[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-808-g82505bd1f
Sat May 7 12:23:06 PDT 2022
the project "PostGIS".
       via  82505bd1ffc6ca1047004b8bf353024851ae72c5 (commit)
       via  1aa4a241fd9b7ca0baffda7c2c5ef4e4883fe99b (commit)
       via  12ecaa03e1fc56fd7623fe5ab8c2c569a68085dc (commit)
       via  784683d74fb7f3dad3fcdc69a5e7c073c27dc86e (commit)
       via  928ea233d286c0a24465ea42bb20b9e0c0817920 (commit)
       via  1bb3834beefa0dd5c935e752c5dccf523808cafb (commit)
       via  3cf4e850824ee0afda13d9ce82f0bc4efc956ebb (commit)
       via  4f54fcba30447905d61166cebacc7cf0de1fe216 (commit)
      from  0794bb543d3f15891bba672fea32f7735a8857d7 (commit)
revisions in full, below.
commit 82505bd1ffc6ca1047004b8bf353024851ae72c5
Author: Regina Obe <regina at arrival3d.com>
Date:   Sat May 7 19:16:13 2022 +0000
    Translated using Weblate (Russian)
    Currently translated at 0.9% (2 of 213 strings)
    Translation: postgis/introduction.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/introductionxml/ru/
diff --git a/doc/po/ru/introduction.xml.po b/doc/po/ru/introduction.xml.po
index eee242bbd..0a3c9739b 100644
--- a/doc/po/ru/introduction.xml.po
+++ b/doc/po/ru/introduction.xml.po
@@ -8,17 +8,18 @@ msgstr ""
 "Project-Id-Version: PostGIS\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2022-04-16 08:20+0000\n"
-"PO-Revision-Date: 2022-01-13 15:49+0000\n"
-"Last-Translator: Александр Иутин <alexmapmaker at gmail.com>\n"
-"Language-Team: Russian (Russia) (http://www.transifex.com/postgis/postgis/"
-"language/ru_RU/)\n"
-"Language: ru_RU\n"
+"PO-Revision-Date: 2022-05-07 19:23+0000\n"
+"Last-Translator: Regina Obe <regina at arrival3d.com>\n"
+"Language-Team: Russian <https://weblate.osgeo.org/projects/postgis/"
+"introductionxml/ru/>\n"
+"Language: ru\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "Plural-Forms: nplurals=4; plural=(n%10==1 && n%100!=11 ? 0 : n%10>=2 && n"
 "%10<=4 && (n%100<12 || n%100>14) ? 1 : n%10==0 || (n%10>=5 && n%10<=9) || (n"
 "%100>=11 && n%100<=14)? 2 : 3);\n"
+"X-Generator: Weblate 4.11.2\n"
 #. Tag: title
 #: introduction.xml:3
@@ -38,7 +39,7 @@ msgid ""
 msgstr ""
 "PostGIS - это пространственное расширение для СУБД PostgreSQL, созданное "
 "компанией Refractions Research в качестве исследовательского проекта по "
-"технологиям пространственных баз данных.  Refractions - это консалтинговая "
+"технологиям пространственных баз данных. Refractions - это консалтинговая "
 "компания в области ГИС и баз данных (базируется в Виктории, Британская "
 "Колумбия, Канада), специализирующаяся на интеграции данных и разработке "
 "программного обеспечения."
commit 1aa4a241fd9b7ca0baffda7c2c5ef4e4883fe99b
Date:   Sat May 7 19:19:51 2022 +0000
    Translated using Weblate (Italian)
    Currently translated at 63.1% (113 of 179 strings)
    Translation: postgis/using_raster_dataman.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/using_raster_datamanxml/it/
diff --git a/doc/po/it_IT/using_raster_dataman.xml.po b/doc/po/it_IT/using_raster_dataman.xml.po
index 2c14d12ba..475326da1 100644
--- a/doc/po/it_IT/using_raster_dataman.xml.po
+++ b/doc/po/it_IT/using_raster_dataman.xml.po
@@ -2,20 +2,22 @@
 # Translators:
 # pibinko <pibinko at gmail.com>, 2013-2014
+# Regina Obe <regina at arrival3d.com>, 2022.
 msgid ""
 msgstr ""
 "POT-Creation-Date: 2021-11-08 06:12+0000\n"
-"PO-Revision-Date: 2021-11-28 22:35+0000\n"
-"Last-Translator: Regina Obe\n"
-"Language-Team: Italian (Italy) (http://www.transifex.com/postgis/postgis/"
-"language/it_IT/)\n"
+"Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/"
+"using_raster_datamanxml/it/>\n"
 "Language: it_IT\n"
-"Plural-Forms: nplurals=2; plural=(n != 1);\n"
+"Plural-Forms: nplurals=2; plural=n != 1;\n"
 #. Tag: title
 #: using_raster_dataman.xml:3
@@ -56,7 +58,7 @@ msgid ""
 "raster table. It is capable of loading folders of raster files as well as "
 "creating overviews of rasters."
 msgstr ""
-" <varname>raster2pgsql</varname> è un loader raster che trasforma i formati "
+"<varname>raster2pgsql</varname> è un loader raster che trasforma i formati "
 "raster supportati da GDAL in formato SQL utile al caricamento in una tabella "
 "raster di PostGIS. Può caricare anche cartelle di file, e creare delle "
 "anteprime."
commit 12ecaa03e1fc56fd7623fe5ab8c2c569a68085dc
Date:   Sat May 7 19:21:12 2022 +0000
    Currently translated at 18.2% (292 of 1601 strings)
    Translation: postgis/reference_raster.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_rasterxml/it/
diff --git a/doc/po/it_IT/reference_raster.xml.po b/doc/po/it_IT/reference_raster.xml.po
index 6ed2f2517..db2b4e42c 100644
--- a/doc/po/it_IT/reference_raster.xml.po
+++ b/doc/po/it_IT/reference_raster.xml.po
@@ -7,8 +7,8 @@ msgstr ""
 "POT-Creation-Date: 2022-05-03 02:58+0000\n"
-"PO-Revision-Date: 2022-02-18 09:52+0000\n"
-"Last-Translator: Sandro Santilli <strk at kbt.io>\n"
 "reference_rasterxml/it/>\n"
 "Language: it_IT\n"
@@ -16,7 +16,7 @@ msgstr ""
-"X-Generator: Weblate 4.10.1\n"
 #. Tag: title
 #: reference_raster.xml:3
@@ -20923,8 +20923,6 @@ msgid ""
 "Return true if rasters rastA and rastB are within the specified distance of "
 "each other."
 msgstr ""
-"Return true if rasters rastA and rastB are within the specified distance of "
-"each other."
 #. Tag: funcsynopsis
 #: reference_raster.xml:11546
commit 784683d74fb7f3dad3fcdc69a5e7c073c27dc86e
Date:   Sat May 7 19:19:30 2022 +0000
    Currently translated at 41.3% (19 of 46 strings)
    Translation: postgis/reference_type.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_typexml/it/
diff --git a/doc/po/it_IT/reference_type.xml.po b/doc/po/it_IT/reference_type.xml.po
index 55a44fa93..107b51f87 100644
--- a/doc/po/it_IT/reference_type.xml.po
+++ b/doc/po/it_IT/reference_type.xml.po
 "POT-Creation-Date: 2021-09-11 01:55+0000\n"
-"PO-Revision-Date: 2022-01-12 23:53+0000\n"
 "reference_typexml/it/>\n"
 "Language: it_IT\n"
 #. Tag: para
 #: reference_type.xml:5
@@ -70,7 +70,7 @@ msgstr ""
 #: reference_type.xml:27
 #, fuzzy, no-c-format
 msgid "PostGIS Geometry/Geography/Box Data Types"
-msgstr "PostgreSQL PostGIS tipi Geometry/Geography/Box "
+msgstr "PostgreSQL PostGIS tipi Geometry/Geography/Box"
 #. Tag: refname
 #: reference_type.xml:31
commit 928ea233d286c0a24465ea42bb20b9e0c0817920
Date:   Sat May 7 19:19:16 2022 +0000
    Currently translated at 57.9% (160 of 276 strings)
    Translation: postgis/reference_input.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_inputxml/it/
diff --git a/doc/po/it_IT/reference_input.xml.po b/doc/po/it_IT/reference_input.xml.po
index 23ec452a0..7113fc343 100644
--- a/doc/po/it_IT/reference_input.xml.po
+++ b/doc/po/it_IT/reference_input.xml.po
@@ -10,8 +10,8 @@ msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "reference_inputxml/it/>\n"
 "Language: it_IT\n"
@@ -19,7 +19,7 @@ msgstr ""
 #. Tag: para
 #: reference_input.xml:6
@@ -55,8 +55,8 @@ msgid ""
 "linestrings as a MultiLineString Well-Known text representation.</refpurpose>"
 msgstr ""
 "<refpurpose>Costruisce un poligono an partire da una collezione arbitraria "
-"di linee chiuse in forma di multilinee  rappresentate come testo Well-Known</"
-"refpurpose>"
+"di linee chiuse in forma di multilinee rappresentate come testo Well-"
+"Known</refpurpose>"
 #. Tag: funcprototype
 #: reference_input.xml:25
commit 1bb3834beefa0dd5c935e752c5dccf523808cafb
Date:   Sat May 7 19:19:55 2022 +0000
    Currently translated at 53.5% (15 of 28 strings)
    Translation: postgis/performance_tips.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/performance_tipsxml/it/
diff --git a/doc/po/it_IT/performance_tips.xml.po b/doc/po/it_IT/performance_tips.xml.po
index 7d6284de8..af51d08e0 100644
--- a/doc/po/it_IT/performance_tips.xml.po
+++ b/doc/po/it_IT/performance_tips.xml.po
@@ -7,15 +7,16 @@ msgstr ""
-"PO-Revision-Date: 2013-11-30 05:55+0000\n"
-"Last-Translator: Tommaso Di Bucchianico\n"
-"Language-Team: Italian (Italy) (http://www.transifex.com/projects/p/"
-"postgis-1/language/it_IT/)\n"
+"performance_tipsxml/it/>\n"
 "Language: it_IT\n"
 #. Tag: title
 #: performance_tips.xml:3
@@ -53,7 +54,7 @@ msgstr ""
 "di grandi dimensioni (nel senso di dimensioni dei dati) che non possono "
 "essere salvati in normali pagine (per esempio lunghi testi, immagini o "
 "geometrie con molti vertici). Vedi <ulink url=\"http://www.postgresql.org/"
-"docs/current/static/storage-toast.html\">la  documentazione PostgreSQL sulle "
+"docs/current/static/storage-toast.html\">la documentazione PostgreSQL sulle "
 "tabelle TOAST</ulink> per maggiori informazioni)."
 #. Tag: para
@@ -88,7 +89,7 @@ msgid ""
 "pages, too."
 msgstr ""
 "Ora si lanci una query che usi l'operatore  && e che [MATCHES] solo "
-"poche righe. Il "
+"poche righe. Il"
 #. Tag: para
 #: performance_tips.xml:35
commit 3cf4e850824ee0afda13d9ce82f0bc4efc956ebb
Date:   Sat May 7 19:15:37 2022 +0000
    Translated using Weblate (Korean)
    Currently translated at 97.5% (202 of 207 strings)
    Translation: postgis/extras_address_standardizer.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/extras_address_standardizerxml/ko/
diff --git a/doc/po/ko_KR/extras_address_standardizer.xml.po b/doc/po/ko_KR/extras_address_standardizer.xml.po
index b510670eb..57cd9915a 100644
--- a/doc/po/ko_KR/extras_address_standardizer.xml.po
+++ b/doc/po/ko_KR/extras_address_standardizer.xml.po
@@ -3,20 +3,22 @@
 # Translators:
 # Kwon.Yongchan <ruvyn at naver.com>, 2016
 msgid ""
 msgstr ""
-"PO-Revision-Date: 2018-07-23 18:00+0000\n"
-"Language-Team: Korean (Korea) (http://www.transifex.com/postgis/postgis/"
-"language/ko_KR/)\n"
+"Language-Team: Korean <https://weblate.osgeo.org/projects/postgis/"
+"extras_address_standardizerxml/ko/>\n"
 "Language: ko_KR\n"
 "Plural-Forms: nplurals=1; plural=0;\n"
 #. Tag: title
 #: extras_address_standardizer.xml:3
@@ -1673,10 +1675,10 @@ msgid ""
 "street</code>, and a macro consisting of standard postal second line of an "
 "address e.g <code>city, state postal_code country</code>."
 msgstr ""
-"변종 2: 주소를 두 부분으로 입력받습니다.  <code>house_num street</code> 같은 "
+"변종 2: 주소를 두 부분으로 입력받습니다. <code>house_num street</code> 같은 "
 "우편 주소의 표준 첫 번째 행으로 이루어진 <varname>micro</varname> 절과,  "
-"<code>city, state postal_code country</code> 같은 우편 주소의 표준 두 번째 행"
-"으로 이루어진 <varname>macro</varname> 절입니다."
+"<code>city, state postal_code country</code> 같은 우편 주소의 표준 두 번째 "
+"행으로 이루어진 <varname>macro</varname> 절입니다."
 #. Tag: para
 #: extras_address_standardizer.xml:661
commit 4f54fcba30447905d61166cebacc7cf0de1fe216
Date:   Sat May 7 19:13:06 2022 +0000
    Translated using Weblate (Spanish)
    Currently translated at 42.0% (87 of 207 strings)
    Translate-URL: https://weblate.osgeo.org/projects/postgis/extras_address_standardizerxml/es/
diff --git a/doc/po/es/extras_address_standardizer.xml.po b/doc/po/es/extras_address_standardizer.xml.po
index c5eb04133..b77cf4561 100644
--- a/doc/po/es/extras_address_standardizer.xml.po
+++ b/doc/po/es/extras_address_standardizer.xml.po
@@ -9,7 +9,7 @@ msgstr ""
-"PO-Revision-Date: 2022-03-11 05:52+0000\n"
 "Language-Team: Spanish <https://weblate.osgeo.org/projects/postgis/"
 "extras_address_standardizerxml/es/>\n"
@@ -131,7 +131,7 @@ msgid ""
 "US or Canada else US"
 msgstr ""
 "Se supone que es de EE. UU. o CA según: código postal de estado/provincia "
-"como EE. UU. o Canadá,  como EE. UU. o Canadá más EE. UU. ."
+"como EE. UU. o Canadá, como EE. UU. o Canadá más EE. UU. ."
 #. Tag: term
 #: extras_address_standardizer.xml:21
Summary of changes:
 doc/po/es/extras_address_standardizer.xml.po    |  4 ++--
 doc/po/it_IT/performance_tips.xml.po            | 15 ++++++++-------
 doc/po/it_IT/reference_input.xml.po             | 10 +++++-----
 doc/po/it_IT/reference_raster.xml.po            |  8 +++-----
 doc/po/it_IT/reference_type.xml.po              |  8 ++++----
 doc/po/it_IT/using_raster_dataman.xml.po        | 14 ++++++++------
 doc/po/ko_KR/extras_address_standardizer.xml.po | 16 +++++++++-------
 doc/po/ru/introduction.xml.po                   | 13 +++++++------
 8 files changed, 46 insertions(+), 42 deletions(-)
hooks/post-receive
