[postgis-tickets] [PostGIS] #5148: ST_Clip ERROR: rt_raster_from_two_rasters: The two rasters provided do not have the same alignment
PostGIS trac at osgeo.org
Fri May 6 08:54:34 PDT 2022
  Reporter:  sergeish  |      Owner:  robe
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.3.0
 Component:  raster    |    Version:  master
Resolution:            |   Keywords:
Comment (by robe):
 As I recall there was an issue a long time ago like pre GDAL 2.0 with
 using double precision compare in postgis raster.  I forget what it was.
 I suspect it's not relevant anymore, so I'd go ahead and flip to DBL_EQ if
 it fixes this.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5148#comment:2>
