[postgis-tickets] [PostGIS] #5147: ST_ConcaveHull gives ERROR: lwgeom_concavehull: GEOS Error: IllegalArgumentException: Edge length ratio must be in range [0, 1]e
PostGIS trac at osgeo.org
Wed May 4 09:28:08 PDT 2022
IllegalArgumentException: Edge length ratio must be in range [0,1]e
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.3.0
Component:  postgis  |    Version:  master
 Keywords:           |
 -- this is with the new GEOS implementation
 POSTGIS="3.3.0dev 3.2.0-788-g82538c6ea" [EXTENSION] PGSQL="110" GEOS="3.11
 .0dev-CAPI-1.16.0" SFCGAL="SFCGAL 1.4.1, CGAL 5.3, BOOST 1.78.0"
 PROJ="7.2.1" LIBXML="2.9.9" LIBJSON="0.12" LIBPROTOBUF="1.2.1"
 WAGYU="0.5.0 (Internal)"
 Example that gives the error:
 SELECT ST_ConcaveHull('MULTIPOINT((99.5 68.5),(69 49.5),(106 50.5),(67.5
 52),(86.5 58.5),(104 50.5),(70 57),(95 87),(89 114),(103.5 56),(76
 61.5),(53.5 59.5),(56 67),(86 123),(89 51.5),(53 60.5),(103.5 59),(58
 73.5),(59.5 87),(69.5 57),(91 104.5),(79.5 123),(59 51),(67.5 53),(88
 117.5),(79.5 61),(74 124),(98 73.5),(83.5 123.5),(61.5 90.5),(72
 124.5),(55.5 71.5),(60 90),(93 49),(99 51),(69 57.5),(90.5 106),(61.5
 50),(69 118),(68 52),(65 109),(77.5 99.5),(81.5 77),(81 87.5),(76.5
 78),(80 92),(80.5 81),(81 88.5),(75.5 87),(77 100.5))'::geometry, 0.1)
 I tried with .1, 0.2, 0.5 also as in the docs and resulted in the same
 error.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5147>
