[postgis-tickets] [PostGIS] #2083: ST_RemEdgeModFace performance review
PostGIS trac at osgeo.org
Thu Mar 31 03:11:14 PDT 2022
  Reporter:  strk         |      Owner:  strk
      Type:  enhancement  |     Status:  reopened
  Priority:  medium       |  Milestone:  PostGIS Fund Me
 Component:  topology     |    Version:  2.0.x
Resolution:               |   Keywords:  performance
Changes (by strk):
 * status:  closed => reopened
 * resolution:  fixed =>
Comment:
 relation(layer_id) should not be needed because you usually don't have
 those many layers and anyway the btree (layer_id, topogeo_id, element_id,
 element_type) index would be already used when a query using layer_id is
 issued.
 The abs(element_id) I removed the need for in
 [854103fa2e087b53485c8cf403a1fcb952146be2/git]
 relation(topogeo_id) would also be covered by the existing btree on all
 members, as topogeo_id is second member after layer_id, and you always
 search for topogeo_id togheter with layer_id.
 The edge_data(geom) is already created.
 The node(containing_face) I pushed already with
 [e4495fb792fe31a87a84e92297d276baf254007a/git]
 The only left over are the indices on abs_next_{left,right}_edge which I
 guess would be useful upon deleting edges, to re-link the edges pointing
 to the one being removed. I'm reopening the ticket to research upon this
 one.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2083#comment:19>
