[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-685-g854103fa2
Wed Mar 30 11:42:04 PDT 2022
the project "PostGIS".
       via  854103fa2e087b53485c8cf403a1fcb952146be2 (commit)
       via  efa1da72fced9c04a7debbdf22e5d5290c47b9f5 (commit)
      from  856a9a98d6729c3b581f4f0ce153fdc908792719 (commit)
revisions in full, below.
commit 854103fa2e087b53485c8cf403a1fcb952146be2
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Mar 30 12:39:33 2022 +0200
    Add index on relation(element_id) and use it from RemEdge functions
    Closes #2083
diff --git a/NEWS b/NEWS
index 173815cd2..cdbfff631 100644
--- a/NEWS
+++ b/NEWS
@@ -5,6 +5,8 @@ PostGIS 3.3.0dev
   - Drop support for PostgreSQL 9.6 and 10 (Regina Obe)
  * Enhancements *
+  - #2083, Add index on topology.relation(element_id) and use it from
+    RemEdge functions (Sandro Santilli)
   - #5118, Allow dropping topologies with missing topogeometry sequences
     (Sandro Santilli)
   - #5111, faster topology face MBR computation (Sandro Santilli)
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index bd5aeb137..e1e9076af 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -2194,7 +2194,8 @@ cb_updateTopoGeomEdgeSplit ( const LWT_BE_TOPOLOGY* topo,
   appendStringInfo( sql, " FROM \"%s\".relation r %s topology.layer l WHERE "
                     "l.topology_id = %d AND l.level = 0 AND l.layer_id = r.layer_id "
-                    "AND abs(r.element_id) = %" LWTFMT_ELEMID " AND r.element_type = 2",
+                    "AND r.element_id IN ( %" LWTFMT_ELEMID ", -%" LWTFMT_ELEMID
+                    ") AND r.element_type = 2",
                     topo->name, (new_edge2 == -1 ? "," : "USING" ), topo->id, split_edge );
   if ( new_edge2 != -1 )
diff --git a/topology/sql/manage/CreateTopology.sql.in b/topology/sql/manage/CreateTopology.sql.in
index 202cae33a..75cd3b956 100644
--- a/topology/sql/manage/CreateTopology.sql.in
+++ b/topology/sql/manage/CreateTopology.sql.in
@@ -183,6 +183,12 @@ BEGIN
         element_type integer NOT NULL,
         UNIQUE(layer_id,topogeo_id,element_id,element_type)
+      ------- Add index on element_type, element_id to speed up
+      ------- queries looking for TopoGeometries using specific
+      ------- primitive elements of the topology
+      ------- See http://trac.osgeo.org/postgis/ticket/2083
+      CREATE INDEX relation_element_id_idx
+        ON %1$I.relation (element_id);
       CREATE TRIGGER relation_integrity_checks
       BEFORE UPDATE OR INSERT ON %1$I.relation
commit efa1da72fced9c04a7debbdf22e5d5290c47b9f5
Date:   Wed Mar 30 12:21:05 2022 +0200
    Put CreateTopology function in its own file
new file mode 100644
index 000000000..202cae33a
--- /dev/null
@@ -0,0 +1,271 @@
+-- PostGIS - Spatial Types for PostgreSQL
+-- http://postgis.net
+-- Copyright (C) 2010, 2011 Sandro Santilli <strk at kbt.io>
+-- Copyright (C) 2005 Refractions Research Inc.
+-- This is free software; you can redistribute and/or modify it under
+-- the terms of the GNU General Public Licence. See the COPYING file.
+-- Author: Sandro Santilli <strk at kbt.io>
+--  CreateTopology(name, SRID, precision, hasZ)
+-- Create a topology schema, add a topology info record
+-- in the topology.topology relation, return it's numeric
+-- id.
+CREATE OR REPLACE FUNCTION topology.CreateTopology(atopology varchar, srid integer, prec float8, hasZ boolean)
+RETURNS integer
+AS
+$BODY$
+DECLARE
+  rec RECORD;
+  topology_id integer;
+  sql TEXT;
+  zsuffix TEXT := '';
+BEGIN
+--  FOR rec IN SELECT * FROM pg_namespace WHERE text(nspname) = atopology
+--  LOOP
+--    RAISE EXCEPTION 'SQL/MM Spatial exception - schema already exists';
+--  END LOOP;
+  IF hasZ THEN
+    zsuffix := 'z';
+  END IF;
+  IF srid < 0 THEN
+    RAISE NOTICE 'SRID value % converted to the officially unknown SRID value 0', srid;
+    srid = 0;
+  END IF;
+  ------ Fetch next id for the new topology
+  FOR rec IN SELECT nextval('topology.topology_id_seq')
+  LOOP
+    topology_id = rec.nextval;
+  END LOOP;
+  sql := format(
+      CREATE SCHEMA %1$I;
+      -------------{ face CREATION
+      CREATE TABLE %1$I.face(
+        face_id SERIAL,
+        mbr GEOMETRY(polygon, %2$L), -- 2d only mbr is good enough
+        CONSTRAINT face_primary_key
+        PRIMARY KEY(face_id)
+      -- Face standard view description
+      COMMENT ON TABLE %1$I.face IS
+      'Contains face topology primitives';
+      -------------} END OF face CREATION
+      --------------{ node CREATION
+      CREATE TABLE %1$I.node(
+        node_id SERIAL,
+        containing_face INTEGER,
+        geom GEOMETRY(point%3$s, %2$L),
+        CONSTRAINT node_primary_key
+          PRIMARY KEY(node_id),
+        CONSTRAINT face_exists
+          FOREIGN KEY(containing_face)
+          REFERENCES %1$I.face(face_id)
+      -- Node standard view description
+      COMMENT ON TABLE %1$I.node IS
+      'Contains node topology primitives';
+      --------------} END OF node CREATION
+      --------------{ edge CREATION
+      -- edge_data table
+      CREATE TABLE %1$I.edge_data (
+        edge_id SERIAL NOT NULL PRIMARY KEY,
+        start_node INTEGER NOT NULL,
+        end_node INTEGER NOT NULL,
+        next_left_edge INTEGER NOT NULL,
+        abs_next_left_edge INTEGER NOT NULL,
+        next_right_edge INTEGER NOT NULL,
+        abs_next_right_edge INTEGER NOT NULL,
+        left_face INTEGER NOT NULL,
+        right_face INTEGER NOT NULL,
+        geom GEOMETRY(linestring%3$s, %2$L) NOT NULL,
+        CONSTRAINT start_node_exists
+          FOREIGN KEY(start_node)
+          REFERENCES %1$I.node(node_id),
+        CONSTRAINT end_node_exists
+          FOREIGN KEY(end_node)
+        CONSTRAINT left_face_exists
+          FOREIGN KEY(left_face)
+          REFERENCES %1$I.face(face_id),
+        CONSTRAINT right_face_exists
+          FOREIGN KEY(right_face)
+        CONSTRAINT next_left_edge_exists
+          FOREIGN KEY(abs_next_left_edge)
+          REFERENCES %1$I.edge_data(edge_id)
+          DEFERRABLE INITIALLY DEFERRED,
+        CONSTRAINT next_right_edge_exists
+          FOREIGN KEY(abs_next_right_edge)
+          REFERENCES %1$I .edge_data(edge_id)
+      -- edge standard view (select rule)
+      CREATE VIEW %1$I.edge AS
+      SELECT
+        edge_id, start_node, end_node, next_left_edge,
+        next_right_edge, left_face, right_face, geom
+      FROM %1$I.edge_data;
+      -- Edge standard view description
+      COMMENT ON VIEW %1$I.edge IS
+      'Contains edge topology primitives';
+      COMMENT ON COLUMN %1$I.edge.edge_id IS
+      'Unique identifier of the edge';
+      COMMENT ON COLUMN %1$I.edge.start_node IS
+      'Unique identifier of the node at the start of the edge';
+      COMMENT ON COLUMN %1$I.edge.end_node IS
+      'Unique identifier of the node at the end of the edge';
+      COMMENT ON COLUMN %1$I.edge.next_left_edge IS
+      'Unique identifier of the next edge of the face on the left (when looking in the direction from START_NODE to END_NODE), moving counterclockwise around the face boundary';
+      COMMENT ON COLUMN %1$I.edge.next_right_edge IS
+      'Unique identifier of the next edge of the face on the right (when looking in the direction from START_NODE to END_NODE), moving counterclockwise around the face boundary';
+      COMMENT ON COLUMN %1$I.edge.left_face IS
+      'Unique identifier of the face on the left side of the edge when looking in the direction from START_NODE to END_NODE';
+      COMMENT ON COLUMN %1$I.edge.right_face IS
+      'Unique identifier of the face on the right side of the edge when looking in the direction from START_NODE to END_NODE';
+      COMMENT ON COLUMN %1$I.edge.geom IS
+      'The geometry of the edge';
+      -- edge standard view (insert rule)
+      CREATE RULE edge_insert_rule AS
+      ON INSERT TO %1$I.edge
+      DO INSTEAD INSERT into %1$I.edge_data
+      VALUES (
+        NEW.edge_id, NEW.start_node, NEW.end_node,
+        NEW.next_left_edge, abs(NEW.next_left_edge),
+        NEW.next_right_edge, abs(NEW.next_right_edge),
+        NEW.left_face, NEW.right_face, NEW.geom
+      --------------} END OF edge CREATION
+      --------------{ layer sequence
+      CREATE SEQUENCE %1$I.layer_id_seq;
+      --------------} layer sequence
+      --------------{ relation CREATION
+      CREATE TABLE %1$I.relation (
+        topogeo_id integer NOT NULL,
+        layer_id integer NOT NULL,
+        element_id integer NOT NULL,
+        element_type integer NOT NULL,
+        UNIQUE(layer_id,topogeo_id,element_id,element_type)
+      CREATE TRIGGER relation_integrity_checks
+      BEFORE UPDATE OR INSERT ON %1$I.relation
+      FOR EACH ROW EXECUTE PROCEDURE
+      topology.RelationTrigger(%4$L, %1$L);
+      --------------} END OF relation CREATION
+      ------- Default (world) face
+      INSERT INTO %1$I.face(face_id) VALUES(0);
+      ------- GiST index on face
+      CREATE INDEX face_gist ON %1$I.face
+      USING gist (mbr);
+      ------- GiST index on node
+      CREATE INDEX node_gist ON %1$I.node
+      USING gist (geom);
+      ------- GiST index on edge
+      CREATE INDEX edge_gist ON %1$I.edge_data
+      ------- Indexes on left_face and right_face of edge_data
+      ------- NOTE: these indexes speed up GetFaceGeometry (and thus
+      -------       TopoGeometry::Geometry) by a factor of 10 !
+      -------       See http://trac.osgeo.org/postgis/ticket/806
+      CREATE INDEX edge_left_face_idx
+        ON %1$I.edge_data (left_face);
+      CREATE INDEX edge_right_face_idx
+        ON %1$I.edge_data (right_face);
+      ------- Indexes on start_node and end_node of edge_data
+      ------- NOTE: this indexes speed up node deletion
+      -------       by a factor of 1000 !
+      -------       See http://trac.osgeo.org/postgis/ticket/2082
+      CREATE INDEX edge_start_node_idx
+        ON %1$I.edge_data (start_node);
+      CREATE INDEX edge_end_node_idx
+        ON %1$I.edge_data (end_node);
+      -- TODO: consider also adding an index on node.containing_face
+    atopology,   -- %1
+    srid,        -- %2
+    zsuffix,     -- %3
+    topology_id  -- %4
+#ifdef POSTGIS_TOPOLOGY_DEBUG
+  RAISE DEBUG 'SQL: %', sql;
+#endif
+  EXECUTE sql;
+  ------- Add record to the "topology" metadata table
+  INSERT INTO topology.topology (id, name, srid, precision, hasZ)
+  VALUES (topology_id, atopology, srid, prec, hasZ);
+  RETURN topology_id;
+END
+$BODY$
+LANGUAGE 'plpgsql' VOLATILE STRICT;
+--} CreateTopology
+--{ CreateTopology wrappers for unspecified srid or precision or hasZ
+--  CreateTopology(name, SRID, precision) -- hasZ = false
+CREATE OR REPLACE FUNCTION topology.CreateTopology(toponame varchar, srid integer, prec float8)
+RETURNS integer AS
+' SELECT topology.CreateTopology($1, $2, $3, false);'
+LANGUAGE 'sql' VOLATILE STRICT;
+--  CreateTopology(name, SRID) -- precision = 0
+CREATE OR REPLACE FUNCTION topology.CreateTopology(varchar, integer)
+RETURNS integer AS
+' SELECT topology.CreateTopology($1, $2, 0); '
+--  CreateTopology(name) -- srid = unknown, precision = 0
+CREATE OR REPLACE FUNCTION topology.CreateTopology(varchar)
+RETURNS integer AS
+$$ SELECT topology.CreateTopology($1, ST_SRID('POINT EMPTY'::geometry), 0); $$
+--} CreateTopology
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index c7f4e3063..ebc62a5af 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -1435,261 +1435,6 @@ LANGUAGE 'plpgsql' VOLATILE STRICT;
 -- 7.3+ explicit cast
 CREATE CAST (topology.TopoGeometry AS Geometry) WITH FUNCTION topology.Geometry(topology.TopoGeometry) AS IMPLICIT;
---  CreateTopology(name, SRID, precision, hasZ)
--- Create a topology schema, add a topology info record
--- in the topology.topology relation, return it's numeric
--- id.
-CREATE OR REPLACE FUNCTION topology.CreateTopology(atopology varchar, srid integer, prec float8, hasZ boolean)
-RETURNS integer
-AS
-$BODY$
-DECLARE
-  rec RECORD;
-  topology_id integer;
-  sql TEXT;
-  zsuffix TEXT := '';
-BEGIN
---  FOR rec IN SELECT * FROM pg_namespace WHERE text(nspname) = atopology
---  LOOP
---    RAISE EXCEPTION 'SQL/MM Spatial exception - schema already exists';
---  END LOOP;
-  IF hasZ THEN
-    zsuffix := 'z';
-  END IF;
-  IF srid < 0 THEN
-    RAISE NOTICE 'SRID value % converted to the officially unknown SRID value 0', srid;
-    srid = 0;
-  END IF;
-  ------ Fetch next id for the new topology
-  FOR rec IN SELECT nextval('topology.topology_id_seq')
-  LOOP
-    topology_id = rec.nextval;
-  END LOOP;
-  sql := format(
-      CREATE SCHEMA %1$I;
-      -------------{ face CREATION
-      CREATE TABLE %1$I.face(
-        face_id SERIAL,
-        mbr GEOMETRY(polygon, %2$L), -- 2d only mbr is good enough
-        CONSTRAINT face_primary_key
-        PRIMARY KEY(face_id)
-      -- Face standard view description
-      COMMENT ON TABLE %1$I.face IS
-      'Contains face topology primitives';
-      -------------} END OF face CREATION
-      --------------{ node CREATION
-      CREATE TABLE %1$I.node(
-        node_id SERIAL,
-        containing_face INTEGER,
-        geom GEOMETRY(point%3$s, %2$L),
-        CONSTRAINT node_primary_key
-          PRIMARY KEY(node_id),
-        CONSTRAINT face_exists
-          FOREIGN KEY(containing_face)
-          REFERENCES %1$I.face(face_id)
-      -- Node standard view description
-      COMMENT ON TABLE %1$I.node IS
-      'Contains node topology primitives';
-      --------------} END OF node CREATION
-      --------------{ edge CREATION
-      -- edge_data table
-      CREATE TABLE %1$I.edge_data (
-        edge_id SERIAL NOT NULL PRIMARY KEY,
-        start_node INTEGER NOT NULL,
-        end_node INTEGER NOT NULL,
-        next_left_edge INTEGER NOT NULL,
-        abs_next_left_edge INTEGER NOT NULL,
-        next_right_edge INTEGER NOT NULL,
-        abs_next_right_edge INTEGER NOT NULL,
-        left_face INTEGER NOT NULL,
-        right_face INTEGER NOT NULL,
-        geom GEOMETRY(linestring%3$s, %2$L) NOT NULL,
-        CONSTRAINT start_node_exists
-          FOREIGN KEY(start_node)
-          REFERENCES %1$I.node(node_id),
-        CONSTRAINT end_node_exists
-          FOREIGN KEY(end_node)
-        CONSTRAINT left_face_exists
-          FOREIGN KEY(left_face)
-          REFERENCES %1$I.face(face_id),
-        CONSTRAINT right_face_exists
-          FOREIGN KEY(right_face)
-        CONSTRAINT next_left_edge_exists
-          FOREIGN KEY(abs_next_left_edge)
-          REFERENCES %1$I.edge_data(edge_id)
-          DEFERRABLE INITIALLY DEFERRED,
-        CONSTRAINT next_right_edge_exists
-          FOREIGN KEY(abs_next_right_edge)
-          REFERENCES %1$I .edge_data(edge_id)
-      -- edge standard view (select rule)
-      CREATE VIEW %1$I.edge AS
-      SELECT
-        edge_id, start_node, end_node, next_left_edge,
-        next_right_edge, left_face, right_face, geom
-      FROM %1$I.edge_data;
-      -- Edge standard view description
-      COMMENT ON VIEW %1$I.edge IS
-      'Contains edge topology primitives';
-      COMMENT ON COLUMN %1$I.edge.edge_id IS
-      'Unique identifier of the edge';
-      COMMENT ON COLUMN %1$I.edge.start_node IS
-      'Unique identifier of the node at the start of the edge';
-      COMMENT ON COLUMN %1$I.edge.end_node IS
-      'Unique identifier of the node at the end of the edge';
-      COMMENT ON COLUMN %1$I.edge.next_left_edge IS
-      'Unique identifier of the next edge of the face on the left (when looking in the direction from START_NODE to END_NODE), moving counterclockwise around the face boundary';
-      COMMENT ON COLUMN %1$I.edge.next_right_edge IS
-      'Unique identifier of the next edge of the face on the right (when looking in the direction from START_NODE to END_NODE), moving counterclockwise around the face boundary';
-      COMMENT ON COLUMN %1$I.edge.left_face IS
-      'Unique identifier of the face on the left side of the edge when looking in the direction from START_NODE to END_NODE';
-      COMMENT ON COLUMN %1$I.edge.right_face IS
-      'Unique identifier of the face on the right side of the edge when looking in the direction from START_NODE to END_NODE';
-      COMMENT ON COLUMN %1$I.edge.geom IS
-      'The geometry of the edge';
-      -- edge standard view (insert rule)
-      CREATE RULE edge_insert_rule AS
-      ON INSERT TO %1$I.edge
-      DO INSTEAD INSERT into %1$I.edge_data
-      VALUES (
-        NEW.edge_id, NEW.start_node, NEW.end_node,
-        NEW.next_left_edge, abs(NEW.next_left_edge),
-        NEW.next_right_edge, abs(NEW.next_right_edge),
-        NEW.left_face, NEW.right_face, NEW.geom
-      --------------} END OF edge CREATION
-      --------------{ layer sequence
-      CREATE SEQUENCE %1$I.layer_id_seq;
-      --------------} layer sequence
-      --------------{ relation CREATION
-      CREATE TABLE %1$I.relation (
-        topogeo_id integer NOT NULL,
-        layer_id integer NOT NULL,
-        element_id integer NOT NULL,
-        element_type integer NOT NULL,
-        UNIQUE(layer_id,topogeo_id,element_id,element_type)
-      CREATE TRIGGER relation_integrity_checks
-      BEFORE UPDATE OR INSERT ON %1$I.relation
-      FOR EACH ROW EXECUTE PROCEDURE
-      topology.RelationTrigger(%4$L, %1$L);
-      --------------} END OF relation CREATION
-      ------- Default (world) face
-      INSERT INTO %1$I.face(face_id) VALUES(0);
-      ------- GiST index on face
-      CREATE INDEX face_gist ON %1$I.face
-      USING gist (mbr);
-      ------- GiST index on node
-      CREATE INDEX node_gist ON %1$I.node
-      USING gist (geom);
-      ------- GiST index on edge
-      CREATE INDEX edge_gist ON %1$I.edge_data
-      ------- Indexes on left_face and right_face of edge_data
-      ------- NOTE: these indexes speed up GetFaceGeometry (and thus
-      -------       TopoGeometry::Geometry) by a factor of 10 !
-      -------       See http://trac.osgeo.org/postgis/ticket/806
-      CREATE INDEX edge_left_face_idx
-        ON %1$I.edge_data (left_face);
-      CREATE INDEX edge_right_face_idx
-        ON %1$I.edge_data (right_face);
-      ------- Indexes on start_node and end_node of edge_data
-      ------- NOTE: this indexes speed up node deletion
-      -------       by a factor of 1000 !
-      -------       See http://trac.osgeo.org/postgis/ticket/2082
-      CREATE INDEX edge_start_node_idx
-        ON %1$I.edge_data (start_node);
-      CREATE INDEX edge_end_node_idx
-        ON %1$I.edge_data (end_node);
-      -- TODO: consider also adding an index on node.containing_face
-    atopology,   -- %1
-    srid,        -- %2
-    zsuffix,     -- %3
-    topology_id  -- %4
-#ifdef POSTGIS_TOPOLOGY_DEBUG
-  RAISE DEBUG 'SQL: %', sql;
-#endif
-  EXECUTE sql;
-  ------- Add record to the "topology" metadata table
-  INSERT INTO topology.topology (id, name, srid, precision, hasZ)
-  VALUES (topology_id, atopology, srid, prec, hasZ);
-  RETURN topology_id;
-END
-$BODY$
-LANGUAGE 'plpgsql' VOLATILE STRICT;
---} CreateTopology
---{ CreateTopology wrappers for unspecified srid or precision or hasZ
---  CreateTopology(name, SRID, precision) -- hasZ = false
-CREATE OR REPLACE FUNCTION topology.CreateTopology(toponame varchar, srid integer, prec float8)
-RETURNS integer AS
-' SELECT topology.CreateTopology($1, $2, $3, false);'
-LANGUAGE 'sql' VOLATILE STRICT;
---  CreateTopology(name, SRID) -- precision = 0
-CREATE OR REPLACE FUNCTION topology.CreateTopology(varchar, integer)
-RETURNS integer AS
-' SELECT topology.CreateTopology($1, $2, 0); '
---  CreateTopology(name) -- srid = unknown, precision = 0
-CREATE OR REPLACE FUNCTION topology.CreateTopology(varchar)
-RETURNS integer AS
-$$ SELECT topology.CreateTopology($1, ST_SRID('POINT EMPTY'::geometry), 0); $$
---} CreateTopology
 --  DropTopology(name)
@@ -1822,6 +1567,7 @@ LANGUAGE 'plpgsql' VOLATILE STRICT;
 --general management --
 #include "sql/manage/ManageHelper.sql.in"
+#include "sql/manage/CreateTopology.sql.in"
 #include "sql/manage/TopologySummary.sql.in"
 #include "sql/manage/CopyTopology.sql.in"
 #include "sql/manage/FindTopology.sql.in"
Summary of changes:
 NEWS                                      |   2 +
 topology/postgis_topology.c               |   3 +-
 topology/sql/manage/CreateTopology.sql.in | 277 ++++++++++++++++++++++++++++++
 topology/topology.sql.in                  | 256 +--------------------------
 4 files changed, 282 insertions(+), 256 deletions(-)
 create mode 100644 topology/sql/manage/CreateTopology.sql.in
hooks/post-receive
