[postgis-tickets] [PostGIS] #5120: ST_EstimatedExtent returns stats based extent even if index is present
PostGIS trac at osgeo.org
Tue Mar 29 16:13:31 PDT 2022
  Reporter:  strk     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.3.0
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Comment (by strk):
 Interesting enough, commented-out tests in
 regress/core/estimatedextent.sql show that even the index-provided read
 can be dirty, and only becomes accurate on VACUUM FULL. Still, it at least
 possible to make it accurate (by runnign VACUUM) while this is impossible
 to do with pg_statistic, looks like.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5120#comment:1>
