[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-784-g6ba156f5b
Mon May 2 17:36:30 PDT 2022
the project "PostGIS".
       via  6ba156f5bdeb3cc31a4fc640ff75259edbee0861 (commit)
      from  0428945693d284ae085f2fe3d4ea2764eba2c62c (commit)
revisions in full, below.
commit 6ba156f5bdeb3cc31a4fc640ff75259edbee0861
Author: Regina Obe <lr at pcorp.us>
Date:   Mon May 2 20:34:57 2022 -0400
    CHANGES:
    Closes #5136
    Change cunit tests that fail on GDAL 3.2 to do perimeter test instead of
    area test
    Change postgresql tests that fail on GDAL 3.2 to do ST_MakeValid before
    testing
diff --git a/raster/test/cunit/cu_raster_geometry.c b/raster/test/cunit/cu_raster_geometry.c
index 4eee17dc4..7118d90e8 100644
--- a/raster/test/cunit/cu_raster_geometry.c
+++ b/raster/test/cunit/cu_raster_geometry.c
@@ -322,7 +322,7 @@ static void test_raster_surface() {
 	gexpected = lwgeom_from_wkt(
 	    "MULTIPOLYGON(((1 -1,1 0,5 0,5 -5,4 -5,0 -5,0 -1,1 -1),(1 -1,1 -2,2 -2,2 -1,1 -1),(2 -2,2 -3,3 -3,3 -2,2 -2)))",
 	    LW_PARSER_CHECK_NONE);
-	CU_ASSERT_DOUBLE_EQUAL(lwgeom_area(gobserved), lwgeom_area(gexpected), FLT_EPSILON);
+	CU_ASSERT_DOUBLE_EQUAL(lwgeom_perimeter(gobserved), lwgeom_perimeter(gexpected), FLT_EPSILON);
 	lwmpoly_free(mpoly);
 	mpoly = NULL;
@@ -336,7 +336,7 @@ static void test_raster_surface() {
 	    "MULTIPOLYGON(((1 -1,1 0,5 0,5 -5,4 -5,0 -5,0 -1,1 -1),(1 -1,1 -2,2 -2,2 -1,1 -1),(2 -2,2 -3,3 -3,3 -2,2 -2),(3 -3,3 -4,4 -4,4 -3,3 -3)))",
 	mpoly = NULL;
diff --git a/raster/test/regress/rt_polygon.sql b/raster/test/regress/rt_polygon.sql
index 454f28fa9..111f089fa 100644
--- a/raster/test/regress/rt_polygon.sql
+++ b/raster/test/regress/rt_polygon.sql
@@ -57,8 +57,9 @@ FROM (
 	FROM raster_polygon
 ) foo;
+-- TODO: Only GDAL 3.2 fails without ST_MakeValid, remove ST_MakeValid when GDAL 3.2 is no longer supported
 SELECT
-	ST_Equals( ST_Polygon(rast), 'MULTIPOLYGON(((1 -1,1 0,5 0,5 -5,4 -5,0 -5,0 -1,1 -1),(1 -1,1 -2,2 -2,2 -1,1 -1),(2 -2,2 -3,3 -3,3 -2,2 -2)))'::geometry)
+	ST_Equals( ST_MakeValid(ST_Polygon(rast)), 'MULTIPOLYGON(((1 -1,1 0,5 0,5 -5,4 -5,0 -5,0 -1,1 -1),(1 -1,1 -2,2 -2,2 -1,1 -1),(2 -2,2 -3,3 -3,3 -2,2 -2)))'::geometry)
 FROM (
 	SELECT
 		ST_SetValue(
@@ -74,7 +75,7 @@ FROM (
 ) foo;
 SELECT
-	ST_Equals( ST_Polygon(rast) , 'MULTIPOLYGON(((1 -1,1 0,5 0,5 -5,4 -5,0 -5,0 -1,1 -1),(1 -1,1 -2,2 -2,2 -1,1 -1),(2 -2,2 -3,3 -3,3 -2,2 -2),(3 -3,3 -4,4 -4,4 -3,3 -3)))'::geometry)
+	ST_Equals( ST_MakeValid(ST_Polygon(rast)) , 'MULTIPOLYGON(((1 -1,1 0,5 0,5 -5,4 -5,0 -5,0 -1,1 -1),(1 -1,1 -2,2 -2,2 -1,1 -1),(2 -2,2 -3,3 -3,3 -2,2 -2),(3 -3,3 -4,4 -4,4 -3,3 -3)))'::geometry)
 FROM (
 	SELECT
 		ST_SetValue(
Summary of changes:
 raster/test/cunit/cu_raster_geometry.c | 4 ++--
 raster/test/regress/rt_polygon.sql     | 5 +++--
 2 files changed, 5 insertions(+), 4 deletions(-)
hooks/post-receive
