[postgis-tickets] [PostGIS] #5120: ST_EstimatedExtent returns stats based extent even if index is present
PostGIS trac at osgeo.org
Tue Mar 29 16:51:48 PDT 2022
  Reporter:  strk     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.3.0
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Comment (by strk):
 I've pushed a fix for this case. I'm tempted to backport it but I wonder
 if others have a different view on the matter. Paul ?
 Basically the question is: is there ANY reason why a NULL gbox fetched
 from an index found by table_get_spatial_index should not be trusted by
 ST_EstimatedExtent ?
 I don't see any reason for that. If index knows no BOX the table *must* be
 empty (while it *could* be empty when the index returns an actual box, due
 to pending vacuum ...)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5120#comment:3>
