71.104, 42.315, 4326);"
+msgstr ""
+#. Tag: title
+#: reference_constructor.xml:529
+#, no-c-format
+msgid "Examples: Geography"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:530
+#, no-c-format
+msgid "Pre-PostGIS 3.2 syntax"
+msgstr ""
+#: reference_constructor.xml:531
+#, no-c-format
+msgid ""
+"SELECT CAST( ST_SetSRID(ST_Point( -71.104, 42.315), 4326) AS geography);"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:532
+#, no-c-format
+msgid "3.2 and on you can include the srid"
+msgstr ""
+#: reference_constructor.xml:533
+#, no-c-format
+msgid "SELECT CAST( ST_Point( -71.104, 42.315, 4326) AS geography);"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:535
+#, no-c-format
+msgid ""
+"PostgreSQL also provides the <varname>::</varname> short-hand for casting"
+msgstr ""
+#: reference_constructor.xml:536
+#, no-c-format
+msgid "SELECT ST_Point( -71.104, 42.315, 4326)::geography;"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:538
+#, no-c-format
+msgid ""
+"If the point coordinates are not in a geodetic coordinate system (such as "
+"WGS84), then they must be reprojected before casting to a geography. In this "
+"example a point in Pennsylvania State Plane feet (SRID 2273) is projected to "
+"WGS84 (SRID 4326)."
+msgstr ""
+#: reference_constructor.xml:542
+#, no-c-format
+msgid ""
+"SELECT ST_Transform(ST_SetSRID( ST_Point( 3637510, 3014852 ), 2273), 4326)::"
+"geography;"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:549
+#, no-c-format
+msgid ""
+", <xref linkend=\"ST_MakePoint\"/>, <xref linkend=\"ST_SetSRID\"/>, <xref "
+"linkend=\"ST_Transform\"/>, <xref linkend=\"ST_PointZ\"/>, <xref linkend="
+"\"ST_PointM\"/>, <xref linkend=\"ST_PointZM\"/>"
+msgstr ""
+#. Tag: refname
+#: reference_constructor.xml:556
+#, no-c-format
+msgid "ST_PointZ"
+msgstr ""
+#. Tag: refpurpose
+#: reference_constructor.xml:557 reference_constructor.xml:594
+#: reference_constructor.xml:632
+#, no-c-format
+msgid "Creates a Point with the given coordinate and SRID values."
+msgstr ""
+#: reference_constructor.xml:562
+#, no-c-format
+msgid ""
+"<funcdef>geometry <function>ST_PointZ</function></funcdef> "
+"<paramdef><type>float</type> <parameter>z</parameter></paramdef> <paramdef "
+"choice=\"opt\"><type>integer</type> <parameter>srid=unknown</parameter></"
+"paramdef>"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:574
+#, no-c-format
+msgid ""
+"Returns an Point with the given X, Y and Z coordinate values, and optionally "
+"an SRID number."
+msgstr ""
+#: reference_constructor.xml:580
+#, no-c-format
+msgid "SELECT ST_PointZ(-71.104, 42.315, 3.4, 4326)"
+msgstr ""
+#: reference_constructor.xml:581
+#, no-c-format
+msgid "SELECT ST_PointZ(-71.104, 42.315, 3.4, srid => 4326)"
+msgstr ""
+#: reference_constructor.xml:582
+#, no-c-format
+msgid "SELECT ST_PointZ(-71.104, 42.315, 3.4)"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:587
+#, no-c-format
+msgid ""
+", <xref linkend=\"ST_Point\"/>, <xref linkend=\"ST_PointM\"/>, <xref linkend="
+"\"ST_PointZM\"/>"
+msgstr ""
+#. Tag: refname
+#: reference_constructor.xml:593
+#, no-c-format
+msgid "ST_PointM"
+msgstr ""
+#: reference_constructor.xml:599
+#, no-c-format
+msgid ""
+"<paramdef><type>float</type> <parameter>m</parameter></paramdef> <paramdef "
+"paramdef>"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:611
+#, no-c-format
+msgid ""
+"Returns an Point with the given X, Y and M coordinate values, and optionally "
+"an SRID number."
+msgstr ""
+#: reference_constructor.xml:617
+#, no-c-format
+msgid "SELECT ST_PointM(-71.104, 42.315, 3.4, 4326)"
+msgstr ""
+#: reference_constructor.xml:618
+#, no-c-format
+msgid "SELECT ST_PointM(-71.104, 42.315, 3.4, srid => 4326)"
+msgstr ""
+#: reference_constructor.xml:619
+#, no-c-format
+msgid "SELECT ST_PointM(-71.104, 42.315, 3.4)"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:624
+#, no-c-format
+msgid ""
+", <xref linkend=\"ST_Point\"/>, <xref linkend=\"ST_PointZ\"/>, <xref linkend="
+"\"ST_PointZM\"/>"
+msgstr ""
+#. Tag: refname
+#: reference_constructor.xml:631
+#, no-c-format
+msgid "ST_PointZM"
+msgstr ""
+#: reference_constructor.xml:637
+#, no-c-format
+msgid ""
+"<funcdef>geometry <function>ST_PointZM</function></funcdef> "
+"paramdef>"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:650
+#, no-c-format
+msgid ""
+"Returns an Point with the given X, Y, Z and M coordinate values, and "
+"optionally an SRID number."
+msgstr ""
+#: reference_constructor.xml:656
+#, no-c-format
+msgid "SELECT ST_PointZM(-71.104, 42.315, 3.4, 4.5, 4326)"
+msgstr ""
+#: reference_constructor.xml:657
+#, no-c-format
+msgid "SELECT ST_PointZM(-71.104, 42.315, 3.4, 4.5, srid => 4326)"
+msgstr ""
+#: reference_constructor.xml:658
+#, no-c-format
+msgid "SELECT ST_PointZM(-71.104, 42.315, 3.4, 4.5)"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:663
+#, no-c-format
+msgid ""
+"\"ST_PointZ\"/>, <xref linkend=\"ST_SetSRID\"/>"
+msgstr ""
+#. Tag: refname
+#: reference_constructor.xml:669
+#, no-c-format
+msgid "ST_Polygon"
+msgstr ""
+#. Tag: refpurpose
+#: reference_constructor.xml:670
+#, no-c-format
+msgid "Creates a Polygon from a LineString with a specified SRID."
+msgstr ""
+#: reference_constructor.xml:675
+#, no-c-format
+msgid ""
+"<funcdef>geometry <function>ST_Polygon</function></funcdef> "
+"<paramdef><type>geometry </type> <parameter>lineString</parameter></"
+"paramdef> <paramdef><type>integer </type> <parameter>srid</parameter></"
+"paramdef>"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:686
+#, no-c-format
+msgid ""
+"Returns a polygon built from the given LineString and sets the spatial "
+"reference system from the <varname>srid</varname>."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:689
+#, no-c-format
+msgid ""
+"ST_Polygon is similar to <xref linkend=\"ST_MakePolygon\"/> Variant 1 with "
+"the addition of setting the SRID."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:691
+#, no-c-format
+msgid ""
+"To create polygons with holes use <xref linkend=\"ST_MakePolygon\"/> Variant "
+"2 and then <xref linkend=\"ST_SetSRID\"/>."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:699
+#, no-c-format
+msgid "&sfs_compliant;"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:700
+#, no-c-format
+msgid "&sqlmm_compliant; SQL-MM 3: 8.3.2"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:708
+#, no-c-format
+msgid "Create a 2D polygon."
+msgstr ""
+#: reference_constructor.xml:709
+#, no-c-format
+msgid ""
+"SELECT ST_AsText( ST_Polygon('LINESTRING(75 29, 77 29, 77 29, 75 29)'::"
+"geometry, 4326) );\n"
+"\n"
+"-- result --\n"
+"POLYGON((75 29, 77 29, 77 29, 75 29))"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:710
+#, no-c-format
+msgid "Create a 3D polygon."
+msgstr ""
+#: reference_constructor.xml:711
+#, no-c-format
+msgid ""
+"SELECT ST_AsEWKT( ST_Polygon( ST_GeomFromEWKT('LINESTRING(75 29 1, 77 29 2, "
+"77 29 3, 75 29 1)'), 4326) );\n"
+"\n"
+"-- result --\n"
+"SRID=4326;POLYGON((75 29 1, 77 29 2, 77 29 3, 75 29 1))"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:718
+#, no-c-format
+msgid ""
+", <xref linkend=\"ST_AsText\"/>, <xref linkend=\"ST_GeomFromEWKT\"/>, <xref "
+"linkend=\"ST_GeomFromText\"/>, <xref linkend=\"ST_LineMerge\"/>, <xref "
+"linkend=\"ST_MakePolygon\"/>"
+msgstr ""
+#. Tag: refname
+#: reference_constructor.xml:725
+#, no-c-format
+msgid "ST_TileEnvelope"
+msgstr ""
+#. Tag: refpurpose
+#: reference_constructor.xml:726
+#, no-c-format
+msgid ""
+"Creates a rectangular Polygon in <ulink url=\"https://en.wikipedia.org/wiki/"
+"Web_Mercator_projection\">Web Mercator</ulink> (SRID:3857) using the <ulink "
+"url=\"https://en.wikipedia.org/wiki/Tiled_web_map\">XYZ tile system</ulink>."
+msgstr ""
+#: reference_constructor.xml:731
+#, no-c-format
+msgid ""
+"<funcdef>geometry <function>ST_TileEnvelope</function></funcdef> "
+"<paramdef><type>integer</type> <parameter>tileZoom</parameter></paramdef> "
+"<paramdef><type>integer</type> <parameter>tileX</parameter></paramdef> "
+"<paramdef><type>integer</type> <parameter>tileY</parameter></paramdef> "
+"<paramdef choice=\"opt\"><type>geometry</type> <parameter>bounds=SRID=3857;"
+"LINESTRING(-20037508.342789 -20037508.342789,20037508.342789 "
+"20037508.342789)</parameter></paramdef> <paramdef choice=\"opt"
+"\"><type>float</type> <parameter>margin=0.0</parameter></paramdef>"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:745
+#, no-c-format
+msgid ""
+"url=\"https://en.wikipedia.org/wiki/Tiled_web_map\">XYZ tile system</ulink>. "
+"By default, the bounds are the in EPSG:3857 using the standard range of the "
+"Web Mercator system (-20037508.342789, 20037508.342789). The optional bounds "
+"parameter can be used to generate envelopes for any tiling scheme: provide a "
+"geometry that has the SRID and extent of the initial \"zoom level zero\" "
+"square within which the tile system is to be inscribed."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:747
+#, no-c-format
+msgid ""
+"The optional margin parameter can be used to grow a tile by the given "
+"percentage, e.g. margin=0.125 grows the tile by 12.5%, which is equivalent "
+"to buffer=512 when extent is 4096, as used in <xref linkend=\"ST_AsMVTGeom\"/"
+">. This is useful to create a tile buffer -- to include data lying outside "
+"of the tile's visible area, but whose existence affects current tile's "
+"rendering. For example, a city name (a geopoint) could be near an edge of a "
+"tile, but the text would need to render on two tiles, even though the "
+"geopoint is located in the visible area of just one tile. Using an expanded "
+"tile in a search would include the city geopoint for both tiles. Use "
+"negative value to shrink the tile instead. Values less than -0.5 are "
+"prohibited because that would eliminate the tile completely. Do not use "
+"margin with ST_AsMVTGeom(). See example in <xref linkend=\"ST_AsMVT\"/>."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:749
+#, no-c-format
+msgid "Enhanced: 3.1.0 Added margin parameter."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:750
+#, no-c-format
+msgid "Availability: 3.0.0"
+msgstr ""
+#. Tag: title
+#: reference_constructor.xml:754
+#, no-c-format
+msgid "Example: Building a tile envelope"
+msgstr ""
+#: reference_constructor.xml:755
+#, no-c-format
+msgid ""
+"SELECT ST_AsText( ST_TileEnvelope(2, 1, 1) );\n"
+"\n"
+" st_astext\n"
+"------------------------------\n"
+" POLYGON((-10018754.1713945 0,-10018754.1713945 10018754.1713945,0 "
+"10018754.1713945,0 0,-10018754.1713945 0))\n"
+"\n"
+"SELECT ST_AsText( ST_TileEnvelope(3, 1, 1, ST_MakeEnvelope(-180, -90, 180, "
+"90, 4326) ) );\n"
+"\n"
+"                      st_astext\n"
+"------------------------------------------------------\n"
+" POLYGON((-135 45,-135 67.5,-90 67.5,-90 45,-135 45))"
+msgstr ""
+#. Tag: refname
+#: reference_constructor.xml:767
+#, no-c-format
+msgid "ST_HexagonGrid"
+msgstr ""
+#. Tag: refpurpose
+#: reference_constructor.xml:768
+#, no-c-format
+msgid ""
+"Returns a set of hexagons and cell indices that completely cover the bounds "
+"of the geometry argument."
+msgstr ""
+#: reference_constructor.xml:773
+#, no-c-format
+msgid ""
+"<funcdef>setof record <function>ST_HexagonGrid</function></funcdef> "
+"<paramdef><type>float8</type> <parameter>size</parameter></paramdef> "
+"<paramdef><type>geometry</type> <parameter>bounds</parameter></paramdef>"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:784
+#, no-c-format
+msgid ""
+"Starts with the concept of a hexagon tiling of the plane. (Not a hexagon "
+"tiling of the globe, this is not the <ulink url=\"https://github.com/uber/"
+"h3\">H3</ulink> tiling scheme.) For a given planar SRS, and a given edge "
+"size, starting at the origin of the SRS, there is one unique hexagonal "
+"tiling of the plane, Tiling(SRS, Size). This function answers the question: "
+"what hexagons in a given Tiling(SRS, Size) overlap with a given bounds."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:796
+#, no-c-format
+msgid ""
+"The SRS for the output hexagons is the SRS provided by the bounds geometry."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:797
+#, no-c-format
+msgid ""
+"Doubling or tripling the edge size of the hexagon generates a new parent "
+"tiling that fits with the origin tiling. Unfortunately, it is not possible "
+"to generate parent hexagon tilings that the child tiles perfectly fit inside."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:805 reference_constructor.xml:861
+#: reference_constructor.xml:904 reference_constructor.xml:963
+#, no-c-format
+msgid "Availability: 3.1.0"
+msgstr ""
+#. Tag: title
+#: reference_constructor.xml:810
+#, no-c-format
+msgid "Example: Counting points in hexagons"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:811
+#, no-c-format
+msgid ""
+"To do a point summary against a hexagonal tiling, generate a hexagon grid "
+"using the extent of the points as the bounds, then spatially join to that "
+"grid."
+msgstr ""
+#: reference_constructor.xml:813
+#, no-c-format
+msgid ""
+"SELECT COUNT(*), hexes.geom\n"
+"FROM\n"
+"    ST_HexagonGrid(\n"
+"        10000,\n"
+"        ST_SetSRID(ST_EstimatedExtent('pointtable', 'geom'), 3857)\n"
+"    ) AS hexes\n"
+"    INNER JOIN\n"
+"    pointtable AS pts\n"
+"    ON ST_Intersects(pts.geom, hexes.geom)\n"
+"GROUP BY hexes.geom;"
+msgstr ""
+#. Tag: title
+#: reference_constructor.xml:816
+#, no-c-format
+msgid "Example: Generating hex coverage of polygons"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:817
+#, no-c-format
+msgid ""
+"If we generate a set of hexagons for each polygon boundary and filter out "
+"those that do not intersect their hexagons, we end up with a tiling for each "
+"polygon."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:823
+#, no-c-format
+msgid ""
+"Tiling states results in a hexagon coverage of each state, and multiple "
+"hexagons overlapping at the borders between states."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:825
+#, no-c-format
+msgid ""
+"The LATERAL keyword is implied for set-returning functions when referring to "
+"a prior table in the FROM list. So CROSS JOIN LATERAL, CROSS JOIN, or just "
+"plain , are equivalent constructs for this example."
+msgstr ""
+#: reference_constructor.xml:826
+#, no-c-format
+msgid ""
+"SELECT admin1.gid, hex.geom\n"
+"FROM\n"
+"    admin1\n"
+"    CROSS JOIN\n"
+"    ST_HexagonGrid(100000, admin1.geom) AS hex\n"
+"WHERE\n"
+"    adm0_a3 = 'USA'\n"
+"    AND\n"
+"    ST_Intersects(admin1.geom, hex.geom)"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:830
+#, no-c-format
+msgid ""
+", <xref linkend=\"ST_SetSRID\"/>, <xref linkend=\"ST_SquareGrid\"/>, <xref "
+msgstr ""
+#. Tag: refname
+#: reference_constructor.xml:836
+#, no-c-format
+msgid "ST_Hexagon"
+msgstr ""
+#. Tag: refpurpose
+#: reference_constructor.xml:837
+#, no-c-format
+msgid ""
+"Returns a single hexagon, using the provided edge size and cell coordinate "
+"within the hexagon grid space."
+msgstr ""
+#: reference_constructor.xml:843
+#, no-c-format
+msgid ""
+"<funcdef>geometry <function>ST_Hexagon</function></funcdef> "
+"<paramdef><type>integer</type> <parameter>cell_i</parameter></paramdef> "
+"<paramdef><type>integer</type> <parameter>cell_j</parameter></paramdef> "
+"<paramdef choice=\"opt\"><type>geometry</type> <parameter>origin</"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:856
+#, no-c-format
+msgid ""
+"Uses the same hexagon tiling concept as <xref linkend=\"ST_HexagonGrid\"/>, "
+"but generates just one hexagon at the desired cell coordinate. Optionally, "
+"can adjust origin coordinate of the tiling, the default origin is at 0,0."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:859
+#, no-c-format
+msgid ""
+"Hexagons are generated with no SRID set, so use <xref linkend=\"ST_SetSRID\"/"
+"> to set the SRID to the one you expect."
+msgstr ""
+#. Tag: title
+#: reference_constructor.xml:865
+#, no-c-format
+msgid "Example: Creating a hexagon at the origin"
+msgstr ""
+#: reference_constructor.xml:866
+#, no-c-format
+msgid ""
+"SELECT ST_AsText(ST_SetSRID(ST_Hexagon(1.0, 0, 0), 3857));\n"
+"\n"
+"POLYGON((-1 0,-0.5\n"
+"         -0.866025403784439,0.5\n"
+"         -0.866025403784439,1\n"
+"         0,0.5\n"
+"         0.866025403784439,-0.5\n"
+"         0.866025403784439,-1 0))"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:870
+#, no-c-format
+msgid ", <xref linkend=\"ST_HexagonGrid\"/>, <xref linkend=\"ST_Square\"/>"
+msgstr ""
+#. Tag: refname
+#: reference_constructor.xml:876
+#, no-c-format
+msgid "ST_SquareGrid"
+msgstr ""
+#. Tag: refpurpose
+#: reference_constructor.xml:877
+#, no-c-format
+msgid ""
+"Returns a set of grid squares and cell indices that completely cover the "
+"bounds of the geometry argument."
+msgstr ""
+#: reference_constructor.xml:882
+#, no-c-format
+msgid ""
+"<funcdef>setof record <function>ST_SquareGrid</function></funcdef> "
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:893
+#, no-c-format
+msgid ""
+"Starts with the concept of a square tiling of the plane. For a given planar "
+"SRS, and a given edge size, starting at the origin of the SRS, there is one "
+"unique square tiling of the plane, Tiling(SRS, Size). This function answers "
+"the question: what grids in a given Tiling(SRS, Size) overlap with a given "
+"bounds."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:899
+#, no-c-format
+msgid ""
+"The SRS for the output squares is the SRS provided by the bounds geometry."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:900
+#, no-c-format
+msgid ""
+"Doubling or edge size of the square generates a new parent tiling that "
+"perfectly fits with the original tiling. Standard web map tilings in "
+"mercator are just powers-of-two square grids in the mercator plane."
+msgstr ""
+#. Tag: title
+#: reference_constructor.xml:909
+#, no-c-format
+msgid "Example: Generating a 1 degree grid for a country"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:910
+#, no-c-format
+msgid ""
+"The grid will fill the whole bounds of the country, so if you want just "
+"squares that touch the country you will have to filter afterwards with "
+"ST_Intersects."
+msgstr ""
+#: reference_constructor.xml:912
+#, no-c-format
+msgid ""
+"WITH grid AS (\n"
+"SELECT (ST_SquareGrid(1, ST_Transform(geom,4326))).*\n"
+"FROM admin0 WHERE name = 'Canada'\n"
+")\n"
+"  SELEcT ST_AsText(geom)\n"
+"  FROM grid"
+msgstr ""
+#. Tag: title
+#: reference_constructor.xml:916
+#, no-c-format
+msgid "Example: Counting points in squares (using single chopped grid)"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:917
+#, no-c-format
+msgid ""
+"To do a point summary against a square tiling, generate a square grid using "
+"the extent of the points as the bounds, then spatially join to that grid. "
+"Note the estimated extent might be off from actual extent, so be cautious "
+"and at very least make sure you've analyzed your table."
+msgstr ""
+#: reference_constructor.xml:919
+#, no-c-format
+msgid ""
+"SELECT COUNT(*), squares.geom\n"
+"    FROM\n"
+"    INNER JOIN\n"
+"    ST_SquareGrid(\n"
+"        1000,\n"
+"    ) AS squares\n"
+"    ON ST_Intersects(pts.geom, squares.geom)\n"
+"    GROUP BY squares.geom"
+msgstr ""
+#. Tag: title
+#: reference_constructor.xml:923
+#, no-c-format
+msgid "Example: Counting points in squares using set of grid per point"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:924
+#, no-c-format
+msgid ""
+"This yields the same result as the first example but will be slower for a "
+"large number of points"
+msgstr ""
+#: reference_constructor.xml:925
+#, no-c-format
+msgid ""
+"    FROM\n"
+"    INNER JOIN\n"
+"        1000,\n"
+"       pts.geom\n"
+"    ) AS squares\n"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:930
+#, no-c-format
+msgid ""
+", <xref linkend=\"ST_HexagonGrid\"/> , <xref linkend=\"ST_EstimatedExtent\"/"
+"> , <xref linkend=\"ST_SetSRID\"/>"
+msgstr ""
+#. Tag: refname
+#: reference_constructor.xml:938
+#, no-c-format
+msgid "ST_Square"
+msgstr ""
+#. Tag: refpurpose
+#: reference_constructor.xml:939
+#, no-c-format
+msgid ""
+"Returns a single square, using the provided edge size and cell coordinate "
+"within the square grid space."
+msgstr ""
+#: reference_constructor.xml:945
+#, no-c-format
+msgid ""
+"<funcdef>geometry <function>ST_Square</function></funcdef> "
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:958
+#, no-c-format
+msgid ""
+"Uses the same square tiling concept as <xref linkend=\"ST_SquareGrid\"/>, "
+"but generates just one square at the desired cell coordinate. Optionally, "
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:961
+#, no-c-format
+msgid ""
+"Squares are generated with no SRID set, so use <xref linkend=\"ST_SetSRID\"/"
+msgstr ""
+#. Tag: title
+#: reference_constructor.xml:967
+#, no-c-format
+msgid "Example: Creating a square at the origin"
+msgstr ""
+#: reference_constructor.xml:968
+#, no-c-format
+msgid ""
+"SELECT ST_AsText(ST_SetSRID(ST_Square(1.0, 0, 0), 3857));\n"
+"\n"
+" POLYGON((0 0,0 1,1 1,1 0,0 0))"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:972
+#, no-c-format
+msgid ", <xref linkend=\"ST_SquareGrid\"/>, <xref linkend=\"ST_Hexagon\"/>"
+msgstr ""
+#. Tag: refname
+#: reference_constructor.xml:980
+#, no-c-format
+msgid "ST_Letters"
+msgstr ""
+#. Tag: refpurpose
+#: reference_constructor.xml:981
+#, no-c-format
+msgid ""
+"Returns the input letters rendered as geometry with a default start position "
+"at the origin and default text height of 100."
+msgstr ""
+#: reference_constructor.xml:985
+#, no-c-format
+msgid ""
+"<funcdef>geometry <function>ST_Letters</function></funcdef> "
+"<paramdef><type>text</type> <parameter> letters</parameter></paramdef> "
+"<paramdef choice=\"opt\"><type>json</type> <parameter> font</parameter></"
+"paramdef>"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:996
+#, no-c-format
+msgid ""
+"Uses a built-in font to render out a string as a multipolygon geometry. The "
+"default text height is 100.0, the distance from the bottom of a descender to "
+"the top of a capital. The default start position places the start of the "
+"baseline at the origin. Over-riding the font involves passing in a json map, "
+"with a character as the key, and base64 encoded TWKB for the font shape, "
+"with the fonts having a height of 1000 units from the bottom of the "
+"descenders to the tops of the capitals."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:999
+#, no-c-format
+msgid ""
+"The text is generated at the origin by default, so to reposition and resize "
+"the text, first apply the <code>ST_Scale</code> function and then apply the "
+"<code>ST_Translate</code> function."
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:1001
+#, no-c-format
+msgid "Availability: 3.3.0"
+msgstr ""
+#. Tag: title
+#: reference_constructor.xml:1005
+#, no-c-format
+msgid "Example: Generating the word 'Yo'"
+msgstr ""
+#: reference_constructor.xml:1006
+#, no-c-format
+msgid "SELECT ST_AsText(ST_Letters('Yo'), 1);"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:1012
+#, no-c-format
+msgid "Letters generated by ST_Letters"
+msgstr ""
+#. Tag: title
+#: reference_constructor.xml:1017
+#, no-c-format
+msgid "Example: Scaling and moving words"
+msgstr ""
+#: reference_constructor.xml:1018
+#, no-c-format
+msgid "SELECT ST_Translate(ST_Scale(ST_Letters('Yo'), 10, 10), 100,100);"
+msgstr ""
+#. Tag: para
+#: reference_constructor.xml:1022
+#, no-c-format
+msgid ", <xref linkend=\"ST_Scale\"/>, <xref linkend=\"ST_Translate\"/>"
+msgstr ""
Summary of changes:
 .../reference_constructor.xml.po}                                   | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
 copy doc/po/{templates/reference_constructor.xml.pot => zh_Hans/reference_constructor.xml.po} (99%)
hooks/post-receive
